Bad front bearing cause erratic front brake behavior? - 600RR.net
post #1 of 8 (permalink) Old 06-09-2011, 01:03 PM Thread Starter
Westtt80's Avatar
its a 03 600rr with 16500 miles. coming to slow stops it has a lunging effect. like the brakes will grab and let loose over and over like its throbbing. on quick stops it does the same thing but alot worse. somtimes i think i can hear a grinding noise coming from the fron but it is hard to tell because ive only had the bike 3 weeks. Any ideas? brake pads look fine i pulled the calipers yesterday.
03 CBR 600RR
Angel Eyes
Blue LED underglow
Blue LED gauges
Hot Bodies Flush Turns
Integrated Tail
Fender eliminator
Custom License plate mount
55w 10000K HID
Lowered
Yoshimura Rs-5
PC-3
Westtt80 is offline
post #2 of 8 (permalink) Old 06-09-2011, 01:07 PM
tenjin's Avatar
you just described perfectly warped rotors.
DDM 55w 7k HID
Sliders
Black Vortex Rearsets
R&G Bar Ends
Black passenger pegs
JPR Shorty levers
EK 520MVXZ black chain
Versah RJL Brake pads
Flushmounts
fender eliminator
Pair Delete
Bazzaz AFM
tenjin is offline
post #3 of 8 (permalink) Old 06-09-2011, 01:10 PM Thread Starter
Westtt80's Avatar
thank you. every one around here told me it couldnt be that. Do they just get too hot and warp? is it common?
03 CBR 600RR
Angel Eyes
Blue LED underglow
Blue LED gauges
Integrated Tail
Fender eliminator
55w 10000K HID
Lowered
Yoshimura Rs-5
PC-3
Westtt80 is offline
post #4 of 8 (permalink) Old 06-09-2011, 01:12 PM
tenjin's Avatar
who is every one? they need their heads checks
warped rotors will push the pads out, useually can be felt in the brake lever, which means no contact after the warped part is gone (the lunge) then the warp comes back, and it grabs hard again, rinse and repeat until you are stoped
DDM 55w 7k HID
Sliders
R&G Bar Ends
JPR Shorty levers
Flushmounts
fender eliminator
Pair Delete
Bazzaz AFM
tenjin is offline
post #5 of 8 (permalink) Old 06-09-2011, 01:18 PM Thread Starter
Westtt80's Avatar
i guess. and D*** these rotors are expensive
03 CBR 600RR
Angel Eyes
Blue LED underglow
Blue LED gauges
Integrated Tail
Fender eliminator
55w 10000K HID
Lowered
Yoshimura Rs-5
PC-3
Westtt80 is offline
post #6 of 8 (permalink) Old 06-09-2011, 01:27 PM
NewRedRider's Avatar
Images: 24
You can check the rotors yourself if you can get the front-end off the ground.
NewRedRider is offline
post #7 of 8 (permalink) Old 06-09-2011, 01:29 PM Thread Starter
Westtt80's Avatar
are there any easy ways to get the front end up without a stand?
03 CBR 600RR
Angel Eyes
Blue LED underglow
Blue LED gauges
Integrated Tail
Fender eliminator
55w 10000K HID
Lowered
Yoshimura Rs-5
PC-3
Westtt80 is offline
post #8 of 8 (permalink) Old 06-09-2011, 01:46 PM
Images: 24
You can use 2 good tie-down straps over a heavy beam or large tree limb. Run them under the triple-tree. All you need to do is get it high enough to spin the wheel. Use a red straw from a WD-40 can or a pencil taped to the top of a can. Put the straw or pencil up to the rotor where it barely touches and slowly rotate the wheel. If the rotors are warped you should see a gap somewhere or the straw/pencil rubbing somewhere. Check both rotors.
