Rear Brake Problems! :( With pictures :D - 600RR.net
post #1 of 13 (permalink) Old 06-17-2012, 05:04 PM Thread Starter
Ok friends.
First off my rear brake reservoir was replaced with some sort of tube. This is fine and dandy but there's no fluid in it and it's because the stupid thing leaks. So I am still learning basic things about cars and bikes and have no idea what to do here. Is there a way to tighten the clamp around the hose? Also how do I bleed these without a brake bleeder? Is that even what I have to do as there is no brake fluid in there! Its most likely just filled with air. :((
jellies is offline
post #2 of 13 (permalink) Old 06-17-2012, 05:08 PM
Brew88's Avatar
You might want to read this thread, It'll explain the reasoning behind why this has been done.
https://www.600rr.net/vb/showthread.php?t=132170
Brew88 is offline
The Following User Says Thank You to Brew88 For This Useful Post:
jellies (06-17-2012)
post #3 of 13 (permalink) Old 06-17-2012, 05:49 PM
BOTM Winner 07/12
03WisconsinRR's Avatar
Images: 8
Feedback Score: 17 reviews
As stated in the thread above. Make sure its the right tubing otherwise it will sweat fluid until its empty. You can find the right stuff at Kurvy Girl or on McMaster Carr.
Clamp that tube on as tight as you can, fill the hose with a small funnel and bleed it through the caliper.
08'RR
Akra Evo TI - Bazzaz ZfiTc - Acumen Gear Indicator - Yoyo Stay - Keyless Mod - Michelin Power Cup - HRC overflow - ECUnleashed
Yoyo Slipper - Galfer Lines - HRC Rear Res - HRC Throttle - Woodcraft Sliders - Woodcraft Rearsets - Servo Mod - Samco Hoses
BMC - Hotbodies - Brembo RCS19 - Penske 8987 & 20mm Valving - ASV Levers - Rk 520 - GPR Damper - EBC XC Rotors
Woodcraft Clipons - Gilles Chain Adjuster - R&R Subframe - PAIR Mod - Cox Rad Guard - MOYT 4 cell - Factory Pro Shift Star
03WisconsinRR is offline
post #4 of 13 (permalink) Old 06-17-2012, 05:59 PM Thread Starter
I tightened the hose clamp. It was sort of lose so now I think it wont leak. (It was leaking out of the bottom) I put fluid in the hose and it doesn't flow through. Does that mean there is air trapped in the caliper.
jellies is offline
post #5 of 13 (permalink) Old 06-17-2012, 06:09 PM
BOTM Winner 07/12
Images: 8
I would bleed it if the tube was empty
08'RR
post #6 of 13 (permalink) Old 06-17-2012, 06:14 PM Thread Starter
Is there a way to bleed it without the bleeding tool?
jellies is offline
post #7 of 13 (permalink) Old 06-17-2012, 06:23 PM
BOTM Winner 07/12
Images: 8
You dont need a tool to bleed it.
Either stick a small piece of tube over the bleeder of the rear caliper or wrap some paper towel around it if your real hard up.
Open the bleeder and push on the pedel.
Close the bleeder tight then release the pedel.
Repeat until the fluid comes out smooth without any air or bubbles. Replace fluid as you go so you dont run air back into the lines.
08'RR
The Following User Says Thank You to 03WisconsinRR For This Useful Post:
post #8 of 13 (permalink) Old 06-17-2012, 06:33 PM
X-treme1's Avatar
Feedback Score: 5 reviews
PM me if you want to go back to stock. I just did a different reservoir delete and I have a reservoir and tube I was thinking about selling. It's off a 2010.
Sent from somewhere down the bayou.
You start the game with a full pot of luck and an empty pot of experience. The object is to fill the pot of experience before you empty the pot of luck.
2010 Leyla
X-treme1 is offline
post #9 of 13 (permalink) Old 06-17-2012, 07:12 PM Thread Starter
If this is still leaking I will pm you about that reservoir! And thanks to all of you that helped. I bled them with paper towels and my sisters help so I will see if they work in a couple minutes!
jellies is offline
post #10 of 13 (permalink) Old 06-17-2012, 07:16 PM
Neptune's Avatar
You just remove the rubber cover and loosen the nut.
Drift Camera Forum - http://driftcamforum.com/
Neptune is offline
post #11 of 13 (permalink) Old 06-17-2012, 07:22 PM
Neptune's Avatar
Whoa totally late
Neptune is offline
post #12 of 13 (permalink) Old 06-17-2012, 07:22 PM Thread Starter
I know I am retarded. I didn't see the nut. I got it and they work now! A really simple problem that I blew up in my head. Lol. for 600rr.net and the great community.
jellies is offline
post #13 of 13 (permalink) Old 06-17-2012, 07:25 PM
X-treme1's Avatar
Just keep an eye on the level in the tube. It will drop as the brakes wear; don't let it go down too far.
2010 Leyla
X-treme1 is offline
