Rubbing sound from front under braking - 600RR.net
post #1 of 6 (permalink) Old 05-14-2012, 10:24 PM Thread Starter
Since my install of my tires last summer. Under hard braking I can feel a shudder in the handlebars. It sounds exactly like a bad wheel bearing on a car. When they installed my new tires, is it possible that if you over torque the front axle, if it can destroy and/or put to much pressure on the front bearings? I'm going to go get new tires installed next week at the Honda Dealership. Should I have them replace the bearings anyway? BTW it's an 09 with 10k miles on it. Thanks guys.
Mods:
Too many mods to list.
09HondaCBR is offline
post #2 of 6 (permalink) Old 05-14-2012, 10:43 PM
EP3hatch03's Avatar
Warped rotors or pads are done.
Sent from my Motorcycle iPad 2 app
I am Chris
2009 Honda CBR600RR
CCS #520
EP3hatch03 is offline
post #3 of 6 (permalink) Old 05-14-2012, 10:48 PM Thread Starter
It has been happening since the tires were replaced. It has gotten worse. Front pads still have 1.5 mm on them.
Sent from my DROID BIONIC using Motorcycle.com Free App
Mods:
post #4 of 6 (permalink) Old 05-14-2012, 11:55 PM
2BROS600CBR/RR's Avatar
1st: check your rotors and pads to check for galling or little beads of metal. I had a problem just recently when I changed a cracked but smooth/good rotor. Had a brand new rotor and pad and felt the same thing. Shutter and rubbing sound. Changed the rotor and pad and works like a dream now. May have happened when they removed the rotors and or brake system.
2BROS600CBR/RR is offline
post #5 of 6 (permalink) Old 05-14-2012, 11:57 PM
You would have to really torque down the axle bar to cause that much damage. They should have known if that happened and if they are reputable and should have used a torque wrench which wouldnt allow that to happen.
post #6 of 6 (permalink) Old 05-15-2012, 07:21 PM Thread Starter
I went ahead and replaced the front pads with OEM Honda pads. After about ten stops. I haven't been able to get it to happen.
Mods:
