blinker problem - 600RR.net
post #1 of 21 (permalink) Old 05-11-2012, 12:14 AM Thread Starter
Angry blinker problem
The bike is an 05 600rr with slip on, flushmounts(led), motodynamic IT. I am trying to figure out what is going on with my blinkers not blinking in the HUD. I know the lights are fine as they light up when I power on the bike (when the fuel pump primes and the tach tests itself). The actual blinkers on the bike do work but the right side will not flash in the HUD. This is only on the right side. Actually I take that back. This happend one time on the left side too on the way back from the gym the other day but it fixed itself before I made it home. Any idea's on what to check? I don't think its a fuse because all the lights work indicating a complete circuit.
RECAP
1. all lights on HUD are operational
2. when switching on the right blinker they (flushmount and tail) come on but the HUD does not indicate that they are on.
3. this also happened to the left side once but fixed it self before it got home.
4. i do not have any resisters that I know of
ATX_ME is offline
post #2 of 21 (permalink) Old 05-11-2012, 02:46 AM
I think youre low on blinker fluid...
Did you check the fuses or just guessed theyre ok?
Zlow28 is offline
post #3 of 21 (permalink) Old 05-11-2012, 03:30 AM
motorhead87's Avatar
Sounds like you need resistors or you have them and they are fouling up. Do you have led front and rear or just front?
Sent from my SPH-D710 using Motorcycle.com Free App
motorhead87 is offline
post #4 of 21 (permalink) Old 05-11-2012, 08:41 AM
tripage's Avatar
Feedback Score: 91 reviews
You need to replace the flasher relay. Thread on here how to do it.
http://tripageled.com/store/
Owner
Tristan Page
[email protected]
[email protected]
tripage is offline
post #5 of 21 (permalink) Old 05-11-2012, 11:55 AM Thread Starter
Zlow - LFMAO at low blinker fluid.... I'll be sure to top it off with my next oil change!!
Motor - wouldnt the light just stay solid or blink really fast if I needed resisters?
Tripage - I'll search for that thread and give it a read. That sounds like a good place to start.
ATX_ME is offline
post #6 of 21 (permalink) Old 05-11-2012, 12:55 PM Thread Starter
Update: I took off the air tube covers and had a look around for the flasher relay. I didn't see any resisters and my flushmount leds are just wire tapped to the bike leads. Are there any plug and play flasher relays or do I need to use the method from https://www.600rr.net/vb/showthread.p...=flasher+relay
ATX_ME is offline
post #7 of 21 (permalink) Old 05-11-2012, 12:57 PM
tripage's Avatar
You have to do that way, your relay is in your cluster. T
Owner
Tristan Page
[email protected]
[email protected]
tripage is offline
post #8 of 21 (permalink) Old 05-11-2012, 01:07 PM Thread Starter
Well I really didnt want to spice wires but oh well. Can you link the part I need from your website?
ATX_ME is offline
post #9 of 21 (permalink) Old 05-11-2012, 01:12 PM
tripage's Avatar
tripage is offline
The Following User Says Thank You to tripage For This Useful Post:
ATX_ME (05-11-2012)
post #10 of 21 (permalink) Old 05-11-2012, 01:28 PM Thread Starter
Order has been placed. Thank you T
ATX_ME is offline
post #11 of 21 (permalink) Old 05-21-2012, 01:16 PM Thread Starter
Today I installed the flasher relay and everything is working as it should except I still have the same problem. Im guessing I have a jacked up wire somewhere as the previous owner downed the bike. Where should I begin to look?
ATX_ME is offline
post #12 of 21 (permalink) Old 05-21-2012, 01:24 PM
tripage's Avatar
Remove front/rear signals and inspect wiring on all 4 sides. Most likely the problem is on the right side. Start with those.
Owner
Tristan Page
[email protected]
[email protected]
tripage is offline
post #13 of 21 (permalink) Old 05-21-2012, 01:31 PM Thread Starter
I know the IT is good as I wired it myslelf (more than once lol) so that eliminates that. The front LEDs look like they were wire tapped on. Could it be a bad connection there even though they still operate?
ATX_ME is offline
post #14 of 21 (permalink) Old 05-21-2012, 01:35 PM
tripage's Avatar
If the cluster isn't responding then maybe the led is bad in the cluster. If the signal is working and the cluster isn't then that will narrow down the search. T
Owner
Tristan Page
[email protected]
[email protected]
tripage is offline
post #15 of 21 (permalink) Old 05-21-2012, 01:40 PM
JloehRRs's Avatar
Feedback Score: 5 reviews
This EXACT problem happened to me and my cluster was unplugged ever so slightly. Push the plug in tight and everything went back to normal.
JloehRRs is offline
The Following User Says Thank You to JloehRRs For This Useful Post:
ATX_ME (05-21-2012)
post #16 of 21 (permalink) Old 05-21-2012, 02:02 PM Thread Starter
The orange indicators work in the cluster for both sides. I know the left side works as it functions normal (blinks when i use the turn signal). I know the right side is good as on startup that side lights up but it does not blink when the turn signal is used. Is there a way to check that connection without removing the front cowl?
ATX_ME is offline
post #17 of 21 (permalink) Old 05-21-2012, 02:09 PM
JloehRRs's Avatar
I was able to just take the windscreen off and get to the back of it. It was a really simple fix though. But seriously, every single problem you've described is exactly what my bike was doing to. Plus I have an 06 so our bikes are identical.
JloehRRs is offline
post #18 of 21 (permalink) Old 05-21-2012, 03:00 PM Thread Starter
I looked at it before I rode to the gym. I'll try that when I get home an post an update.
ATX_ME is offline
post #19 of 21 (permalink) Old 05-21-2012, 03:50 PM
JloehRRs's Avatar
Good luck!
JloehRRs is offline
post #20 of 21 (permalink) Old 05-21-2012, 03:59 PM Thread Starter
Problem solved! Thanks for all the help. I can't believe it was that connection. It wasn't even lose and didn't make any noise when I pushed on it.
ATX_ME is offline
post #21 of 21 (permalink) Old 05-21-2012, 04:39 PM
JloehRRs's Avatar
Yup. Same here. Glad it was something so simple. Ride safe!
JloehRRs is offline
