Front wheel not spinning freely - 600RR.net
post #1 of 20 (permalink) Old 04-25-2012, 08:34 PM Thread Starter
pyadlapalli's Avatar
Today I put my bike on both (rear and front) stands. I noticed that my front wheel is not spinning freely. If I turn it by hand there is some drag and sound from the brakes and the wheel is stopping without even completing half a turn.
Is this normal? Are my brakes dragging the discs?
2009 Black CBR600RR
Jardine RT-1 Dual Exhaust
2007 Blue/Silver CBR600RR
[wrecked]
2006 Black CBR600RR [stolen]
pyadlapalli is offline
post #2 of 20 (permalink) Old 04-25-2012, 08:39 PM
CK_32's Avatar
Idk about that severe but there was a thread a little while ago and it's said that the brake rub is normal.
I'm assuming yea because wheels are heavy and don't spin too easily. Remember these aren't skateboard wheels these are machines. Mine rub bad too I hate it I hear it when in neutral coasting to a light or pushing it into my garage.
Someone with more info will probably be along shortly and tell for sure.
I'm assuming yes it's normal.
My YouTube channel.
CK_32 is offline
post #3 of 20 (permalink) Old 04-25-2012, 08:40 PM
biglen's Avatar
Images: 5
Feedback Score: 9 reviews
Make sure that the stands are not catching anything on ur front wheel. I know sometime when i put my front stand on and spin wheel the insides of the stands actually are hitting the middle of the rim causing it not to spin freely. If not that, did u take front wheel off at all for any reason? Make sure wheel is on correctly, make sure calipers are on right, and make sure forks are straight... Sometimes is forks are inverted can cause the wheel to not spin freely...
biglen is offline
post #4 of 20 (permalink) Old 04-25-2012, 08:43 PM
CK_32's Avatar
Yea and if it's ever been down or anything like that would help us to know and if anyone did front end work recently.
My YouTube channel.
CK_32 is offline
post #5 of 20 (permalink) Old 04-25-2012, 08:52 PM Thread Starter
I never removed the wheel.
Recently, it has been down. But I got it checked by the shop. They said the forks are fine. Also, when I am riding or push the bike I didn't notice any problem. I can hear the brakes rubbing when I spin the wheel. How can I check if my forks are really fine?
2009 Black CBR600RR
[wrecked]
post #6 of 20 (permalink) Old 04-25-2012, 09:12 PM
biglen's Avatar
Images: 5
Its normal for brakes to drag a bit, but the front wheel should atleast spin a few times when u give it a turn... One way to check and make sure forks are not inverted are, loosen front axle bolt, and pinch bolts, pump up and down on the handle bars a few times, then tighten pinch bolts on opposite side of front axle bolt, then tighten pinch bolts on front axle bolt side, then tighten front axle bolt. Make sure everything is torqued to specifications.
biglen is offline
The Following User Says Thank You to biglen For This Useful Post:
pyadlapalli (04-25-2012)
post #7 of 20 (permalink) Old 04-25-2012, 10:22 PM
Not to be pedantic, but the correct tightening sequence (from the manual) is:
1. axle bolt
2. right pinch bolts
3. bounce the front end to let the forks align to the axle
4. left pinch bolts
OP: while everything is loose (before tightening everything up again) see if the wheel spins freely. It should go around at least once or so before stopping. Then try again after tightening up all the bolts and see if anything changes.
Edit: Go for a few minutes ride, with minimal use of brakes. Stop, get off, and feel the rotors with your hand. They should be cool or barely warm to the touch.
checksix is offline
post #8 of 20 (permalink) Old 04-25-2012, 10:25 PM
A little drag is normal. A lot is not. If it tends to stop in the same place the rotor may be a little out-of-round. That's pretty normal, too. As with pad drag, so goes the rotor: a little is okay, a lot is not.
KeysRider3 is offline
post #9 of 20 (permalink) Old 04-25-2012, 10:46 PM
Bullast's Avatar
Images: 19
Feedback Score: 10 reviews
Take your calipers off real quick and see if it spins nice and free.
Loosen and tighten the axle and pinch bolts as described above.
Biglen,
The way to check if the forks are inverted is by the year bud. 05 was the first year.
Tasha
Phatty
Super Sic
FOR SALE
05/06 OEM Body Parts (Red/Black) Price Drophttps://www.600rr.net/vb/showthread.php?t=468281
Track Day/ Race Gearhttps://www.600rr.net/vb/showthread.php?t=470449
Leupold 1" Unimounthttps://www.600rr.net/vb/showthread.p...66#post6155866
Bullast is offline
post #10 of 20 (permalink) Old 04-26-2012, 01:35 PM
fallingbomb's Avatar
It's fine. If you are really worried you could test with the calipers pulled back.
2007 CBR600RR -- CVMA #270 -- Pictures -- Build Thread
fallingbomb is offline
post #11 of 20 (permalink) Old 04-27-2012, 01:33 AM
Royalfelix's Avatar
ur best test is what everyone is saying, pull the calipers off and spin the wheel, slight brake pad drag is normal BUT when u spin the wheel it should spin a few times not stop at half a turn thats for sure. take off calipers then spin it see what happens. hope this helps. o btw if taking off the calipers makes the wheels spin more freely, then you could have 2 of 1 things wrong a ton of rotor run out causing to much friction, "proper way is with a dial indicator to check for runout, or a symptom would be while going 50 or 60 slightly press on that front brake and see if u can feel any pulsating ( this is true on vehicles not sure if bikes are wired or pure hydraulic?) if so this means ur rotors are bad OR most likely bad calipers if they drag to much.
those who are always doing what they know, are never doing something new to learn.
Royalfelix is offline
post #12 of 20 (permalink) Old 04-27-2012, 08:14 AM
Dogman's Avatar
Also, check to ensure the spring clips for the brake pads in the caliper are in the right way. I have found they will go in two ways, but only one way is correct.
Dogman is offline
post #13 of 20 (permalink) Old 08-08-2014, 03:59 AM
runout234's Avatar
i recently put in my front tire and am having problems with the centering of the wheel. I had followed the correct procedure. When analyzing the problem it seemed like the pads are not centering on the rotors causing unnecessary rubbing. anyone have a solution to this problem?
runout234 is offline
post #14 of 20 (permalink) Old 08-08-2014, 07:32 AM
Jim Moore's Avatar
Is your wheel on backwards?
Jim Moore is offline
post #15 of 20 (permalink) Old 08-08-2014, 08:59 AM
gotama's Avatar
you know that torque spec on the front axle the 44 ft lbs that it says is needed via the manual
yeah
you can back that off to about 30 ft lbs and it will help with the stiction
also when putting on your front wheel with the axle pinch bolts loose and the axle nut loos spin the wheel and then apply the brakes
then zip tie the brake lever down and then tighten everything up
gotama is offline
The Following User Says Thank You to gotama For This Useful Post:
D1stylz (08-08-2014)
post #16 of 20 (permalink) Old 08-08-2014, 10:52 AM
Also, I'm pretty sure that on models before 2007 the left and right spacers on the front tires were different sizes and if you switched them the wheel would drag. I made this mistake on my 05 1000rr. You might want to look into that if you have an older model
RedisFaster is offline
post #17 of 20 (permalink) Old 08-09-2014, 07:13 PM
runout234's Avatar
My wheel isnt backwards. I checked the direction. I dont think that changing the torque spec would change anything since the axle is fixed to one side which only allows the wheel to rotate, not move side to side. I tried various methods such as brakes full on, push down on forks and with them off. Im still having issues with the tire not rotating freely. The only Thing that I can think of that might be my problem is that the forks some how got rotated causing the callipers to shift
post #18 of 20 (permalink) Old 08-09-2014, 07:14 PM
runout234's Avatar
Its an 09 btw
post #19 of 20 (permalink) Old 08-09-2014, 07:21 PM
dehingst's Avatar
Images: 3
It may be normal. I notice on mine if the brakes and rotors are hot there is more drag than when they're cold. A half turn seems a little much though hot or cold.
dehingst is offline
post #20 of 20 (permalink) Old 08-10-2014, 01:31 PM
runout234's Avatar
When I say they dont rotate freely, Im taking about when my front wheel is in the air. I know its suppose to drag a little from the brakes but when I rotate them it barley rotates after rotating it.
