Starting Issue - Now seems to be running hot - 600RR.net
post #1 of 5 (permalink) Old 09-28-2005, 10:59 PM Thread Starter
I have an '05 CBR 600RR, bought it used with 1700 miles on it, I have had it for a few weeks now. I did something to the bike, and it seems as though I screwed something up. Please help ?!
Last night I installed the CA Integrator kit, tested everything and buttoned it up, started the bike, tested blinkers, brakes, etc. Everything was fine.
A different thing that had been bothering me about the bike was that whoever had the bike before me installed the Yosh RS-5 pipe a little crooked. So, in an attempt to straighten it, I loosened the bolt and nut that holds the bracket in place for the pipe(the one right under the center of the back seat) and manipulated the pipe a little, then re-tightened it back up. It wasn't perfect, but it looked a little better than before. Later in the day I fired the bike up to go for a ride and it was idling a little rough, like 800 instead of around 12-1500. So I gave it a little gas and it sputtered out and stalled. Then the bike would not start. I was like, great, I hope your happy that your pipe is a little more straight you dumb ass, cause now you have screwed somethingt up! Anyway, I waited a little while, about 10-15 minutes or so and tried to start it again. Same thing, it would try to start but not turn all the way over. So after trying a couple of times, I tried giving it some gas while turning it over and it fired up. I reved it a few times and shut it off, then started it again and it started normally. So I took it on a 5 minute ride or so. It seemed different, like maybe there is an exhaust leak or something. Not quite as much power on the throttle and sounded a little weak compared to what I was used to. Now I just took it for an actual ride and it seems to be running a little hot. It is staying at about 209 and up to 220 at a stop light. I was even riding it at 55-60 MPH for about ten minutes and it never dropped below 195. It is currently nice and cool norhtern california weather at night too, so it seemed as though it should have been running a lot cooler. Normally, it only runs that hot during the middle of a hot day. Anyways, If anyone can think of what I might have possibly done to cause a problem, please respond with some advice or experience in this area.
Thanks,
Todd
togles is offline
post #2 of 5 (permalink) Old 09-28-2005, 11:29 PM
fireblade's Avatar
Images: 2
Try adjusting your idle man, set it to around 1300RPM +/- 100RPM.
fireblade is offline
post #3 of 5 (permalink) Old 09-28-2005, 11:45 PM
LtcOliverNorth's Avatar
Fiddling with the pipe is not going to prevent the bike from starting, or make it run badly. You could in fact entirely remove the Yosh Slip-on and ride the bike around the neighborhood and it would not make a noticable difference - except maybe to your neighhbors.
Your temps seem normal to me... I run the same temps myself with Engine Ice in 100ish degree weather. For OEM coolant in a cooler enviornment that is about right.
2005 BMW R1200GS
2005 Kawasaki KLR650
1971 Honda CL350
LtcOliverNorth is offline
post #4 of 5 (permalink) Old 10-01-2005, 12:23 AM
I have the same problem on an '04 with the yosh rs-5, but i don't think its an exhaust problem. i now live in tempe, az, and my temps have been rising quick and staying hot for a while, but i can't deny the fact that i am riding the bike in temp upwards of 100 or above. my bike is a ca bike with 6k on it. basically, it does the same thing. tries to turn, it won't, blip the throttle, and it fires. not sure what it is, but im havin the same problem and if it gives me more problems it might be time for an unfortunate trip to the dealer.
HyE_RR is offline
post #5 of 5 (permalink) Old 10-01-2005, 02:07 PM
NewRedRider's Avatar
Images: 24
Have you had the tank off the bike. It sounds to me like your running leaner then normal. Hence the higher temps and rough engine idle. Check for a pinched fuel line in front of the tank. Make sure it fits in the notch in the air box.
How old is the fuel? You could have some bad gas in the tank. I don't think messing with the exhaust pipe had anything to do with your current problem.
NewRedRider is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
PCIII: The cure for hot runnin? DiZmAc Exhaust & Fuel Delivery 10 07-25-2006 05:03 PM
Bike running HOT. SinisteRR General Discussion 12 07-09-2006 03:09 AM
LED Running Lights? fergusonv 03-06 RR Modifications 2 05-19-2006 02:40 PM
Having trouble starting when hot? It's the starter! NewRedRider Polls and Research 14 09-16-2004 03:57 PM
Trouble starting when hot? KooJo Maintenance 28 09-15-2004 04:53 AM
