Won't start in gear, fine in neutral - 600RR.net
post #1 of 10 (permalink) Old 05-01-2012, 05:00 PM Thread Starter
EuroTrip's Avatar
I always park the bike in 1st, so I always start it up in first. Yesterday, for 2 starts I had to put it in neutral to start it. It wouldn't even turn over in first, just sat there doing nothing. After that it was fine again, started in 1st no issues. Today, went to a friend's and it was working fine, get home and grab some food then get ready to head to school when it didn't want to start in 1st again, but started fine when I put it in neutral. Of course the kickstand was up and the clutch pulled in. I've not had this problem with the bike until yesterday, and even since it's not every time, it's intermittent/random; sometimes it'll start in gear, sometimes it won't. What could be the problem? I have warranty on it, so I could take it in to the dealer, but it's my only mode of transportation, so I can't really afford to leave it with them for a long time.
EuroTrip is offline
post #2 of 10 (permalink) Old 05-01-2012, 05:02 PM
tenjin's Avatar
well, its one of two things...
your kickstand switch isn't working right
or your clutch switch isn't working right ;)
DDM 55w 7k HID
Sliders
Black Vortex Rearsets
R&G Bar Ends
Black passenger pegs
JPR Shorty levers
EK 520MVXZ black chain
Versah RJL Brake pads
Flushmounts
fender eliminator
Pair Delete
Bazzaz AFM
tenjin is offline
post #3 of 10 (permalink) Old 05-01-2012, 05:55 PM
ProWakeskater's Avatar
yep. just jump the switch. badda bing badda boom
ProWakeskater is offline
post #4 of 10 (permalink) Old 05-03-2012, 03:02 AM
but if you bypass and the dealer sees depending on the guys there it may get ugly for you the ones here dont even like slip ons...
Zack
04 Honda CBR600RR Blue D&D fender elim hid's
05 CRF50 full lot bike
06 Suzuk Ltr450 fmx ride
97 cr250 mx
05 SDG 107 Speed Mini girls pit
03 Honda 400ex girls quad
Zhaef is offline
post #5 of 10 (permalink) Old 05-03-2012, 06:11 AM
Nico's Avatar
Problem isn't with the side stand... if it was it wouldn't run at all whilst in gear.
The problem is either your clutch switch or the diode... tell the dealer to check them both, or if you have a multimeter you can.
Nico is offline
post #6 of 10 (permalink) Old 05-30-2012, 10:27 PM
BOTM Winner 2/13
jasonmaynard's Avatar
Which diode are you referring to? I'm having the same issue. I tested the clutch switch with my meter, and its working.
Here is the wire harness diagram, you referring to number 6?:
http://www.jasonmaynard.us/WireHarness-Diagram.jpg
Thanks!
-Jason
jasonmaynard is offline
post #7 of 10 (permalink) Old 05-31-2012, 05:20 AM
Nico's Avatar
Yep. That's the one mate.
Nico is offline
The Following User Says Thank You to Nico For This Useful Post:
jasonmaynard (06-01-2012)
post #8 of 10 (permalink) Old 06-01-2012, 04:52 PM
BOTM Winner 2/13
Thank you! Picked one up at lunch.. It'll be nice to get this working again!
post #9 of 10 (permalink) Old 06-01-2012, 10:56 PM
BOTM Winner 2/13
Well I replaced the diode, still won't start in gear. Any thoughts on other things to check? I see the cables from the clutch lever switch go into the turn signal/ horn assembly, was thinking of cracking this open and looking for a loose connection in it.
Any ideas appreciated. OP or Admin, if I should start my own thread, let me know.
Thanks!
post #10 of 10 (permalink) Old 06-08-2012, 03:14 AM
Nico's Avatar
Clutch switch or wiring then mate.
Nico is offline
You may post new threads
You may post replies
