Do I have an idle problem? - 600RR.net
post #1 of 21 (permalink) Old 06-17-2011, 03:23 PM Thread Starter
TribalJuju's Avatar
I tried to search this but didn't get much info.
Anyways primarily before my bike is totally warmed up, the idle seems to jump up and down around ~300 rpm at random times. I can hear the engine revving and going down with the rpm needle.
At fully warm, the idle is set around 1300 rpm. I haven't noticed any problems when riding, just when stopped. Is this normal?
03 cbr600rr
leo vince slip on
TribalJuju is offline
post #2 of 21 (permalink) Old 06-17-2011, 03:37 PM
BOTM Winner 8/12 / Super Moderator
CBR Time's Avatar
Images: 45
Feedback Score: 12 reviews
hmm, bounce around a bit not sure about that? it should rev a tad bit higher at cold start, then lower soon thereafter. 13 seems to be ok. Its prob nothing to worry about though
CBR Time is offline
post #3 of 21 (permalink) Old 06-17-2011, 04:41 PM
Bullast's Avatar
Images: 19
Feedback Score: 10 reviews
Your bike is supposed to idle at 1300 RPM +/- 100 per the manual. It sounds like your throttle bodies are VERY different in presusre. Theres a thread here somewhere on how to equalize them. I may not be using the right terminology but Ill try to track it down.
Tasha
Phatty
Super Sic
FOR SALE
05/06 OEM Body Parts (Red/Black) Price Drophttps://www.600rr.net/vb/showthread.php?t=468281
Track Day/ Race Gearhttps://www.600rr.net/vb/showthread.php?t=470449
Leupold 1" Unimounthttps://www.600rr.net/vb/showthread.p...66#post6155866
Bullast is offline
post #4 of 21 (permalink) Old 06-17-2011, 07:16 PM
NewRedRider's Avatar
Images: 24
You're probably running a little rich at idle from the Leo Vince. I have an '04 w/ a Leo Vince SO. But I also have a PCIII installed to re-tune the map.
NewRedRider is offline
post #5 of 21 (permalink) Old 06-20-2011, 05:28 AM
Nico's Avatar
Don't worry about searching for it mate, you can't balance the throttle bodies - just the starter valves...
Start by checking for vacuum leaks and spark plug condition (don't go buying new ones if its not necessary though)
Nico is offline
post #6 of 21 (permalink) Old 07-06-2011, 01:40 PM Thread Starter
TribalJuju's Avatar
uploaded a video if this helps anyone
post #7 of 21 (permalink) Old 07-06-2011, 02:58 PM
tenjin's Avatar
idle is probably a stich low, with the adjuster on the left side of the bike, turn it just a hair to the right while warm, see if you can get it to smooth out, it does not take much at all
like 1/10th of a turn, give the throttle a quick rev, let it settle down
DDM 55w 7k HID
Sliders
Black Vortex Rearsets
R&G Bar Ends
Black passenger pegs
JPR Shorty levers
EK 520MVXZ black chain
Versah RJL Brake pads
Flushmounts
fender eliminator
Pair Delete
Bazzaz AFM
tenjin is offline
post #8 of 21 (permalink) Old 07-06-2011, 03:24 PM
Lifetime Premium
SuuScbr's Avatar
Feedback Score: 9 reviews
http://www.youtube.com/watch?v=wohXmWcIW8I
nevermind, Im retarded, hahah
R.I.P. P H A T S T U D
Stickies down!!!!! GEAR UP!!!!!!!
MOTORCYCLE PIC GAME PT. 2 RESULTShttps://www.600rr.net/vb/showthread.php?t=256112
SuuScbr is offline
post #9 of 21 (permalink) Old 07-06-2011, 03:28 PM Thread Starter
TribalJuju's Avatar
Thanks for the reply.
I can usually get it to smooth out if I increase the idle speed - but that point is usually around 1500-1600 rpm. At ~200 degrees, the idle speed is set to about 1350-1400 rpm ( which is recommended I believe). What rpm would be too high?
I also have a leovince slip on, if that makes a difference.
post #10 of 21 (permalink) Old 07-06-2011, 03:32 PM
tenjin's Avatar
Originally Posted by SuuScbr View Post
wait, why is your brake on your left?
Tenjin, where is that adjuster? __________________
lol ... HURP DURP!
DDM 55w 7k HID
Sliders
R&G Bar Ends
JPR Shorty levers
Flushmounts
fender eliminator
Pair Delete
Bazzaz AFM
tenjin is offline
post #11 of 21 (permalink) Old 07-06-2011, 03:33 PM
tenjin's Avatar
if its around 1400 while above 180 degrees, you are good
also, when was the last time valve clearances were checked?
DDM 55w 7k HID
Sliders
R&G Bar Ends
JPR Shorty levers
Flushmounts
fender eliminator
Pair Delete
Bazzaz AFM
tenjin is offline
post #12 of 21 (permalink) Old 07-06-2011, 03:44 PM Thread Starter
TribalJuju's Avatar
I wish I knew... Bought the bike about 2000 miles ago. Now has 17k on the clock.
As far as I remember, it didn't do this when I first bought it either.
EDIT: When it is fully warm and at 1400 rpm, rpms move slightly. When warming up, the rpms jump more abruptly.
post #13 of 21 (permalink) Old 07-07-2011, 08:16 AM
Images: 24
Tribal,
I don't think you have any issues to worry about. The idle sounds almost identical to mine. I wouldn't mess with the idle. If you're worried about the fuel map see if you can find a dyno and have it tested w/ an A/F ratio readout. The only thing you may need is a Power Commander to correct the fuel map in the upper RPM range.
If you had checked the valve clearances you would remember.... They're probably within tolerances as these bikes rarely require shims on their first scheduled service. I checked mine at 16k and everything was good.
I suggest you insert key and have some fun!
PS. I would replace the air filter if you haven't already. They tend to clog long before their scheduled service interval.
post #14 of 21 (permalink) Old 10-20-2011, 08:28 PM
05'Scorpion's Avatar
Feedback Score: 8 reviews
my bike does this exact thing too except it happened when I installed the block off plates and removed the california emissions...any ideas?
2006 CBR 600RR - Red/Black *StreetBike*
2003 CBR 600RR - All Black *Trackbike* SOLD
Orion Pit Bike *SOLD
05' CBR 600RR - Sold/Missed
WANTED!!! 08'+ 1KRR for sale White/Red or all Black
and....OHLINS FORKS/BREMBO BRAKES!!!
PARTS FOR SALE: https://www.600rr.net/vb/showthread.php?t=204160
05'Scorpion is offline
post #15 of 21 (permalink) Old 10-20-2011, 08:36 PM
tenjin's Avatar
im going to guess because the ecu is adjusting for something its not getting
or doing
as long as it smooths out when warm, dont worry about it too much.
DDM 55w 7k HID
Sliders
R&G Bar Ends
JPR Shorty levers
Flushmounts
fender eliminator
Pair Delete
Bazzaz AFM
tenjin is offline
post #16 of 21 (permalink) Old 10-21-2011, 12:25 AM
Nico's Avatar
I would guess that its because your mixture at idle has become a little leaner because there is more oxygen available to the bike, hence the bouncing.
Nico is offline
post #17 of 21 (permalink) Old 10-21-2011, 05:59 PM
or doing
unfortunately it still does it even when it warms up, even gets hot.
Originally Posted by nico View Post
i would guess that its because your mixture at idle has become a little leaner because there is more oxygen available to the bike, hence the bouncing.
any ideas on how to fix?
Should i adjust the idle on the left of the bike or the idle screw under the tank?
post #18 of 21 (permalink) Old 10-21-2011, 06:09 PM
tenjin's Avatar
thats the ONLY thing that can be done, other than tuning the idle with a PC that can be done to adjust idle conditions...
DDM 55w 7k HID
Sliders
R&G Bar Ends
JPR Shorty levers
Flushmounts
fender eliminator
Pair Delete
Bazzaz AFM
tenjin is offline
post #19 of 21 (permalink) Old 10-21-2011, 07:13 PM
Nico's Avatar
The idle screw will adjust the rpm at idle, I think its the mixture that is out.
The other thing it could be is the timing, you can look at that with a timing light if you like.
Nico is offline
post #20 of 21 (permalink) Old 10-22-2011, 05:32 PM
I noticed when I created some back pressure (putting my hand over the exhaust) my idle evened out perfectly! It does have the cat removed as well as the california emissions crap...
post #21 of 21 (permalink) Old 10-22-2011, 07:01 PM
Nico's Avatar
That's because your hand slowed down the exhaust velocity, changing the way the cylinder scavenges, richening the mixture back up.
Nico is offline
