Battery Problem? Rec/Reg? - 600RR.net
post #1 of 14 (permalink) Old 05-27-2011, 10:29 PM Thread Starter
I know my battery is probably dying and I'm looking to replace it pretty soon, but hoping to get some life out of it, I charged my battery using a schumacher charger and left it for a few days. I just reinstalled the battery (in the video, it's the 2nd time starting it) and I am curious as to see if this is normal when revving...
it drops to like 4 volts and i don't think I even broke 5k rpm yet.
WingZeroX5 is offline
post #2 of 14 (permalink) Old 05-27-2011, 10:40 PM
NewRedRider's Avatar
Images: 24
No...that's not normal. Should be reading about 14.5v @ 5k rpm. What year is the bike?
NewRedRider is offline
post #3 of 14 (permalink) Old 05-27-2011, 10:56 PM Thread Starter
it's an 07
thing is, i didn't rev it all the way to 5k, it was like around 3k and it was already dancing around like that
post #4 of 14 (permalink) Old 05-27-2011, 11:28 PM
Images: 24
Well make sure the leads on the battery charger are not vibrating loose. Do you have a multimeter?
post #5 of 14 (permalink) Old 05-28-2011, 01:06 AM Thread Starter
Yeah they're tight. I dont have a multimeter at the moment, only a voltmeter.
I'm convinced it's the battery because when i picked up the bike, it died a day or two later, clickclicklickclick...then after the recharge, i tested how many start/stop cycles before the battery gave out again and it was 5. But if anyone else can shed some more light on this matter, that would be great!
Plus, it's the original battery since 07.
post #6 of 14 (permalink) Old 05-28-2011, 05:20 AM
kali_cbr600rr's Avatar
Feedback Score: 9 reviews
i have an 07 and recently had to replace mine, got the bikemaster tru gel
YouTube Channel
kali_cbr600rr - build/progress (2007 blue/silver)
4 sale: A Lot Of Stuff - Look at the "For Sale" section!!!
kali_cbr600rr is offline
post #7 of 14 (permalink) Old 05-28-2011, 09:45 AM
Nico's Avatar
That looks to be a dead r/r... your battery sounds ok though.
Nico is offline
post #8 of 14 (permalink) Old 05-28-2011, 10:26 AM
Images: 24
If you know your battery charger is connected good and your voltmeter shows the same thing then I agree with Nico. But before you go replacing things double check all your PIN connectors, main ground wires, and the battery cables. Make sure everything is corrosion free and tight. Pull the battery and have it load tested. Even if the battery is bad the R/R should be putting out @ 14.5v.
post #9 of 14 (permalink) Old 05-28-2011, 10:34 AM
Nico's Avatar
I think what is happening is that a couple of the diodes in the rr have died, when the bike is idling the rr isn't putting out to much voltage and all seems well, then as you rev it the output of the rr reduces sucking power out of the battery and reducing what the meter is seeing.
If I'm right after around 10-20 seconds at +3k rpm the rr should be quite hot to touch, maybe even enough to burn.
Nico is offline
post #10 of 14 (permalink) Old 05-29-2011, 01:08 AM Thread Starter
I tested it again today in the afternoon when all the freaking mosquitoes aren't out yet, and it seems my R/R is fine. Hahaha, I think what happened is that when I left the voltmeter on the battery, I didn't leave it secured, so it's just touching the terminals. Whenever I rev, the vibrations causes it to intermittently lose contact, thus causing a low reading like I previously posted...
So, I held the voltmeter's terminal tightly and clamped on the (+), revved to 5k, output is 14-ish (forgot the exact readings)
Where is the R/R located exactly and how do I test it?
post #11 of 14 (permalink) Old 05-29-2011, 06:50 AM
Nico's Avatar
You just did test it... 14V @ 5k is fine.
Looks like you found your problem...
Nico is offline
post #12 of 14 (permalink) Old 05-29-2011, 08:04 AM
Images: 24
No problem is a good problem! Like Nico said that's basically it. The only other thing the SM says to do is turn on your high beams while you're testing but I didn't see a big difference between high and low beam.
post #13 of 14 (permalink) Old 05-29-2011, 05:04 PM Thread Starter
Thanks guys!
Anyone know much about the Shorai lithium batteries? They seem pretty nice and has a major advantage over the old lead-acid technology. Plus it has more CCA! Since my battery is on its last legs, I'm looking into getting a Shorai lithium
post #14 of 14 (permalink) Old 05-31-2011, 03:15 AM
Nico's Avatar
Catch is even though you gain CCA, you generally lose out on the Ah when you go for a lithium battery...
Have a look at BrowningBuck's Motydesign batteries as well... they are very well priced.
Nico is offline
