2005 CBR600 Not starting after lowside - 600RR.net
post #1 of 24 (permalink) Old 05-01-2012, 12:05 PM Thread Starter
So I'm helping a friend try to get his bike started again after his brother low sided it. They had it taken to a dealer after the wreck to get a quote on fixing the bike, but after it took the dealer 4 months to quote them $7k, they told them no and decided to take it back themselves to try to get it going.
Well, they dropped off the bike to my house and we noticed a parts were missing. The bike dropped on the right side, but it looks like the dealer took parts off of it and didn't give everything back. It was missing the bank angle sensor, all 3 relays on the left, and random fuses in the fuse box were gone. Other small bits were missing and when we contacted the dealer about it, they said it wasn't their fault and offered to sell us all the missing parts. We said screw it and decided we'd just go buy parts elsewhere.
So far...
+ Threw in 3 new relays
+ Replaced missing fuses
+ Checked for any burnt out fuses
+ Jumped the outside wires of the BAS for now (just to bypass)
+ Charged the battery
Here's what happens when I try to start it...
+ Everything lights up
+ Fuel pump primes
+ I hear a relay click on the left
+ Only the headlight goes off when pressing the engine start
+ No clicking noise at all
It's just silent when I press the engine start, I don't hear the starter click or anything. I haven't tried push starting it yet, but will when I get the chance. I want to test the starter, but I don't know how.
Any suggestions and help would be much appreciated!
drifteratheart is offline
post #2 of 24 (permalink) Old 05-01-2012, 09:59 PM
HSPxNick's Avatar
Check the fuses and relays behind ur battery. Y'all some passive folks, I'd have spoke with the manager and district manager about the missing parts within 24 hr Upon getting the bike back
HSPxNick is offline
post #3 of 24 (permalink) Old 05-01-2012, 10:32 PM
Um, sorry to hear about that crappy situation... Have you checked the starter motor? Is it there? If it's there then it's probably not getting power. Trace it back to see what's missing/broken that's making it not get power. If it is getting power (you can check the voltage on the plug when you hit the start button), then it's safe to say your starter motor crapped out.
shwanny is offline
post #4 of 24 (permalink) Old 05-02-2012, 02:48 AM
BOTM Winner 1/13
Nuttynu's Avatar
has to be the tip over sensor in the front between the two headlights.. .if its missing . you can bypass that by splicing two of those wires together.
My Ride Report :
-Alaska,The Last Frontier
Nuttynu is offline
post #5 of 24 (permalink) Old 05-02-2012, 08:26 AM Thread Starter
Thought I checked those fuses, but I'll double check once I get home. Should I hear any sort of clicking from the relay? Well, at first the supposed service manager told us to head down and show him what parts. When we went down there he said he'll order them for us. We call a few days later and someone tells us that the guy we talked to was fired and he never ordered us any parts. Figured we would probably constantly get the run around and just didn't feel like dealing with it.
No idea where the starter motor is, could you point me in the right direction? How can I check the voltage coming from the start button?
Already got that bypassed.
post #6 of 24 (permalink) Old 05-03-2012, 06:02 AM
Nico's Avatar
Does the neutral light come on?
Is the side stand switch there and plugged in? is it down?
Is the clutch switch still there?
Have you tried pulling the clutch in to start it?
Nico is offline
post #7 of 24 (permalink) Old 05-03-2012, 08:06 AM Thread Starter
Neutral light is on.
Kick stand switch is there and plugged in. It's a green connector at the end? I've tried with it down and up.
Clutch switch is there. Brake switch is missing, but that shouldn't matter should it?
I've tried pulling the clutch in to start with no luck.
post #8 of 24 (permalink) Old 05-04-2012, 11:48 PM
Nico's Avatar
Ok...
If you look at the left hand side of the bike, just behind the seat you will find a little yellow box taped up to the harness. This is the common ground point for the bike... just make sure that none of the pins in it are burnt...
Nico is offline
post #9 of 24 (permalink) Old 05-05-2012, 09:32 PM Thread Starter
Is this the connector that you're talking about? I disconnected it from the male end. It's just hanging onto the left side of the seat? All the pins look good to me.
post #10 of 24 (permalink) Old 05-05-2012, 10:40 PM
Nico's Avatar
Yep, that's the sucker... looks good to me to. How did the other side look? The same I guess...
Well, next thing I would look at is the starter switch itself... make sure the wires are all soldered on correctly and that the contacts are all in decent condition.
Nico is offline
post #11 of 24 (permalink) Old 05-05-2012, 11:15 PM Thread Starter
Yep, other end looks good too.
Starter switch looks good too. Wires are all on and soldered in. When I press the switch, the headlight goes out as well. When I release, the headlights come back on.
post #12 of 24 (permalink) Old 05-06-2012, 12:04 AM
Nico's Avatar
Have you checked the clipon harness connector?
Nico is offline
post #13 of 24 (permalink) Old 05-06-2012, 01:23 AM Thread Starter
I'm not sure what that is lol. Happen to have a pic or something?
post #14 of 24 (permalink) Old 05-06-2012, 04:20 AM
Nico's Avatar
Follow the wiring down from the starter switch, there should be a (from memory) 9 pin connector where it joins onto the rest of the harness. I have seen that knocked loose before...
Nico is offline
post #15 of 24 (permalink) Old 05-06-2012, 12:44 PM Thread Starter
The connector close to the tank? That one is good, I reconnected it to make sure.
post #16 of 24 (permalink) Old 05-07-2012, 10:05 AM
Nico's Avatar
Well mate, essentially what you have to do is follow the power path to the starter relay and then it's ground path. Power is supplied through the start switch, the ground goes through the clutch switch, side stand switch, neutral switch and diodes.
All you have to do is find your loose connection or broken wire / part.
Do you have a service manual?
Nico is offline
post #17 of 24 (permalink) Old 05-08-2012, 12:11 PM Thread Starter
No service manual... Would you mind pointing out exactly what path I need if you have a wiring diagram of it?
post #18 of 24 (permalink) Old 05-08-2012, 12:27 PM
Nico's Avatar
Here you go mate.
Nico is offline
post #19 of 24 (permalink) Old 05-09-2012, 01:09 PM Thread Starter
Thanks. I won't be home till this weekend, so once I give that a shot, I'll update this thread with what I find.
post #20 of 24 (permalink) Old 05-09-2012, 01:47 PM
sean9721's Avatar
Not sure if this applies to you, but I think it's something to keep in mind. There could be oil in the cylinders which is keeping the motor from turning over. Take the spark plugs out and tap the starter button. Also be sure that the battery is charged up. I had this problem with mine after I lowsided.
Sent from my DROID3 using Motorcycle.com Free App
2003 CBR600RR
sean9721 is offline
post #21 of 24 (permalink) Old 05-09-2012, 06:56 PM
CorneliusRox's Avatar
I had a similar issue when my battery crapped out. It had just enough juice to power everything but not enough to even click the starter and the lights would go out, but my clock seemed to stay on. I hooked it up to my car (NOT WITH IT RUNNING!) and it all worked like brand new.
Corey - BSME
BCM, Full Arata Ti exhaust, PC3, etc...
CorneliusRox is offline
post #22 of 24 (permalink) Old 05-10-2012, 06:46 PM Thread Starter
I'll check that, I haven't tried pulling the plugs yet. He bought some new ones and asked for me to change them for him anyway. If I find oil in the cylinders, how do I get it out?
Charged the battery and also tried to jump it with no luck.
post #23 of 24 (permalink) Old 05-10-2012, 09:43 PM
sean9721's Avatar
You'll have to drop the radiator. Just unbolt it and let it hang down. I used a 3" extension, and swivel socket, and a spark plug socket to get the plugs out. Once you get them out you can either tap the starter button or you can turn the motor over by hand. Make sure you stand clear because the oil will shoot out if there is any.
Depending on your bike mileage you may want to go ahead and replace them since you will have to take them out anyway.
2003 CBR600RR
sean9721 is offline
post #24 of 24 (permalink) Old 05-13-2012, 10:09 PM Thread Starter
Thanks, I'll try it out and get back to everyone. It probably won't be till this weekend though.
