Rattling twisting metal sound noise - 600RR.net
post #1 of 5 (permalink) Old 09-27-2012, 02:29 AM Thread Starter
Jude20's Avatar
Hey!
Quick question. I've got this rattling, twisty metal kind of noise coming what seems from my left side when I'm on my bike. If I could pin point any area almost right under my knee. Took it to a local shop and he guessed Cam Chain Tensioner. Idk if that's right cause isn't that on the right side?
Idk. Chain maybe? Plugs? Doesn't effect bikes performance at all. Running strong. With ear plugs its unnoticeable, and it seems to lighten up once the bike warms up.
It's a 2006 13k with the last oil change done about 1500 miles ago. Full synthetic.
Sent from my iPad using Motorcycle
Jude20 is offline
post #2 of 5 (permalink) Old 09-28-2012, 01:20 PM
Plugs won't make a noise like that.
Unless you've got an overly tight engine then a noise like that is odd.
CCTs will cause a clattering noise rather than a "twisty metal noise".
Can you clarify the noise a little bit?
'06 in Silver: 29K on the clock (and counting)
PCIII w/custom tune (stock AF and shortie stacks)
320mm rotors with SBK5 pads, Galfer HH rear
Full f/r FenTubo Type 2 set black on black
Nissin Radial M/C (07+)
wrapped in Mich Power Pures (aka love)
oldschooldesigns is offline
post #3 of 5 (permalink) Old 09-28-2012, 01:34 PM
DrCheeser's Avatar
Maybe you're just lucky... people spend a lot of money on harleys to get the same noise...
DrCheeser is offline
post #4 of 5 (permalink) Old 09-28-2012, 01:40 PM
Lifetime Premium
SuuScbr's Avatar
Feedback Score: 9 reviews
Originally Posted by Jude20 View Post
Hey!
A CCT will not make this sound at idle, it will start around 4-6K, and it sounds like to metal disc spinning in each other and slightly touching I guess it could be described as twisting metal,
if its at idle, check the oil level, if its at that range of RPMs it could be the CCT get a stock one so you wont have to worry about adjusting, you could ruin your motor if tightened to much,
if you can post a video of the sound, that will help
R.I.P. P H A T S T U D
Stickies down!!!!! GEAR UP!!!!!!!
MOTORCYCLE PIC GAME PT. 2 RESULTShttps://www.600rr.net/vb/showthread.php?t=256112
SuuScbr is offline
post #5 of 5 (permalink) Old 09-28-2012, 02:09 PM
Do you have an aftermarket exhaust? Did you touch the EGCV?
The previous owners of my bike had tampered with the EGCV and after a while it got loose and was rattling.
Maybe something to check?
kuja1120 is offline
