brake lights always on !! - 600RR.net
post #1 of 15 (permalink) Old 01-26-2013, 01:41 PM Thread Starter
salsaleh's Avatar
Like the title states, my brake lights are always on for some reason, this went bad as well as the right turn signal. the rear right turn signal doesnt work, the front right turn signal sometimes works, and sometimes freezes.
on the dash, the right turn signal is always on (doesnt blink)
What do i need to check ? i never touched a wire in my bike so please indicate the location of what i need to check
thanks
Your daily dose of pre-workout motivation, fitness articles, and whatever it takes to go beast-mode on em
http://www.facebook.com/pages/Painan...40363356065027
salsaleh is offline
post #2 of 15 (permalink) Old 01-26-2013, 02:08 PM
for the brakes I would check the actual sensor, it could be your rear switch sensor, or front, they are adjustable, so they may be activating while brakes are off.
turn signals could be the switch itself, not too sure how all that works.
hope this helps
cailes is offline
post #3 of 15 (permalink) Old 01-26-2013, 03:03 PM
Lobster's Avatar
Its always been the rear switch sensor for me for the brake light.
Check your connections and fuses for the blinker issue. Are you running LED blinkers?
Lobster is offline
post #4 of 15 (permalink) Old 01-26-2013, 03:08 PM
NaturalPhenomenon's Avatar
Re: brake lights always on !!
Iv had that problem too its the rear brake pedal switch u gotta turn the nut to give it more room
Sent from my SGH-T989 using Motorcycle.com Free App
NaturalPhenomenon is offline
post #5 of 15 (permalink) Old 01-26-2013, 03:26 PM Thread Starter
salsaleh's Avatar
yeah i have a fender eliminator kit
salsaleh is offline
post #6 of 15 (permalink) Old 01-26-2013, 03:27 PM Thread Starter
salsaleh's Avatar
il try that, but how come the turn signal went bad at the same time ? is the brake light and the turn signal related/connected in any way ?
salsaleh is offline
post #7 of 15 (permalink) Old 01-26-2013, 06:43 PM
Nico's Avatar
Rear brake switch (on the rearset) and your tail light is where I would be looking...
Do you have an after market tail light?
Nico is offline
post #8 of 15 (permalink) Old 01-27-2013, 12:15 PM Thread Starter
salsaleh's Avatar
nope stock, it has been running ok for 2 years, never touched a wire, im gna check the rear brake switch
salsaleh is offline
post #9 of 15 (permalink) Old 01-27-2013, 02:25 PM Thread Starter
salsaleh's Avatar
ok ur right nico, loosened up the spring on the rear brake a little and brake lights work perfectly fine now.
What about the right turn signal ? what so i need to check ? it sort of gets stuck sometimes and doesnt blink (freezes on), and the rear signal is out
salsaleh is offline
post #10 of 15 (permalink) Old 01-27-2013, 05:22 PM
Nico's Avatar
Have you still got the stock indicators? Or have you got LEDs in there at all?
Nico is offline
post #11 of 15 (permalink) Old 01-28-2013, 11:01 AM Thread Starter
salsaleh's Avatar
LED indicators
salsaleh is offline
post #12 of 15 (permalink) Old 01-28-2013, 06:49 PM
Owns24's Avatar
I has that issue on my '04, took it in and it was the sensor was jammed in the brake position, check your front brake lever. Pull it if you don't hear that audible click it's stuck
Owns24 is offline
post #13 of 15 (permalink) Old 01-28-2013, 09:41 PM
Honda125 358's Avatar
Feedback Score: 7 reviews
If the rear switch isn't the issue, check that the bolt holding the front brake switch (at the lever) didn't fall out. The switch is mounted under the lever near the pivot, it's a little black box
2007 CBR600RR, a work in progress
Honda125 358 is offline
post #14 of 15 (permalink) Old 01-29-2013, 01:28 AM
Nico's Avatar
He has that sorted out now, it was the rear brake switch.
Nico is offline
post #15 of 15 (permalink) Old 01-29-2013, 01:30 AM
Nico's Avatar
Originally Posted by salsaleh View Post
LED indicators
Check the wiring to the indicators, there is a fair chance it's dodgy. Also look for any resistors hooked up to that wiring and check them.
It would also be worth your time and dollars replacing any resistors with an LED flasher relay...
Nico is offline
