Cam chain noise at high rpm - 600RR.net
post #1 of 29 (permalink) Old 06-22-2011, 11:59 AM Thread Starter
my stock cam chain tensioner started going bad on my 05 with 16,000 miles. i began hearing the chain between 5-6k rpm so i replaced it with the ape tensioner. i adjusted it so it was as loose as possible, but got rid of almost all the cam chain noise between 5-6k rpm. i noticed that i have a lot of cam chain noise above 8k rpm that did not go away. i tried tightening the tensioner more but the noise is still there so i backed it off to where i had it originally set. Is this noise due to my chain stretching? or could it be something else? any help would be appreciated.
aquinas is offline
post #2 of 29 (permalink) Old 06-23-2011, 01:32 AM
how do you hear cc noise @ hi rpm?
tary preisser is offline
post #3 of 29 (permalink) Old 06-23-2011, 06:03 AM
Nico's Avatar
Could be the chain or guides, but are you sure its coming from the cam chain and not something else?
Nico is offline
post #4 of 29 (permalink) Old 06-24-2011, 03:19 AM Thread Starter
its hard to tell what the noise is with all the other engine noise and exhaust noise, but to me it sounds like the cam chain. its is not my fairings vibrating or anything loose that i know of. i have looked around for something that might be loose, but it sounds too much like cam chain noise. that clicking sound is very distinct but i have not heard of people having problems at higher rpm's. the sound is more obvious under load than if i wind out the bike slowly.
aquinas is offline
post #5 of 29 (permalink) Old 06-24-2011, 03:20 AM Thread Starter
i dont expect much but i thought someone might have had a similar problem or heard of a similar problem.
aquinas is offline
post #6 of 29 (permalink) Old 06-24-2011, 03:21 AM
tenjin's Avatar
you are POSITIVE its not wind screan ratteling... or the top of the gas tank rattling against the ECU (this is common in 05-06)
DDM 55w 7k HID
Sliders
Black Vortex Rearsets
R&G Bar Ends
Black passenger pegs
JPR Shorty levers
EK 520MVXZ black chain
Versah RJL Brake pads
Flushmounts
fender eliminator
Pair Delete
Bazzaz AFM
tenjin is offline
post #7 of 29 (permalink) Old 06-24-2011, 06:21 PM Thread Starter
its not the gas tank cover, i had that problem and put foam underneath which solved the vibration. i checked my clip-on bar ends. i just checked my windscreen too. i had the sound before i adjusted my valve clearances and after, so after taking half the bike apart and putting it back together, i know everything is tight. i have looked around quite a bit on these forums for anything else that it could possibly be. i have become very familiar with the sound of a cam chain rattling against the guides. the sound im hearing is not a plastic rattle, but rather the same type of sound i heard between 5-6k rpm before i installed the manual cam chain tensioner.
aquinas is offline
post #8 of 29 (permalink) Old 06-24-2011, 09:51 PM
Nico's Avatar
when was the last time you changed the oil?
Nico is offline
post #9 of 29 (permalink) Old 06-28-2011, 05:07 PM Thread Starter
2400 miles ago. i change it every 3000. Im pretty meticulous when it comes to maintaining my bike. ive been listening to the sound over the past couple of days and now im sure its the cam chain/guides.
aquinas is offline
post #10 of 29 (permalink) Old 06-29-2011, 03:22 AM
Nico's Avatar
That may be as a result of over-tightening the cam chain...
Only thing left is to pull her apart and have a look....
Nico is offline
post #11 of 29 (permalink) Old 07-26-2011, 10:39 AM
jbkicks's Avatar
I installed the manual cct a while back and am having similar trouble. To review, the manual cct only needs to be tightened until pressure is felt from cam chain before locking it in, correct?
Has anyone ever counted the threads on their APE manual cam chain tensioner when properly tuned? That might at least give me a reference point when adjusting mine. Thanks.
jbkicks is offline
post #12 of 29 (permalink) Old 07-27-2011, 10:43 AM
Nico's Avatar
Tighten it until you feel a slight amount of resistance then start the bike and continue tightening until the cam noise goes away.
Nico is offline
post #13 of 29 (permalink) Old 07-28-2011, 07:28 AM
jbkicks's Avatar
I have done that but still hear a vibration. The sound is not the "can of bbs" sound from the cam chain but quicker rattle that is not as loud or as high pitched. I could just be hearing things. I just rolled over 30k miles and i guess part of me is just getting paranoid about the bikes age and any maintenance i may need (that i dont know about).
jbkicks is offline
post #14 of 29 (permalink) Old 07-28-2011, 07:32 AM
Nico's Avatar
You could be hearing the oil pump drive chain, if its soft I wouldn't worry about it.
Nico is offline
post #15 of 29 (permalink) Old 08-07-2011, 11:39 PM
Feedback Score: 6 reviews
Hey guys, I've been having some rattling type noises starting around 3.5k rpm and going up till 5-6k rpm (beyond it might just be drowned out by bike noise). I haven't been able to figure out yet what it is, but from reading about the ccts it seems this might be it. I got ~50k miles on it (2003). How can I be sure it's the cct? What would it sound like? All I know is that mine sounds scary. To me it sounds like the valves are loose or something. But definitely a metallic rattle. Thanks for any help. I hope I'm not thread jacking.
Edward
edwardvdh is offline
post #16 of 29 (permalink) Old 08-08-2011, 03:38 AM
Nico's Avatar
See if you can find where the noise is coming from, if its the left hand side of the case then its probably the cam chain. After 50k miles I wouldn't be surprised.
Nico is offline
post #17 of 29 (permalink) Old 08-08-2011, 11:47 AM
You mean the right side? Thought the cct was on the right.. Thanks!
post #18 of 29 (permalink) Old 08-08-2011, 09:54 PM
jerm's Avatar
ive had the same problem on my 07 13k+ miles, took it to the shop and they told me it was the cct. so i bought one and was attempting to take off the old one but cant get to the bolt on the left hand side. was wondering if anyone knew how to and no i dont have a manual but i should get one seeing that i do all the work myself.
jerm is offline
post #19 of 29 (permalink) Old 08-08-2011, 11:12 PM
Where does one buy a new stock cct? Anywhere other than cheapcycle parts and the like? They all want like $60. Or is that as cheap as they get?...
post #20 of 29 (permalink) Old 08-09-2011, 06:40 AM
Nico's Avatar
Online parts store, local dealer... and $60 seems pretty good to me, mine cost a fair bit more than that, think it was about $90 - $100, but not 100% sure.
Nico is offline
post #21 of 29 (permalink) Old 08-09-2011, 06:40 AM
Nico's Avatar
Have a look in my sig and you will find a how to...
Nico is offline
post #22 of 29 (permalink) Old 08-09-2011, 08:49 AM
jerm's Avatar
Hey nico, I think I read your write up but the 07 is a little different. the 2 bolts that hold it on, well one of them seems impossible to get to unless you have a special tool or you take off alot of stuff.
jerm is offline
post #23 of 29 (permalink) Old 08-09-2011, 09:48 AM
Nico's Avatar
It is similar to the 03-06 but yes, its a bit of a pita as you have to lift the fuel tank to get at it...
Nico is offline
post #24 of 29 (permalink) Old 08-09-2011, 03:22 PM
jerm's Avatar
I did that already but it does not help, the coolant hose and the plastic that the wire harness runs thr ough that is attached to something is in the way.
jerm is offline
post #25 of 29 (permalink) Old 08-09-2011, 04:00 PM
Alright. Order the new cct. Thanks for the help nico. I'll certainly be using your writeup when I install it. Now just hope that's what's making the noise.
post #26 of 29 (permalink) Old 08-09-2011, 08:28 PM
jerm's Avatar
well i got mine changed out thanks to a flexible extension and the noise is gone
jerm is offline
post #27 of 29 (permalink) Old 08-21-2011, 12:23 AM
Alright!!! Got the cct changed out and all is great! Finally after who knows how many months the noise is gone! Thanks nico for the tips and anyone else for the diagnosis help!
Edward
post #28 of 29 (permalink) Old 08-21-2011, 01:04 AM
Nico's Avatar
No worries mate, glad to hear you have it sorted.
Nico is offline
post #29 of 29 (permalink) Old 04-14-2019, 05:49 PM
darko13's Avatar
I got the same problem on my 03 RR. Classic CCT rattle at 5k RPM (55 000 KM). Installed manual APE and now I got a problem. Did not overtighten it (just by hand). I still hear a little bit of rattle but the problem now is, I hear strange sound only when on load and driving above 8-14k, and when I release the throtle, I get a sound like cutting through a plastic with a machine grinder.
Is this the sound of worn out guides ? But I hear it only when driving, not when I rev it without load.
darko13 is offline
