Running Rich, Weird Sound, Pants On Fire... Spark Plugs? - 600RR.net
post #1 of 28 (permalink) Old 05-17-2011, 11:49 PM Thread Starter
AstroPenguin's Avatar
so I started my bike up the other day and it sounded way different than the last time I rode it, exhaust had a deeper tone almost like a V-twin and the bike is running rich.
there is no FI code, could it be the spark plugs or fuel regulator? it also kind of stutters when I try and start it up
I only have about 5,000 miles
I took a couple videos so you can get a better idea of the sound and the startup, my pants also caught on fire today from the exhaust!
2007 Honda CBR600RR - Pearl White
Pearl White seat cowl
Akrapovic Slip-on (Titanium w/ blued midpipe)
BMC Air Filter
Bridgestone S20 tires
Driven 520 Conversion (-1 +2)
Puig Double Bubble (Dark Smoke)
ASV Shorty Levers
Woodcraft Rearsets
Motydesign custom gauges w/ Acumen Gear Indicator
Motydesign 8-cell Battery
HRC Throttle cables & housing
Rizoma Grips & bar ends w/ 1/6th turn throttle
Tripage Smoked IT
Watsen Flushmounts
Black Majik Carbon Fiber huggers and tank panels
AstroPenguin is offline
post #2 of 28 (permalink) Old 05-18-2011, 12:14 AM
GrrUSMC's Avatar
Damn man that's crazy.. sorry. So it just started act up for no reason?
'08 600RR Red & Black
C/F Leo Vince S/O
ASV Shorties
DIY Fender Eliminator (Sexy)
HRC Delete Kit
DB Smoked Wind Screen
My '08 Red and Black
GrrUSMC is offline
post #3 of 28 (permalink) Old 05-18-2011, 12:57 AM
Images: 5
Definitely doesn't sound right. Have you done any work to the bike recently? When was the last time you rode it? To give the rest of the readers a better idea of the problem, can you also post any mods on the bike (Power Commander or anything like that?).
i_tys is offline
post #4 of 28 (permalink) Old 05-18-2011, 01:18 AM
Huh, I actually like how it sounds! Though the revving sounded a little weak...
Are you sure it's running rich, have you checked the plugs or is the exhaust all sooty?
Checking the air filter would be a good first step.
x5finger is offline
post #5 of 28 (permalink) Old 05-18-2011, 06:32 AM
Nico's Avatar
Dead coil or spark plug etc... get yourself a laser thermometer and measure your header temps, the cool one is the one with the problem.
You should be able to get one of these nice and cheap.
Nico is offline
post #6 of 28 (permalink) Old 05-18-2011, 10:19 AM Thread Starter
Last time I rode it was two weeks ago and it ran just fine. I did have an FI error a couple weeks before that (for the idle air control valve) but I just forgot to plug it back in when I replaced the throttle cables.
I don't have a power commander but I put a BMC air filter in recently along with hrc throttle cables. I have noticed that the fuel gauge has gone down quite a bitter faster than usual and the exhaust smell is strong. I don't have a heat shield over the exhaust pipe but it seems to be hotter than usual (being that my pants caught on fire) but the engine temp never went over 200 degrees.
Nico, where can I find one of those laser testers?
BMC Air Filter
ASV Shorty Levers
Woodcraft Rearsets
Tripage Smoked IT
Watsen Flushmounts
post #7 of 28 (permalink) Old 05-18-2011, 10:36 AM
Nico's Avatar
http://shop.ebay.com/i.html?_nkw=las....c0.m270.l1313
Jump on ebay and type in 'Laser Thermometer' you will get heaps of results.
Nico is offline
The Following User Says Thank You to Nico For This Useful Post:
AstroPenguin (05-18-2011)
post #8 of 28 (permalink) Old 05-18-2011, 10:58 AM Thread Starter
awesome thanks! i'm gonna check at Sears too, i wanna get it as soon as i can, so i need to see which header pipe isnt getting hot enough?
BMC Air Filter
ASV Shorty Levers
Woodcraft Rearsets
Tripage Smoked IT
Watsen Flushmounts
post #9 of 28 (permalink) Old 05-18-2011, 11:36 AM
PHXRR's Avatar
def check all the plugs. sound like a plug or plugs not gettin spark.
Death Smiles Upon Us All, All One Can Do Is twist The Throttle And Smile Back...........
PHXRR is offline
post #10 of 28 (permalink) Old 05-18-2011, 11:46 AM
tenjin's Avatar
he definitly has a dead hole ... i wonder if thats whats causing all the heat in the pipe? cause thats some SERIOUS blueing going on there...
DDM 55w 7k HID
Sliders
Black Vortex Rearsets
R&G Bar Ends
Black passenger pegs
JPR Shorty levers
EK 520MVXZ black chain
Versah RJL Brake pads
Flushmounts
fender eliminator
Pair Delete
Bazzaz AFM
tenjin is offline
post #11 of 28 (permalink) Old 05-18-2011, 12:19 PM Thread Starter
dead hole?
do you think the time I rode the bike before plugging the IACV back in could have blackened up the spark plugs? being that it messed with the air/fuel mix.
timeline:
- replaced throttle cables
- I rode it for a couple hours for one day without the idle air control (forgot to plug it back in)
- found the problem and rode for one day, everything worked fine
- now it runs rich, mid-pipe hotter than usual, seems like it lacks power (maybe one of the cylinders isnt running?)
p.s. when i first put on the titanium akra, i also had the heat shield covering the midpipe for a couple months, that caused the baked blue color, although it does seem bluer than normal
BMC Air Filter
ASV Shorty Levers
Woodcraft Rearsets
Tripage Smoked IT
Watsen Flushmounts
post #12 of 28 (permalink) Old 05-18-2011, 03:14 PM
PHXRR's Avatar
dead hole = no spark in a cylinder
PHXRR is offline
post #13 of 28 (permalink) Old 05-18-2011, 03:16 PM Thread Starter
ahhh, good to know
BMC Air Filter
ASV Shorty Levers
Woodcraft Rearsets
Tripage Smoked IT
Watsen Flushmounts
post #14 of 28 (permalink) Old 05-18-2011, 04:03 PM
SuperBrute's Avatar
Feedback Score: 27 reviews
also on another note..you have a slip on or full system? and which bmc filter did you put in?
since you have an akra and a filter, it might be time for a power commander or some other fuel managment system too. could be running rich/lean..
SuperBrute is offline
post #15 of 28 (permalink) Old 05-18-2011, 04:13 PM Thread Starter
so i picked one up at Sears for like 40 bucks, took the bike around the block and checked the temps of the four header pipes
from my perspective standing in front of the bike i will go left to right from 1 to 4:
1 - 120 degrees
2 - 200 degrees
3 - 220 degrees
4 - 220 degrees
exhaust midpipe was about 140 degrees
SuperWario:
its a titanium slip on with BMC filter for street (not race)
it wasnt running rich at first from those upgrades, so i dont think they would make that drastic of a change. i probably should invest in a power commander next tho
BMC Air Filter
ASV Shorty Levers
Woodcraft Rearsets
Tripage Smoked IT
Watsen Flushmounts
post #16 of 28 (permalink) Old 05-18-2011, 04:20 PM
tenjin's Avatar
1 - 120 degrees
2 - 200 degrees
3 - 220 degrees
4 - 220 degrees
so now you know you need to check connections on injectors, plugs and all that good stuff on #1
DDM 55w 7k HID
Sliders
R&G Bar Ends
JPR Shorty levers
Flushmounts
fender eliminator
Pair Delete
Bazzaz AFM
tenjin is offline
post #17 of 28 (permalink) Old 05-18-2011, 08:22 PM
GrrUSMC's Avatar
Sounds like you've found your problem child. Let us know what happens.
C/F Leo Vince S/O
ASV Shorties
HRC Delete Kit
GrrUSMC is offline
post #18 of 28 (permalink) Old 05-19-2011, 01:24 AM Thread Starter
well i found out what the problem was without taking much apart!
somehow that white connector above the spark plug was mysteriously disconnected... either the plug got unclipped all by itself after the "everything's fine" ride a couple weeks ago or my douche bag bi-polar roommate reached in between the fairings and unplugged it... i'm thinking the latter
seriously!?, how easily can those connectors come undone by themselves without crashing the thing?
plugged that back in and she sounded good as new, although the electrical was still acted up. dash kept restarting, checked the battery and the positive terminal was loose.
now everything is good as new! for now...
BMC Air Filter
ASV Shorty Levers
Woodcraft Rearsets
Tripage Smoked IT
Watsen Flushmounts
post #19 of 28 (permalink) Old 05-19-2011, 07:41 AM
Nico's Avatar
Good to hear!
Those plugs definitely wont come out on their own if they are in properly, but its easy to not get them in, and subsequently have them fall out...
The hot mid pipe will have been caused by the un-ignited fuel from #1 burning up in the exhaust...
Nico is offline
post #20 of 28 (permalink) Old 05-19-2011, 06:53 PM Thread Starter
Good to hear!
do you think i could have melted the ceramic substrate inside the catalytic converter from only running on 3 cylinders? it got pretty damn hot
BMC Air Filter
ASV Shorty Levers
Woodcraft Rearsets
Tripage Smoked IT
Watsen Flushmounts
post #21 of 28 (permalink) Old 05-19-2011, 07:31 PM
Images: 5
The ceramic in the catalytic converter can withstand a large amount of heat. I doubt that you would have a problem , but you can always check by running the bike and then taking the temperature along the length of the cat. You should have equal heat distribution along the cat. If you find that the inlet side is really hot and then the temp just drops off then you might have a plugged cat. Also, check the exhaust flow out of the exhaust. The exhaust coming out of the muffler should have some pressure to it. If you can completely block off the muffler and you don't feel any pressure then there is a large pressure drop in your cat. I hope this helps, but like I said, you should be fine.
i_tys is offline
post #22 of 28 (permalink) Old 05-19-2011, 07:58 PM
tenjin's Avatar
not to mention, the cbr cat uses some sort of metal substrate unlike a cars
is a weird cat imo.
DDM 55w 7k HID
Sliders
R&G Bar Ends
JPR Shorty levers
Flushmounts
fender eliminator
Pair Delete
Bazzaz AFM
tenjin is offline
post #23 of 28 (permalink) Old 05-19-2011, 11:56 PM
Nico's Avatar
If it was ceramic, the pipe would melt first...
You wont have done any damage to it.
Nico is offline
post #24 of 28 (permalink) Old 05-19-2011, 11:58 PM
Nico's Avatar
If you completely block off the muffler even the smallest bit of flow will equalize the pressure on both sides of the cat... its flow rate you would be interested in, either that or the differential pressure across the cat with the exhaust unimpeded.
Nico is offline
post #25 of 28 (permalink) Old 06-08-2011, 12:38 AM
raymoon's Avatar
AstroPenguin,
Was your idle normal?
I started my bike up cold this morning and usually it revs a little higher than normal idle speeds then slowly comes down to 1500.
But this morning it kind of sounded like yours, it started idling around 1300-1400 with a lower deeper sound. Usually when i start it up my two-bros deafen me, but not so much this time. Just restarted it after a quick ride too and same things happening.
raymoon is offline
post #26 of 28 (permalink) Old 10-20-2011, 08:45 PM
05'Scorpion's Avatar
Feedback Score: 8 reviews
Question
Originally Posted by raymoon View Post
AstroPenguin,
id like to know whats causing this...
2006 CBR 600RR - Red/Black *StreetBike*
2003 CBR 600RR - All Black *Trackbike* SOLD
Orion Pit Bike *SOLD
05' CBR 600RR - Sold/Missed
WANTED!!! 08'+ 1KRR for sale White/Red or all Black
and....OHLINS FORKS/BREMBO BRAKES!!!
PARTS FOR SALE: https://www.600rr.net/vb/showthread.php?t=204160
05'Scorpion is offline
post #27 of 28 (permalink) Old 10-20-2011, 08:48 PM
bwolfe84's Avatar
Feedback Score: 5 reviews
went it is all set and done, how the hell did you pants catch fire due to the exhaust. I am not saying i don't believe you, i am just trying to figure out where your pants are while riding that your exhaust can cause ignition.
Honda 600RR RED (Julia)
"Ambition is just a poor excuse for people to not have enough sense to be lazy..."
bwolfe84 is offline
post #28 of 28 (permalink) Old 10-20-2011, 08:52 PM
tenjin's Avatar
AstroPenguin,
fairly cool when you started your bike? sounds like the electronics doing their job, enabling the "choke" ... its not a true choke, but its an addition of fuel to help the engine get hotter, faster, for emissions
DDM 55w 7k HID
Sliders
R&G Bar Ends
JPR Shorty levers
Flushmounts
fender eliminator
Pair Delete
Bazzaz AFM
tenjin is offline
