Installed PCV now fuel pump wont prime - 600RR.net
post #1 of 10 (permalink) Old 06-18-2012, 12:19 PM Thread Starter
I can hear the relay tick but that's it. Its a 2011 CBR600RR. It will turn over but wont start. With everything turned off. I turn the key to on. The flip the kill switch and normally hear the fuel pump prime. All I hear is the relay tick by the fuse box. All fuses are good, all connections are good. I did plug into the fuel injectors up under the gas tank not the ones on top of the air box. So I did remove the entire fuel tank. Any thoughts or advice?
Sent from my DROIDX using Motorcycle.com Free App
thewakka1 is offline
post #2 of 10 (permalink) Old 06-18-2012, 12:43 PM
BOTM Winner 07/12
03WisconsinRR's Avatar
Images: 8
Feedback Score: 17 reviews
Make sure the PC is getting power and the lights are on.
08'RR
Akra Evo TI - Bazzaz ZfiTc - Acumen Gear Indicator - Yoyo Stay - Keyless Mod - Michelin Power Cup - HRC overflow - ECUnleashed
Yoyo Slipper - Galfer Lines - HRC Rear Res - HRC Throttle - Woodcraft Sliders - Woodcraft Rearsets - Servo Mod - Samco Hoses
BMC - Hotbodies - Brembo RCS19 - Penske 8987 & 20mm Valving - ASV Levers - Rk 520 - GPR Damper - EBC XC Rotors
Woodcraft Clipons - Gilles Chain Adjuster - R&R Subframe - PAIR Mod - Cox Rad Guard - MOYT 4 cell - Factory Pro Shift Star
03WisconsinRR is offline
post #3 of 10 (permalink) Old 06-18-2012, 01:57 PM Thread Starter
Were does the pc get power from?
post #4 of 10 (permalink) Old 06-18-2012, 02:04 PM
BOTM Winner 07/12
Images: 8
Dont quote me but I think the PC gets power from one or more of the piggy back plugs, like the injector plugs. The Bazzaz still splices into a wire to get power/signal.
08'RR
post #5 of 10 (permalink) Old 06-18-2012, 02:46 PM Thread Starter
I will check for lights on it when I get home. There wasn't a power wire. It must get it from the injector or TPS. But why would any of the keep the fuel pump from priming?
post #6 of 10 (permalink) Old 06-18-2012, 02:54 PM
BOTM Winner 07/12
Images: 8
That happened with my bazzaz. The splice for power was so-so and every once in a while it would not signal.
08'RR
post #7 of 10 (permalink) Old 06-18-2012, 03:05 PM
Lifetime Premium
BLACK ICE RR's Avatar
I am having this same problem PCV does not have power light on.
2005 CBR 600RR Tribal
Pinebox custom exhaust + header
PCv + pair mod
Ape CCT
Vortex Clip-ons
MOTY battery
ZG DB
Milled rear rotor
55w HIDs
Rear res delete mod
flush mounts, frame sliders
Get outta here troll!
BLACK ICE RR is offline
post #8 of 10 (permalink) Old 06-18-2012, 03:22 PM
Joe81's Avatar
Re-check all of your connections, check your fuses.. It may be a bad pcv...
Joe81 is offline
post #9 of 10 (permalink) Old 06-18-2012, 09:45 PM Thread Starter
It turned out to be a bad ground, I believe. I replaced the connecters for the grounds and it started right up. All in all it took about 3 hours of work to install the PCV with the IRC. Man what a difference. Thanks for the all the quick replies. Next up will be the headers and auto tune.
post #10 of 10 (permalink) Old 06-22-2012, 07:23 PM
Lifetime Premium
Glad you got it figured out. Mine turned out to be gunk built up in killswitch. Symptoms were: starter worked, no lights on PCV, no fuel delivery. Checked relays, checked grounds. Hope this helps other people. It was an easy thing to check and an easy fix.
PCv + pair mod
Ape CCT
Vortex Clip-ons
MOTY battery
ZG DB
Milled rear rotor
55w HIDs
Rear res delete mod
