coolant leak from water pump hose. - 600RR.net
post #1 of 7 (permalink) Old 09-29-2012, 04:12 PM Thread Starter
its.meee's Avatar
my bike has been leaking coolant on the left side, i looked at it and there is dried up coolant all over a hose from the water pump, i took the hose off and doesnt seem to have any cracks or anything. also the clasp isnt loose or broken at all. any ideas what it could be?
also it is not a gasket either because you can see that the leak is from the hose connected to the water pump but everything checks out.
its.meee is offline
post #2 of 7 (permalink) Old 09-29-2012, 04:28 PM
harry-nyc's Avatar
Feedback Score: 10 reviews
Try running it in your driveway and see where it's coming from. I definitely wouldn't ride it until you solve the issue, your rear wheel may slip and cause an accident. Throw up some pics if you got a chance.
harry-nyc is offline
post #3 of 7 (permalink) Old 09-29-2012, 05:37 PM Thread Starter
its.meee's Avatar
its not a crazy leak, it just gets on the side of my bike. although i didnt see any cracks in the hose, i changed it. ill see how this holds up and if it doesnt help ill deff post some pics
its.meee is offline
post #4 of 7 (permalink) Old 09-29-2012, 07:39 PM
speeddeamon88's Avatar
get a new hose for sure. It will never stop leaking from it untill you do so
MachineGunMyers - Xbox gamertag
The X's #1 Fan™
speeddeamon88 is offline
post #5 of 7 (permalink) Old 09-30-2012, 08:11 PM Thread Starter
its.meee's Avatar
okay so i changed the hose the leak was coming from and i leave all my fairings off with my bike on the stand. i went out to the garage today and saw this...
gasket?! any ideas?
its.meee is offline
post #6 of 7 (permalink) Old 09-30-2012, 08:53 PM
White RepsoL's Avatar
Do a search on wet side seal or mechanical seal...
White RepsoL is offline
post #7 of 7 (permalink) Old 10-03-2012, 02:20 PM
dreze1's Avatar
Look here: https://www.600rr.net/vb/showthread.php?t=104212
Check under the water pump for a weep hole. It's a small hole that lets coolant flow out when the seal goes bad. Better than pumping it into the crankcase. It will leak from there but then flow down other stuff, making you think it's the hoses.
2006 Red CBR 600RR
dreze1 is offline
