04 fuel pump wont prime fuel cut off relay won't click - 600RR.net
post #1 of 9 (permalink) Old 01-08-2013, 04:30 AM Thread Starter
I'll start By saying, IV research this for 3 days with no luck......
I have an 04 cbr I did a motor swap on it, it ran fine after I finished. I replaced the cam chain tensioner ,it started after that to. I parked it in my apartment for a wile then went to take her out. As I was taking her out I sliped and she fel,not hard tho. Went to start and no fuel pump prime ..
I checked the run stop switch and its fine I checked all the relays they all Work but only the run stop clicks.. I bypassed the fuel cut off relay and my fuel pump primed, I looked for broken or disconnect wires could not fined anything . The 20 fuse by main fuse was poped I replaced it and still nothing,no idea why It poped .... Ichecked. The bank angle and it is working ialso bypassed it and nothing...the run stop relay works but for some reason its not powering fuel cut off..I'm so lost and need help...
ANTHONYSOTO21 is offline
post #2 of 9 (permalink) Old 01-08-2013, 08:28 AM
venomenon83's Avatar
Images: 5
Feedback Score: 9 reviews
That sucks bro, hmmm try unplug the connector that goes to the speedometer/cluster. I had the same problem where the fuel pump won't prime too (not the part where I swapped engine our dropped the bike though, our was just that my fuel pump won't prime), I tried unplugging and plugging everything possible but no luck UNTIL I unplug the plug connector thet goes to the cluster. Although I did't swap engine etc , I think its worth a try though. GL bro.
venomenon83 is offline
post #3 of 9 (permalink) Old 01-08-2013, 09:33 AM
Str8_Lurkin's Avatar
Feedback Score: 19 reviews
Check for a loose wire. Or better yet if it fell on its left side then the grounds may have been snashed.
<<Click HERE>>
Check out my NEW & Upcoming Company.
Producing and designing gear that you, the rider actually want.
Click HERE
f/s 03 trackbike, sharkskins , chrome rear
& MORE
03rr -FOR SALE
06yzf r6
- NEW
Str8_Lurkin is offline
post #4 of 9 (permalink) Old 01-08-2013, 01:57 PM Thread Starter
I'll try the cluster right now, and it fell on the right side not left!
post #5 of 9 (permalink) Old 01-08-2013, 02:01 PM Thread Starter
So I did the cluster ans still nothing ....do you guys think it needs to be reset beacuse I droped it?? And if so how is that done???
post #6 of 9 (permalink) Old 01-08-2013, 02:05 PM Thread Starter
Another thing when I tested the zener diode or whatever its called I got 9.43 volts, I know it needs 9 to start would that little extra voltage cause it not to start??
post #7 of 9 (permalink) Old 01-09-2013, 03:50 PM Thread Starter
So its not the wiring harness, replaced it with another one I had was not the ecm I tryd 2 different ones, was not the switch I tested it and tryd a different one all relays are good...what could it be-_-
post #8 of 9 (permalink) Old 01-09-2013, 05:56 PM
Have u tried swapping relays?
"It sounds like a Ferrari having an orgasm"
Handyman is offline
post #9 of 9 (permalink) Old 01-10-2013, 05:50 PM Thread Starter
Yes I did that,I have a feeling its the diode in the ignition, anyone know where I can buy one besides the dealer?
