RPM Needle going crazy - 600RR.net
post #1 of 4 (permalink) Old 05-29-2012, 02:29 PM Thread Starter
KGraska's Avatar
So the other day this started, when the bike starts up the cluster does its thing and needle goes up and down fine as usual. When riding its going ok until I accelerate real hard and the needle starts jumping until it goes all the way around and then moves a little.
When I shut the bike off and on the needle goes back to 0 and it works again til I give it some throttle again.
I have done gauge LEDs but they have been done for awhile and this just started.
Anyone got any ideas?
05 600RR - Matte White
-Driven 520 -1/+2
-RK GXW Black Chain
-Leo Vince Carbon Fiber Slip-On
-ASV F3 Levers
-Driven D3 Grips
-Driven D-Axis Spools
-Driven V2 Bar Ends
-Speedo DRD
-Morimoto Mini H1 Bi-Xenon Projectors
-Amsoil Full Synthetic
KGraska is offline
post #2 of 4 (permalink) Old 05-29-2012, 03:00 PM
SeanO's Avatar
Images: 2
Yes. Most likely one or two of your 4 solder joints for the RPM motor on the circuit board are bad. When the bike is sitting idle there is a connection. The vibrations that you cause from accelerating will cause the connection to move around. I am almost 100% sure since you have done the gauge mod that this is your issue. Make sure you heat up both surfaces so that you get a clean and strong solder joint.
White 07 CBR600rr
SeanO is offline
The Following User Says Thank You to SeanO For This Useful Post:
KGraska (06-02-2012)
post #3 of 4 (permalink) Old 05-29-2012, 07:11 PM Thread Starter
KGraska's Avatar
Thanks. I will tear it apart sometime this week and find out if that helps. Appreciate the response
-Driven 520 -1/+2
-RK GXW Black Chain
-ASV F3 Levers
-Driven D3 Grips
-Driven V2 Bar Ends
-Speedo DRD
KGraska is offline
post #4 of 4 (permalink) Old 05-29-2012, 07:36 PM
Definitely sounds like a loose connection. Those symptoms also occur on the cable driven tachs when one end, or both, aren't fully coupled.
KeysRider3 is offline
You may post new threads
You may post replies
