my engine stalls when its warm - 600RR.net
post #1 of 8 (permalink) Old 12-18-2012, 01:46 AM Thread Starter
Nick41324's Avatar
I just got a 2003 600rr and every time it gets warm (210-220 F), the rpm tends to slowly decrease in like a 3 second period (while at a complete stop in first gear), it putters, then shuts off/stalls. Every time this happens the oil light comes on. I am going to change the oil/filter tomorrow with gtx 10-40 I think.
I can start the bike when it does this with the throttle pulled back slightly, but as soon as I let off the gas it begins to putter and stall again.
Edit: I felt the clutch cover and its quite warm when it does this.
Nick41324 is offline
post #2 of 8 (permalink) Old 12-18-2012, 02:26 AM
Just to clarify: Are you saying the oil light comes on prior to stalling out or afterwards?
If it is lighting up after it stalls out, don't sweat it - that's similar to the light coming on when you turn the ignition to the "on" position prior to cranking the bike over.
COBRA90GT is offline
post #3 of 8 (permalink) Old 12-18-2012, 01:39 PM Thread Starter
Nick41324's Avatar
Right as the rpm slowly starts to fade, the oil light comes on. It also comes on when the bike is cold. In the time period that it is at around 175-210F it goes off, then reappears once the rpm slows down to a stop.
I will probably take it down to a Honda motorcycle dealer if this still happens, once I change the oil/filter.
post #4 of 8 (permalink) Old 12-18-2012, 01:42 PM
tenjin's Avatar
this indicates a problem
the oil like is a pressure sensor ... if its not getting full pressure untill its warmed way up, you have an issue
it should be off within a second or two of the motor running (and having built up pressure)
DDM 55w 7k HID
Sliders
Black Vortex Rearsets
R&G Bar Ends
Black passenger pegs
JPR Shorty levers
EK 520MVXZ black chain
Versah RJL Brake pads
Flushmounts
fender eliminator
Pair Delete
Bazzaz AFM
tenjin is offline
The Following User Says Thank You to tenjin For This Useful Post:
Nick41324 (12-19-2012)
post #5 of 8 (permalink) Old 12-18-2012, 02:36 PM
MikeyP's Avatar
Feedback Score: 10 reviews
Sounds like your water pump is bad.
2008 CBR 600RR #1 (Graffiti) street
2008 CBR 600RR #2 track
CMRA #599
Originally Posted by MikeyP View Post
Unfortunately bikes fall over. It's in their nature.
It's our job to keep them upright, but we are only men.
MikeyP is offline
The Following User Says Thank You to MikeyP For This Useful Post:
post #6 of 8 (permalink) Old 12-19-2012, 12:45 AM Thread Starter
Nick41324's Avatar
What do you think is wrong with it?
Old 12-19-2012, 09:08 AM
brmoore
This message has been deleted by Moeman. Reason: Spam and/or unwanted content
post #7 of 8 (permalink) Old 12-19-2012, 12:43 PM Thread Starter
Nick41324's Avatar
Originally Posted by brmoore View Post
at 212F your fan should kick in as well, does that happen? its getting hot but the fan alone should have a massive effect on the RR's, also cooling system as pointed out above
Yea, when it stalls the fans remain running, but the engine shuts down.
post #8 of 8 (permalink) Old 12-19-2012, 01:30 PM
MikeyP's Avatar
Oil light is coming on because of the stall. It has nothing to do with your oil.
If your engine stalls when hot, and your fan is coming on, it's the water pump.
...assuming your battery is good.
CMRA #599
MikeyP is offline
