No crank, no fuel pump prime. - 600RR.net
post #1 of 11 (permalink) Old 05-30-2011, 07:05 PM Thread Starter
2003 CBR 600rr.
Bike went down little over a month ago and it messed up the front end. I did the 2006 inverted fork conversion. Same 2003 harness, nothing was damaged on it.
Bike is nearly complete but now It won't crank nor will the fuel pump prime. All the fuses are good. Same ignition. Lights turn on, tail lights work, turn signals works...
Did the basics, neutral, kick stand, clutch etc etc.
Help!!
Thank you!
Inflame is offline
post #2 of 11 (permalink) Old 05-30-2011, 07:59 PM
Lifetime Premium
After doing an audi light install on my bike, I had the same problem. For me it turned out I installed the tilt sensor upside down. You may have a tilt sensor issue. If the bike thinks its down it will do exactly what u r experiancing. The tilt sensor is right above both headlights. It should look like an upside down D. This should give u an idea of what is wrong.
Midnight is offline
The Following User Says Thank You to Midnight For This Useful Post:
Inflame (06-01-2011)
post #3 of 11 (permalink) Old 05-30-2011, 09:28 PM Thread Starter
I installed it right :/ I'll bypass it to see if it's bad.
Inflame is offline
post #4 of 11 (permalink) Old 05-30-2011, 10:01 PM Thread Starter
bypassed and still nothing.
Also, no clicking from the relays.
Inflame is offline
post #5 of 11 (permalink) Old 05-31-2011, 10:31 AM
Nico's Avatar
Did you use the 06 ignition barrel?
Nico is offline
The Following User Says Thank You to Nico For This Useful Post:
post #6 of 11 (permalink) Old 05-31-2011, 04:32 PM Thread Starter
No, all electrical is from my 2003. Only that is 2006 is the inverted fork setup.
Well hmmm. I did take the lower portion of the ignition off so i could remove one of the two big bolts (it stripped)... Possibly when I put it on, I did it wrong? But the get moves to the ON position.
Inflame is offline
post #7 of 11 (permalink) Old 05-31-2011, 05:01 PM Thread Starter
Bypassed starter relay, bike started cranking. OK so that's figured out.
Now, I remember reading about swapping out fan and fuel pump relays. Where are these?
Fuel pump is getting power, I checked the connection.
Inflame is offline
post #8 of 11 (permalink) Old 05-31-2011, 05:22 PM
Find some one with a new or used start stop switch.. They're know for getting fucked up. My buddy just had the same problem with his and it was the switch..
Tim~600~r~r is offline
The Following User Says Thank You to Tim~600~r~r For This Useful Post:
post #9 of 11 (permalink) Old 06-01-2011, 07:23 AM
doofiep007's Avatar
did you check the 3pin under the gas tank or the relay?
if you have 12v and ground at the 3 pin...your pump is bad
doofiep007 is offline
The Following User Says Thank You to doofiep007 For This Useful Post:
post #10 of 11 (permalink) Old 06-01-2011, 08:31 AM
Nico's Avatar
Make sure there is power getting to the ignition for starters - 30A fuse under the seat.
All of your issues more than likely have a single root cause, and thankfully there aren't to many things that cause all of your symptoms.
Nico is offline
post #11 of 11 (permalink) Old 06-01-2011, 08:52 AM Thread Starter
DING DING DING!!!! Replaced the kill switch and BOOM everything worked again!!
Thank you everyone for the help!!!
Inflame is offline
