Brake light and turn signal indicator problem - 600RR.net
post #1 of 13 (permalink) Old 01-12-2013, 01:33 PM Thread Starter
AUaviator's Avatar
I have an 09 600rr with an iwin integrated taillight and hotbodies front turn signal. Not running resistors or an led flasher relay.
Here's the problem: When I pull my brake lever, the right turn signal indicator on my dash lights up. The turn signal itself does not turn on, just the light on the dash. Right turn signal works as it should as does the left.
Things I have tried: I checked my fuses (all good), unplug the front turn signals (same problem), go back to stock rear fender set up (same problem).
After I installed the whole lighting setup it worked perfectly. I hit a table-top speed bump/cross walk at quite a bit of speed and thats when it started happening.
“Courage is doing what you're afraid to do. There can be no courage unless you're scared." Edward Vernon Rickenbacker, WW1 pilot and ACE
2008 CBR600rr track Build Thread
2007 GSXR 600 track Build Thread SOLD!!!
2011 ZX-10r street Build Thread SOLD!!!
AUaviator is offline
post #2 of 13 (permalink) Old 01-12-2013, 01:47 PM
Banned
Are these headlights plug and play or do you have to do the wiring yourself?
Bizzle is offline
post #3 of 13 (permalink) Old 01-12-2013, 02:02 PM Thread Starter
AUaviator's Avatar
The taillight was plug and play, the front turn signals I did the wiring myself into stock connectors.
post #4 of 13 (permalink) Old 01-12-2013, 02:05 PM
tripage's Avatar
Feedback Score: 91 reviews
Just so we are covering everything. ON the hotbody signals there are 2 wires. On the bike there are 3 wires. Are the hotbody signals just on when you signal or are they running/signals?
http://tripageled.com/store/
Owner
Tristan Page
[email protected]
[email protected]
tripage is offline
post #5 of 13 (permalink) Old 01-12-2013, 02:45 PM Thread Starter
AUaviator's Avatar
They are only on when I signal. I only hooked up the strobe and negative wires on the hotbodies.
post #6 of 13 (permalink) Old 01-12-2013, 02:48 PM
tripage's Avatar
If you switch the signal wire to the other side on the taillight does the problem switch to the other side?
Owner
Tristan Page
[email protected]
[email protected]
tripage is offline
post #7 of 13 (permalink) Old 01-12-2013, 04:51 PM Thread Starter
AUaviator's Avatar
It does not. Its always just the right side.
post #8 of 13 (permalink) Old 01-12-2013, 06:15 PM
tripage's Avatar
I would put that on the taillight being the problem. Something in the wiring is causing the signal to trigger.
Owner
Tristan Page
[email protected]
[email protected]
tripage is offline
post #9 of 13 (permalink) Old 01-24-2013, 04:49 PM Thread Starter
AUaviator's Avatar
so I disconnected my iwin taillight, the problem stopped. I hooked up my stock light setup and it worked as it should. So it is the taillight itself. Any idea what it could be?
post #10 of 13 (permalink) Old 01-26-2013, 09:17 AM
the resitor, on mine it was half ass soildered so got a new one and soildere the crap out of it.. guess worked it self out with vibrations..
flat-blackrr is offline
The Following User Says Thank You to flat-blackrr For This Useful Post:
AUaviator (01-27-2013)
post #11 of 13 (permalink) Old 01-26-2013, 05:02 PM
You need resistors, my bike does the same thing, all led all around is too little resistance and it won't even flash quickly, it just won't flash
cailes is offline
post #12 of 13 (permalink) Old 01-26-2013, 06:23 PM
Nico's Avatar
^ no he doesn't, his tail light is stuffed. Power is being shorted from the brake light to the turn signal.
Nico is offline
post #13 of 13 (permalink) Old 01-27-2013, 09:42 PM Thread Starter
AUaviator's Avatar
Got it fixed. Took it apart and replaced the capacitor and re-did the crappy soldering job it came with. Works as it should now. Thanks for ya'lls help. (flasher relay is next on my list to fix the fast blinking)
