fuel gauge not reading - 600RR.net
post #1 of 6 (permalink) Old 10-02-2005, 02:32 PM Thread Starter
Question fuel gauge not reading
went for a ride this weekend and when i top off my tank and started the bike the fuel gauge said i was already down 1 bar. (03 rr) i shot off the bike and check the tank it was full. i was at 95 miles and the fuel gauge started flashing (reserve) got the gas station and i only put in 2.5 gallons. what do i do? i bought the bike used. so i dont have a worrenty how much does it cost to fix?
03 600 RR
scotts ohilins streeing damper
woodcraft frame sliders
cataylist composit body work
artat full ti system
pcm usb III
rk 520 x ring -1 +2
galfer ss lines
galfer hh pads
castrol 5-40
srfinatsunset is offline
post #2 of 6 (permalink) Old 10-02-2005, 02:38 PM
resqme's Avatar
Images: 2
i did a search, and it sounds like the gas gauge goes bad, and the dealer ends up replacing it. I don't have a clue to how much it would cost..gl
resqme is offline
post #3 of 6 (permalink) Old 10-02-2005, 07:53 PM
NewRedRider's Avatar
Images: 24
I think you're talking about 2 different issues. The dealer usually replaces the guage cluster if the buttons stop working.
There's nothing wrong with your gas gauge. It sounds like the tank float is bent or out of calibration. Just go by your miles per tank. Otherwise, you have to pull the tank and remove the fuel pump assembly to correct the float. Not worth it in my book.
NewRedRider is offline
post #4 of 6 (permalink) Old 10-03-2005, 06:04 PM Thread Starter
i went to the my local dealer today and i asked them what the problem might be and they said it could be the sending unit or the lcd screen. if it was the sending unit it would be 400 dollars plus labor. the other thing is they havnt seen a problem like this either. i tend to think a little different. so for now i am going to use my mileage for now. but i would like to get a fixed since it is a really nice toy
03 600 RR
pcm usb III
rk 520 x ring -1 +2
galfer ss lines
galfer hh pads
castrol 5-40
post #5 of 6 (permalink) Old 10-10-2005, 04:52 PM
Rolling Roscoe's Avatar
Images: 23
Dude, I'm having the same troubles with mine. I have a black '05. Happened twice. The first time I had only one bar left but no red LED for reserve. Bike died, pushed it to a gas station, fired right up with a full tank. Today, a month or so later, I'm riding down the road, have 2 bars showing and it runs of of gas again. Ridiculous! I have a feeling its the sending unit. Haven't taken it to the dealer yet, still has warranty but I have changed out the intake and exhaust system and don't feel like putting it back to stock just to keep Honda happy. I guess I'll have to do the milage thing for now. A pity seeing how much the freaking thing costs.
Good luck with yours.
'05 Black
DIY FE
OEM seat cowl
LED rear signal/brake light
Sato rear sets
Vortex Frame Sliders
LED flush turn sigs
BMC filter
PCIII-USB
Two Bros C-5 S/O CF
Swingarm spools
Scott's Damper
GS Creations LED run light
Metzler M1 tires
Galfer SS lines (blk w/gold)
Luminics Hdlights
Pazzo Shortie Levers (blk/gld adj)
Pro-Bolt bar Ends-bolt kits
G-Craft Brake Res.
ZG Dark Smoke
Renthal 16/43-DID 520ERV3
Corbin Seat
FP Velo Stacks
Rolling Roscoe is offline
post #6 of 6 (permalink) Old 10-10-2005, 06:02 PM
Images: 306
Check your connections from the sending unit and the connection to the console. If it is the sending unit i'd search ebay for a replacement tank with the unit still in it or the unit itself. And if no luck there I would probably leave it and go by milage.
joe_rocket65 is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
fuel gauge cbrdeju Troubleshooting 6 08-26-2011 04:59 PM
Fuel Gauge Indicator (low on fuel) jfook1 Exhaust & Fuel Delivery 26 09-05-2010 04:20 PM
Fuel Gauge? 0verdose General Discussion 9 07-06-2006 02:18 PM
Fuel Gauge Problems?!?! maixner96 General Discussion 4 08-28-2005 01:15 PM
Fuel Gauge Failure Indication J3rmz731 Maintenance 4 04-23-2004 09:50 AM
