engine randomly cuts out during acceleration - 600RR.net
post #1 of 5 (permalink) Old 10-01-2005, 01:04 AM Thread Starter
Images: 6
hi, I just bought a 600rr with ~4400 miles. I'm upgrading from an F3 so it's definitely a big change. The bike is awesome and super clean but in the past few days, it has randomly cut out during acceleration. It happened 3 times in 1st gear while taking off from a light and once while accelerating in 3rd on the highway. I had to actually pull over to the side, turn the key and kill switch off , and then turn them back on to start the bike again. Anyone have any suggestions on what it might be before I take it in to the shop? I'm guessing something is loose....but not really sure what.
ExhaustNote is offline
post #2 of 5 (permalink) Old 10-01-2005, 04:32 AM
Perhaps it's a faulty relay. There are three relays on the left side intake duct. The middle one is for the cooling fan. The bike can be run without that one so you can swap it out with the other two. Just off the top of my head one is for the engine stop relay. The other i can't remember but they are both needed to run the bike.
scuzmuz is offline
post #3 of 5 (permalink) Old 10-01-2005, 07:37 AM
Over the berm, and thru the woods, to grandmothers house we go...
flamedRRider's Avatar
Images: 70
Sounds like it might be a faulty Bank Angle Sensor. Its between the headlights. It is loose or bad. The next thing sounds like a loose wire that is shorting somewhere, you will have to search for that.
04' 600rr function over fashion at this point.
flamedRRider is offline
post #4 of 5 (permalink) Old 10-01-2005, 01:59 PM
NewRedRider's Avatar
Images: 24
Definitely check all your fuses, battery cables, and PIN connectors.
NewRedRider is offline
post #5 of 5 (permalink) Old 10-02-2005, 07:14 PM
Images: 3
buddy of mine had the same problem....turns out it was loose battery cable due to too many weelies
vawn69 is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
HRC Throttle Wiring Ringo 03-06 RR Modifications 15 12-02-2006 10:24 PM
Engine power cuts off at 13k rpm pelele General Discussion 31 04-29-2006 10:24 PM
Engine cuts out... any ideas? senecak19 Troubleshooting 6 04-28-2006 09:52 AM
a little perspective on acceleration Simonster Off Topic & Flame Thrower 2 02-04-2006 12:08 PM
bike cuts out randomly danimal Maintenance 9 05-09-2004 04:13 PM
You may post new threads
You may post replies
