Fuel pressure in gas tank - 600RR.net
post #1 of 18 (permalink) Old 10-24-2012, 03:29 PM Thread Starter
underoath1122's Avatar
So when I open gas cap to get gas. It flys open with tons of pressure behind it. I tried to locate the pressure escape tube but can't. I did find the over flow tube. Any help would be great. The pressure inside my tank is not escaping. Could be due to a crimped tube. Or no tube at all
Sent from my iPad using MO Free
92 cbr 600 f2 SOLD :(
03 cbr 600 rr
underoath1122 is offline
post #2 of 18 (permalink) Old 10-24-2012, 10:27 PM
nurdie's Avatar
I thought that the gas cap itself acts as a pressure valve, but I could be mistaken
The avatar is my other ride.
nurdie is offline
post #3 of 18 (permalink) Old 10-24-2012, 10:32 PM
tricolour 600
Posts: n/a
There should be 2 tubes coming off the bottom of your tank, ones the overflow, the other the breather. you need to remove the fairings and lift the tank to access them. That should help narrow down the problem.
post #4 of 18 (permalink) Old 10-24-2012, 10:53 PM
ChrisR.Conley's Avatar
Get it taken care of ASAP, because this can be a huge problem. My tank had the opposite problem. The tank had a vacuum after the fuel was pulled out by the pump and it eventually cracked and leaked. A brand new tank is over 500 plus install.
ChrisR.Conley is offline
post #5 of 18 (permalink) Old 10-24-2012, 11:47 PM
search, as there are multiple threads on this.
also dangerous, and can damage bike.
do not run it until you have done a troubleshoot + correct.
tary preisser is offline
post #6 of 18 (permalink) Old 10-25-2012, 10:24 PM Thread Starter
I found only a one way tube. I blew air into it. It seemed to help a oil. Not as much pressure coming from it but it still builds up enough to where it noticeable
03 cbr 600 rr
post #7 of 18 (permalink) Old 10-26-2012, 12:12 AM
get deeper into it... there IS a problem with your tank vents...
s/b one for suction (from the fuel pump) and one for positive pressure off the tank....
(ex. 3 tubes off the bottom of my 09's tank)
1. fuel feed off the pump.
2. overfill/+psi.vent.
3. and tank vent for pump out.
note #2+3 do have one way valves and #2 is possibly blocked.
vital that all 3 are not pinched!.
thats all I got.
GL
post #8 of 18 (permalink) Old 03-06-2013, 04:53 PM
rlee350's Avatar
have the same issue. i checked all the hoses and made sure that the hose that goes to the kick stand isn't kinked. did anyone find the resolution to this problem?
rlee350 is offline
post #9 of 18 (permalink) Old 04-08-2013, 07:45 PM
dsid's Avatar
Guys, I am not sure if my problem is the same as above but everytime i open the gas cap to get gas, I feel like the tank is releasing a little bit of air out. Its not high pressure. Its a quick release of little bit of air. What do you guys think? Is that normal? Thanks for your help.
dsid is offline
post #10 of 18 (permalink) Old 04-08-2013, 08:24 PM
speeddeamon88's Avatar
if its hot outside like 85-90+. and a very minimal minimal amount of pressure.
MachineGunMyers - Xbox gamertag
The X's #1 Fan™
speeddeamon88 is offline
post #11 of 18 (permalink) Old 04-08-2013, 08:46 PM
dsid's Avatar
Thanks. I'll make a video and post it. Hopefully that will clear things out.
Also its not hot outside right now. its only 15C.
dsid is offline
post #12 of 18 (permalink) Old 04-08-2013, 10:18 PM
dsid's Avatar
Guys. I made a video. Check it out. Please let me know what you think. Thanks.
2007 CBR600RR Konica Minolta (blue/white)
dsid is offline
post #13 of 18 (permalink) Old 04-09-2013, 04:00 AM
dsid's Avatar
I dont think the video got embedded right. Here's a link if you cant open it:
some more information for you guys:
The gas cap opens and closes easily. The pressure hasn't increased over the last month. Gas doesn't get splashed out out anything. Its just air pressure.
As i research more about it, i am starting to get worried. Some say its ok, others say it could be a constricted hose underneath the tank.
Thanks and I appreciate your help.
dsid is offline
post #14 of 18 (permalink) Old 04-09-2013, 09:54 AM
sounds a lot more than mine. i usually have to push mine down slightly to get the latch to release
The X's #1 Fan™
post #15 of 18 (permalink) Old 04-09-2013, 11:18 AM
dsid's Avatar
The gas cap opens without any problem though.
dsid is offline
post #16 of 18 (permalink) Old 04-09-2013, 05:58 PM
dsid's Avatar
Any other suggestions/ideas? Thanks
dsid is offline
post #17 of 18 (permalink) Old 04-09-2013, 06:02 PM
I wish my gas cap opened like that. I always fight with it to get it opened due to the corrosion build up.
Cripton805 is offline
post #18 of 18 (permalink) Old 04-09-2013, 06:42 PM
dsid's Avatar
I should add that I just got the tank taken out and treated for rust. Is it possible that the new coating could be blocking anything?
dsid is offline
