2003 cbr 600rr over loading with gas bad please help miss my bike - 600RR.net
post #1 of 21 (permalink) Old 01-09-2013, 05:11 AM Thread Starter
So I cleaned all the connectors on my wiring harness.and when I put every thing back together it ran bad took a min to start and when it did it would run bad until I gave it throttle up to 5000 rpm still sounds bad in high Rev and won't idle the only mill code I get it 1 blink (map sensor) it has akra slip on and pc3 USB that's it and 33,000 miles but I mant. My bike on time and take good care of it any help plzzzzzz
??? If the map sensor is faulty would it cause it to
Run rich are what would exactly cause it to do or run
Last edited by Hype600; 01-09-2013 at 05:17 AM. Reason: For got to ask a quistions in post
Hype600 is offline
post #2 of 21 (permalink) Old 01-09-2013, 06:51 AM
White RepsoL's Avatar
Ck vacuum lines one prob disconnected.
T fitting under tank.
White RepsoL is offline
The Following User Says Thank You to White RepsoL For This Useful Post:
Hype600 (01-09-2013)
post #3 of 21 (permalink) Old 01-09-2013, 07:42 AM Thread Starter
I took the tank off and checked the lines they all look good
Hype600 is offline
post #4 of 21 (permalink) Old 01-09-2013, 07:43 AM
Nico's Avatar
You will have left the vacuum line to the map sensor off.
Nico is offline
post #5 of 21 (permalink) Old 01-09-2013, 07:43 AM
Nico's Avatar
Or you may not have plugged it back in...
Nico is offline
post #6 of 21 (permalink) Old 01-09-2013, 09:28 AM
Yeah i would say vacuum line mine would always disconnect on me
ANTHONYSOTO21 is offline
post #7 of 21 (permalink) Old 01-09-2013, 04:33 PM Thread Starter
I'm going to double check but I dnt thaink it's that not sure and ? How would a faulty map sensor make the bike run
Hype600 is offline
post #8 of 21 (permalink) Old 01-09-2013, 05:48 PM
Like ****...
post #9 of 21 (permalink) Old 01-09-2013, 07:58 PM Thread Starter
I'm asking how would the bike run if it did have a faulty sensor
Hype600 is offline
post #10 of 21 (permalink) Old 01-09-2013, 09:15 PM
NaturalPhenomenon's Avatar
Iv been running on a faulty ecu or dash for a while now but the bike runs fine. My MIL light wont turn off or blink.
Sent from my SGH-T989 using Motorcycle.com Free App
NaturalPhenomenon is offline
post #11 of 21 (permalink) Old 01-10-2013, 12:24 AM
tuck and roll's Avatar
The map sensor is a dominant fuel control sensor. With the vacuum line off, it thinks the engine is under heavy load and dumps lots of fuel in, blubbers and runs like sh*t.
If vacuum line is connected and wire connecter in place, it depends if it's high or low, open or shorted, neither of which is common.
tuck and roll is offline
post #12 of 21 (permalink) Old 01-10-2013, 12:57 AM
Nico's Avatar
Then you probably have low oil pressure. Check your oil level and your oil pressure sender.
Nico is offline
post #13 of 21 (permalink) Old 01-10-2013, 01:50 AM
Says FI on the dashboard. Its not oil. Iv checked everything throughout the bike. Idk what else it can be
post #14 of 21 (permalink) Old 01-10-2013, 03:31 AM
Nico's Avatar
hmm.
In that case you will need to take it to a dealership and have it hooked up to find what triggered the FI light.
Nico is offline
post #15 of 21 (permalink) Old 01-10-2013, 08:03 AM
Its an 06 their tester looks like somthing out of a horror film From the 80s
post #16 of 21 (permalink) Old 01-10-2013, 08:54 AM
Nico's Avatar
lol
See what they get I suppose...
Nico is offline
post #17 of 21 (permalink) Old 01-10-2013, 12:39 PM
There are some melting evidence on my dash. They said it could be a bad dash which makes sence.
post #18 of 21 (permalink) Old 01-10-2013, 03:35 PM
And I'm telling you it will run like crap...
post #19 of 21 (permalink) Old 01-10-2013, 09:35 PM
Nico's Avatar
When it fails to recognise the map sensor it only uses the throttle position sensor and RPM to work out fuelling. The result is an engine that is running rich and doesn't run particularly well at idle especially. It will however keep running.
Nico is offline
post #20 of 21 (permalink) Old 01-10-2013, 10:06 PM
tripage's Avatar
Feedback Score: 91 reviews
DO you have a picture of this? That would have to be some serious melting to effect how the bike is running.
http://tripageled.com/store/
Owner
Tristan Page
[email protected]
[email protected]
tripage is offline
post #21 of 21 (permalink) Old 01-10-2013, 10:15 PM
Sdbir11's Avatar
Forgot to plug this bad boy back in on my bike today and i was having the same problem. I knew right away what it was. I was salty when i had to take it apart again.
Sdbir11 is offline
