600rr Engine Noise - 600RR.net
post #1 of 4 (permalink) Old 09-12-2012, 03:28 PM Thread Starter
Mhjiha's Avatar
600rr Engine Noise
Hello folks,
I just Got this new baby 2003 600rr 7 days ago with 25 000km on it and Sunday I went out with a bunch of ppl to Mont-Tremblant (on curvy roads) and beat it a little bit without abusing or over revving.
Everything was fine!
Few Hours later after coming back home more than 200km, I went out again with the bike and after another 100km while doing over 100kph on the highway the engine started doing this noise (view YouTube link)and got louder so I took a towing and brought it back home. Total Km I put on the bike? less than 600km.
I checked the oil level and it's OK.
I read a bit on this forum and it seems to be cct (cam chain tensioner)
I removed it but it doesn't seem to be it (visually it looks fine) and the noise is coming from the top of the engine.
Yesterday, a mechanic told me its the engine that needs to be changed...
this is the YouTube link:
I really don't know what to do.
Any help would be greatly appreciated.
Mhjiha is offline
post #2 of 4 (permalink) Old 10-08-2012, 07:11 PM
Dont start it before fixing, the more the engine runs, the more it gets ruinned.
It seems like a valve is hitting a piston, but only checking can confirm it.
Was the tensioner touched before? If it was too loose the chain could have jumped and the engine gets out of its points.
Get another mechanic or a friend who knows about engines to have a look at the distribution chain and points.
Sorry for my messy english.
FerreiraAveiro is offline
post #3 of 4 (permalink) Old 10-08-2012, 07:21 PM
murphdog1411's Avatar
Images: 94
shut the thing off!!!!!!!
now that you have dont that, you are going to have to teardown and inspect timing and valvetrain, or replace the engine, that sounds like valves hitting the pistons caused by a jump in timing. keeps us posted.
murphdog1411 is offline
post #4 of 4 (permalink) Old 10-08-2012, 07:47 PM
OveRReV's Avatar
Images: 16
that thing is fkd, it could be any of these, the engine spun a rod bearing & now the piston is hitting the cylinder head, the cam chain went loose & the cam timing got out of sync & now the valves are hitting the piston.
i would check the camshaft timing first to see if the marks are aligned with the crankshaft timing mark, if that is good then your next problem is the rod bearing, try draining the oil & see if its got any metal shavings, if it has then your engine is truly fkd & will need a full rebuild.
i now use an APE manual cam chain tensioner to prevent the chain going loose, just do regular checks & adjust the tension if the cam chain becomes noisy, i adjust mine little by little until i hear no more ticking.
2003 CBR 600RR JDM
HRC ECU AMA spec
HRC radiator
WP 4618 rear shock
WP 1508 steering damper
Ohlins 9.0N fork springs
Overrev tuned fork cartridges
Akrapovic Evo Carbon FS
Dynojet PCV WB2 POD300
BMC race air filter
AFAM 15/47 sprockets
DID VX2 520 gold chain
Brembo 19RCS MC
HEL brakelines
HM Plus quickshifter
EVR CTS slipper clutch
BST CF wheels
OveRReV is offline
