Battery problem - 600RR.net
post #1 of 20 (permalink) Old 06-02-2011, 06:00 PM Thread Starter
Battery problem
Hi Just bought a cbr600rr 03 and the seller told me I had to change the battery ! I changed it last week ! I never touch the bike since, and today I took it. It starts great..did a 15 minutes run and come back home... I wanted to change the clock but my buttons doesn't seem to work...so I had the idea to re-start the engine... and the battery was dead... battery is new and 15 minutes before everything was alright... can it be my anti-theft system that drain the battery ?
It has a Merlin 2000
help me... im sure it is not normal that the battery was draining like that ...
Jay337 is offline
post #2 of 20 (permalink) Old 06-02-2011, 06:01 PM
crash277's Avatar
charge it up.. disconnect the alarm, and let it sit over night then try to start it.
Originally Posted by nutcore View Post
Duct tape is like the Force, it has a light side, a dark side and it binds the universe lmao
crash277 is offline
post #3 of 20 (permalink) Old 06-02-2011, 06:04 PM
Back in the Day
Moeman's Avatar
Images: 665
Feedback Score: 148 reviews
Alarms are pron to suck battery juice and for bike batteries it would not take much to kill the battery even a short test for new Hid lights or a new set of turn signals without the engine running will drain the battery dry i would follow crash's advice and see what happens
Moeman is offline
post #4 of 20 (permalink) Old 06-02-2011, 06:16 PM Thread Starter
ok... for trying to set up my clock.. I let it at ON without the engine running during like 10 minutes... is it too much ?
and I know nothing about alarm... :(
Jay337 is offline
post #5 of 20 (permalink) Old 06-02-2011, 06:18 PM Thread Starter
and I put the old battery that I let on charge since a replaced it by the new one and it start at the frist time ! ....
so my 2 choices are .. battery get drain by something OR I let my bike on ''ON'' for changing clock too much longer !
Jay337 is offline
post #6 of 20 (permalink) Old 06-02-2011, 06:23 PM
Back in the Day
Moeman's Avatar
Images: 665
10 minutes does not seem long but its possible that the battery was not fully charged to begin with so that with the clock test might have finished it off .
Your clock might not reset if the 2 white buttons that are below the 2 rubber black push buttons have gotten loose from their mounting points within the cluster itself .
This problem was & is a common issue with the 03 to 06 RR's if nothing is blinking when the Black adjust and reset buttons are held down then what i stated above has taken place if it fixable yes it is very easy to fix
Moeman is offline
post #7 of 20 (permalink) Old 06-02-2011, 06:28 PM Thread Starter
alright thank you ! because I had the new battery in the bike since... maybe 2-3 weeks and before my 15 minutes ride , the bike starts like a charm ! .... if alarm system was drainning my battery then after 2-3 weeks of non-used it would be drain no ?
do you have a DIY for the 2 cluster bottons ?
sorry for my poor english !
Jay337 is offline
post #8 of 20 (permalink) Old 06-02-2011, 06:37 PM
Back in the Day
Moeman's Avatar
Images: 665
Do not worry about your English you are doing great so far i would not throw away the old battery get it charged up then take it to an auto parts store and ask them to load test it that will prove its either good or dead after all
As far as the cluster buttons i need to know first did you notice any blinking going on when you pushed the black rubber buttons or not ? If not then you need to remove the black buttons and tell me if you see any white buttons sticking in these holes or not ?
Moeman is offline
post #9 of 20 (permalink) Old 06-02-2011, 06:40 PM
Back in the Day
Moeman's Avatar
Images: 665
Buttons fix write up very easy to follow
https://www.600rr.net/vb/showthread.p...et+buttons+fix
Moeman is offline
post #10 of 20 (permalink) Old 06-02-2011, 08:16 PM Thread Starter
alright thank you so much moeman...i'll check this DIY !
I took a reading of my charge system... at 3 000 rpm the battery shows 13,86volt ! so my charge system is OK. after 2-3 weeks without taking it...if the alarm system was the problem... I couldn't start it ! ...so im pretty sure it was my 10 minutes ON with light without the engine running... will see ! I will waiting about my battery to get full charge !
Jay337 is offline
post #11 of 20 (permalink) Old 06-02-2011, 08:18 PM
Back in the Day
Moeman's Avatar
Images: 665
Any time man always my pleasure
Moeman is offline
post #12 of 20 (permalink) Old 06-02-2011, 08:50 PM Thread Starter
so 13,9volts is ok right ?
Jay337 is offline
post #13 of 20 (permalink) Old 06-02-2011, 09:09 PM
Back in the Day
Moeman's Avatar
Images: 665
Yes that is on the money
Moeman is offline
post #14 of 20 (permalink) Old 06-02-2011, 09:16 PM
v-tec crx's Avatar
Feedback Score: 10 reviews
Ya I say you have a short somewhere... Likely caused by the alarm
I am from CANADA, the land of poutine, back-bacon and GOOD BEER!!
2012 STREET BIKE OF THE YEAR
v-tec crx is offline
post #15 of 20 (permalink) Old 06-02-2011, 10:15 PM Thread Starter
what makes you say that?
and moeman .... I just remember something...when I change my battery... I never put a charger on it before like it was said on the sticker on the battery ! I put the battery in my bike just to make sure everything was alright and since I never put it on the charger...
Jay337 is offline
post #16 of 20 (permalink) Old 06-02-2011, 10:33 PM Thread Starter
I dont think so... because it was parked like 3 weeks and it starts like a charm... if I had a short somewhere my battery would be down....
Jay337 is offline
post #17 of 20 (permalink) Old 06-03-2011, 01:53 AM
Nico's Avatar
Not likely to be caused by the alarm...
When you left the bike on for 10 mins, you can't forget that the headlights would have been on as well - this is what drained your battery, and there is nothing surprising or abnormal about that.
Your bike is fine, your alarm is fine, your battery is fine (once it has been charged). Just remember that the headlights come on when you turn the key on.
Nico is offline
post #18 of 20 (permalink) Old 06-03-2011, 09:56 AM Thread Starter
great ! I charged my battery last night and will put it on the bike! hope it goes well ! thank you
Jay337 is offline
post #19 of 20 (permalink) Old 06-03-2011, 10:05 AM Thread Starter
could it be a bad genertor when the bike is hot ?
Jay337 is offline
post #20 of 20 (permalink) Old 06-03-2011, 06:21 PM Thread Starter
so after a 2 hours ride ! and multiple stop and start ! starting is good !... so thanks everyone !
Jay337 is offline
