Engine Over Heating - 600RR.net
post #1 of 10 (permalink) Old 05-10-2011, 02:14 PM Thread Starter
Francismwoo's Avatar
Exclamation Engine Over Heating
Recently my brother dropped the bike and it bent one of the piping that led to the radiator. Took apart the bike and replaced that pipe and now the bike is over heating.
Before replacing it, I thought it was cause the coolant was leaking through the bent pipe, but with new coolant and no leakage, can't figure out why the engine is over heating. It went past 250 F today when test riding it.
ANY IDEAS?
Thanks in advance guys!
Francismwoo is offline
post #2 of 10 (permalink) Old 05-10-2011, 02:22 PM
is your fan kicking on when you hit the 220F mark?
Silver 2008 CBR600rr
-Watsen Design Flush Mounts
-Woodcraft Frame Sliders
-DDM Tuning 35w 5000k hid kit
-Tripage IT Taillight
-Akrapovic Exhaust
jaydeehitop is offline
post #3 of 10 (permalink) Old 05-10-2011, 02:31 PM
BAKA444's Avatar
how did you replace the coolant? Did you remember to burp the system of any trapped air after replacing the pipe and coolant? If not, then trapped air is in your cooling system giving inefficient cooling and that may be why you're overheating.
And the half of me's all about apathy
And the other half just doesn't care
BAKA444 is offline
post #4 of 10 (permalink) Old 05-10-2011, 02:32 PM Thread Starter
how do you burp the system of trapped air?
post #5 of 10 (permalink) Old 05-10-2011, 02:33 PM Thread Starter
the fan does kick it after a certain temp but it's been inconsistent. sometimes it kicks in when bike starts, sometimes it kicks in after 240.
it's driving me crazy! literally dropped it while parked, at least that's why my brother said.
post #6 of 10 (permalink) Old 05-10-2011, 02:36 PM
BAKA444's Avatar
you gotta open the radiator cap and turn on the engine until the thermostat opens up (around 180 F) After that, there should be a noticeable drop in temperature to like 170F or so. When the tstat opens, blip the throttle and you'll see large air bubbles coming through. Thats the trapped air throughout the system being forced out. The coolant level should drop noticeable afterwards so top her off and you should be good to go after. Check the coolant overflow as well.
BAKA444 is offline
The Following 2 Users Say Thank You to BAKA444 For This Useful Post:
Francismwoo (05-10-2011), Kit Fox (05-10-2011)
post #7 of 10 (permalink) Old 05-10-2011, 02:43 PM Thread Starter
I"ll def try that today and keep you posted!
post #8 of 10 (permalink) Old 05-10-2011, 02:48 PM
tenjin's Avatar
see my signature for specifics on how the cooling system should work.
DDM 55w 7k HID
Sliders
Black Vortex Rearsets
R&G Bar Ends
Black passenger pegs
JPR Shorty levers
EK 520MVXZ black chain
Versah RJL Brake pads
Flushmounts
fender eliminator
Pair Delete
Bazzaz AFM
tenjin is offline
post #9 of 10 (permalink) Old 05-10-2011, 03:00 PM Thread Starter
here are some questions i got from your signature
The radiator and engine contains 3.2 Liters (or 3.4 US Quarts)
the Reserve tank contains .3 Liters (or .32 quarts)
If my coolant was drained due to a leak, does that mean i have to put coolant separately into the radiator as well?
the radiator pressure limits are 108-137 kPa (or 16-20 PSI) .. note, this is the pressure range where coolant should be switching to the reserve tank as an over flow
where and how can i check the pressure?
post #10 of 10 (permalink) Old 05-10-2011, 03:03 PM
tenjin's Avatar
yes, if coolant leaked from the cooling system, its best to add directly to the radiator,
the cap is a bit trickier, and will require specialized tools to successfully test it, if in doubt, replace it, iirc its less than 10 bucks.
DDM 55w 7k HID
Sliders
R&G Bar Ends
JPR Shorty levers
Flushmounts
fender eliminator
Pair Delete
Bazzaz AFM
tenjin is offline
The Following User Says Thank You to tenjin For This Useful Post:
