Fuel pump not priming.. Please help! - 600RR.net
post #1 of 12 (permalink) Old 01-10-2013, 10:01 AM Thread Starter
Hey guys i have a 2008 CBR 600RR and I ran into a problem with the fuel pump not priming when i turn the key.
Here's the story,
last summmer a buddy and i were riding and we went to the gym and the bike was running fine! no problems! when we came out of the gym i inserted my key and turned it to the on position and didn't hear the normal sound of the fuel pump priming. I reached over and went to start it and it just cranked but didn't turn over. I popped the seat off disconnected the battery and and checked some fuses and everything seemed fine. I connected the battery, put the seat back on and turned the key and it started like there was never a problem, continued to ride the bike for weeks and never ran into a problem then all the sudden it did it again and i disconnected the battery and waited and put it back together and turned the key and still no fuel pump noise and continued to try turning the key on and off and eventually it worked.
Come fall time no fuel pump noise and bike won't start
i checked all the fuses under the seat, switched some relays around under the seat, disconnected and reconnected the tip sensor, tried bypassing the tip sensor, and i just can't seem to figure it out. I've seen some people have had some problems with their bike not making the fuel pump noise. it makes it tough that it would do it here and there but now its not priming at all.
Its very frustrating. please help[/B]
jlev09 is offline
post #2 of 12 (permalink) Old 01-10-2013, 10:52 AM
VP of Metal Operations
Inkslingerxx's Avatar
Feedback Score: 33 reviews
I still suggest removing and getting the contacts clean in the kill switch its like a 10 min job. Especially if you use your killswitch. Mine is just there for emergency for this reason. 8/10 times this will fix fuel pump issue. If that doesnt work Then we can give input on testing your fuel pump etc. Mine wouldnt prime twovsummers ago but it turned out mine was from field mice getting to my wiring harness but thats a bitch.
-Friedrich Nietzsche
Inkslingerxx is offline
post #3 of 12 (permalink) Old 01-10-2013, 10:53 AM
And yes the fuel pump wont prime with killswitch off.
post #4 of 12 (permalink) Old 01-10-2013, 10:58 AM
Originally Posted by Demented All you need is a small philips screwdriver and a pocket flathead, or anything flat like a razor blade, etc.
1)Turn your bars to full left lock. Makes it easier to remove the kill switch screws.
2) Pop the kill switch off the bars. You're after the switch assembly inside the housing . There's 4 small tabs that you can see through the side of the housing, 2 on each side. Push the tabs in and pry the switch out from the housing with the flathead.
3)With the switch out, pop the two pieces apart. There will be two tabs, one on each side. Here's one side popped off.
4) That will expose the contact points. You can see a little bit of pitting on my copper contacts and some grime on the silver ones. Clean off the contacts, and if needed, polish up the copper contacts with some fine grit sandpaper to get rid of excessive pitting.
(Pencil Eraser works well also)
5) Put together in reverse order.
post #5 of 12 (permalink) Old 01-10-2013, 11:02 AM
Tater S's Avatar
When you first turn the key does the tachometer needle sweep across the face and come back?
The kill switch is a very common problem. I had to replace mine once.
I've also stopped using it.
__________________________________________________ ____________________________________
Thank you for purchasing a 600rr as your first bike.
The odds are strong that you will successfully add to our classified section and help lower parts prices
Crash Stats: Length of ownership
https://www.600rr.net/vb/showthread.php?t=313730
Tater S is offline
post #6 of 12 (permalink) Old 01-10-2013, 12:32 PM Thread Starter
thanks guys ill look into the kill switch.. also, is there a kill switch relay i could maybe check?
jlev09 is offline
post #7 of 12 (permalink) Old 02-19-2013, 08:38 PM
Update??????
post #8 of 12 (permalink) Old 03-23-2013, 09:48 AM Thread Starter
Update??????
nothing new man, haven't bothered with it in a while. the other night i took the fuel tank off and tested the fuel pump and it worked so i know its not the pump. So its something that is preventing the fuel pump from kicking on. i just ordered a new kill switch and that will be in next week. any suggestions in the meantime?
jlev09 is offline
post #9 of 12 (permalink) Old 03-23-2013, 10:03 AM
nathan0726's Avatar
You probably could've just cleaned the contacts on the switch. Mine was going the same thing, I cleaned the contacts off and I haven't had an issue since.
Provehito In Altum
My Build Thread
nathan0726 is offline
post #10 of 12 (permalink) Old 03-23-2013, 11:25 AM
Images: 30
do you have HISS?? if yes, then the RFID tag in the key is likely compromised...
try spare key if it works then get new spare using your current spare..if you dont have a spare your pretty much f***ed, unless its electrical related of course.
no HISS, cant really help much more than what others have said
any updates?
sameh90 is offline
post #11 of 12 (permalink) Old 03-23-2013, 11:46 AM
KappaSigma's Avatar
I had this problem. Thought my batterey was dead. Charged it. Thought something was unplugged. Checked. Flicked the kill switch a couple times and what do you know. It primed. Something must be loose in my killswitch.
KappaSigma is offline
post #12 of 12 (permalink) Old 03-27-2013, 12:34 PM
Jotun's Avatar
Here's the story,
It might not be a bad idea to take a look at your ECM and make sure all of the wires are plugged it and none are just dangling. You will have some empty holes on your ECM but you shoudn't have any wires next to the ECM that aren't plugged into it. Make sure you have checked all of the fuses, including the two near the battery. If they are fine, I would take your fairing off and get access to your relays. Put the bike in neutral. You should be able to toggle your killswitch and hear your engine cutoff relay clicking. If this relay is not clicking then you probably have a problem with your killswitch or the wiring of your killswitch (assuming you have correctly bypassed the bank angle sensor). You said that you were able to get the fuel pump running, I'm guessing you applied voltage to the fuel pump connection under the tank. You should also be able to apply voltage at the fuel cut off relay and turn the fuel pump on. I can't find a wiring diagram so I can't tell you which color wires to connect but if you place a small jumper wire between the "output" wires of the relay (wires that are connected when the relay turns on), therefore bypassing the relay, it should start the fuel pump. Be careful not to jump the wrong set of wires as this could fry your ECM. If you can link me a wiring diagram I can tell you which wires to connect. If you are able to start the fuel pump from the connection under the tank, but not from the fuel pump relay, it could mean a couple of things. You could have a broken wire from the relay to the fuel pump connector or you could have a broken wire as one of your inputs to this relay (it would be the other "output" wire that comes from the engine stop relay).
Jotun is offline
