Starting problems - 600RR.net
post #1 of 5 (permalink) Old 06-04-2012, 09:30 PM Thread Starter
Starting problems
hey guys, I have an 02 cbr600 f4i and it fired up no problem 2 days ago, now it wont start, i checked all my fuses, the BAS is in correctly, i pulled the plugs and they have spark, (may replace them anyways since it is apart) i have not tried to put it back together and start it yet. is there anything else i should check? oh the battery is brand new as well. the fuel pump primes when i turn it on. my friend said change the plugs, put it back together and try it, then if it doesnt work check the electrical stuff. am i on the right path or is there something i missed?
decomaryan is offline
post #2 of 5 (permalink) Old 06-04-2012, 09:31 PM
Bridge_Jumper's Avatar
Feedback Score: 5 reviews
check your battery terminal connections. sometimes they are just loose enough they can cause something to not start
Bridge_Jumper is offline
post #3 of 5 (permalink) Old 06-04-2012, 10:28 PM
Str8_Lurkin's Avatar
Feedback Score: 19 reviews
plugs should be fine... check ya battery for ample cranking voltage.
Is the gauge lighting when you turn the key?
<<Click HERE>>
Check out my NEW & Upcoming Company.
Producing and designing gear that you, the rider actually want.
Click HERE
f/s 03 trackbike, sharkskins , chrome rear
& MORE
03rr -FOR SALE
06yzf r6
- NEW
Str8_Lurkin is offline
post #4 of 5 (permalink) Old 06-05-2012, 03:01 AM Thread Starter
Gauges light, fuel pump makes some noise.. all the normal stuff.
post #5 of 5 (permalink) Old 06-05-2012, 09:25 AM
okay when you press the start button what happens?
I if you hear the relay click when you press the button then I would turn and check the voltage in the battery. And even disassemble the start button switch and give it a good cleaning.
When you say brand new battery... did you charge it properly as instructed in the manual?
If you did not properly charge it then that is the issue.
<<Click HERE>>
Click HERE
& MORE
03rr -FOR SALE
06yzf r6
- NEW
