Gear shifter lever sticking HELP PLEASE - 600RR.net
post #1 of 5 (permalink) Old 01-25-2013, 04:32 AM Thread Starter
rolltide14's Avatar
I have a 06 Kawasaki zzr600 . Rode it the other day it will go down in first gear easy but sticks . It will shift up but for example going from first to second when i go to second gear it stays up. I have to tap the shifter down a little with my foot then i can shift up gears and so on. And it does the same when i down gear. I changed oil and filter thinking that it just wasnt well lubricated but didnt fix the problem. Can anyone please help !!
Sent from my DROID BIONIC using Motorcycle.com Free App
rolltide14 is offline
post #2 of 5 (permalink) Old 01-25-2013, 09:04 AM
AUaviator's Avatar
Might be a bent shift fork. Before that, do everything you can thats cheap and easy. Clean and lubricate the pivot point on the shifter first.
“Courage is doing what you're afraid to do. There can be no courage unless you're scared." Edward Vernon Rickenbacker, WW1 pilot and ACE
2008 CBR600rr track Build Thread
2007 GSXR 600 track Build Thread SOLD!!!
2011 ZX-10r street Build Thread SOLD!!!
AUaviator is offline
post #3 of 5 (permalink) Old 01-26-2013, 06:49 PM
Rozenheimer's Avatar
Also check the bolt that is connecting the shifter to the bike. It could be too tight and making it not easy to move. Follow the recommended specs, hope this helps.
-09 600rr Tricolor
-My Build
https://www.600rr.net/vb/showthread.php?t=286164
2W1R: MrProteinShake
Rozenheimer is offline
post #4 of 5 (permalink) Old 01-27-2013, 07:15 PM
BOTM Winner 03/13
Sun-Zoom-Spark's Avatar
Images: 175
Try to find out whether it's resistance at the top (the shifter arm) or the bottom (by the side stand). That should isolate your problem.
Bottom should be a quick and easy fix. Top probably not so!
Sun-Zoom-Spark is offline
post #5 of 5 (permalink) Old 01-27-2013, 07:20 PM
Gashuffer's Avatar
Feedback Score: 5 reviews
Also check to see clearance. Might be getting caught on fairings or something?
Sent from Motorcycle.com App
Give a man a fish; you have fed him for today. Teach a man to fish; and you have fed him for a lifetime.
Gashuffer is offline
