help starting bike - 600RR.net
post #1 of 18 (permalink) Old 10-11-2005, 09:28 PM Thread Starter
help starting bike
having trouble starting my bike (2003 CBR 600rr) and need some help. haven't had the bike out of the garage in 5 weeks. after replacing the battery and getting the cables hooked back up it won't start. the bike
seems like it wants to turn over, but just won't fire. after talking to my local honda shop (service tech. wanted me to take off the carbs and clean them) i figured i might get an answer from someone who knows about the bike.
kaferwagen is offline
post #2 of 18 (permalink) Old 10-11-2005, 09:34 PM
EsotericRR's Avatar
Images: 14
well your bike is fuel injected so i dont know what the service guy is gonna clean the carbs for lol. So dont take it to that guy. Did you leave old gas in there? Have you put newer gas in? Did you try to open the throttle once when you were starting it? If not try that. The manual will tell you so if you want to look.
-bikeless
EsotericRR is offline
post #3 of 18 (permalink) Old 10-11-2005, 09:51 PM Thread Starter
yeah, i informed him there weren't carbs on the bike and he didn't understand....informed him i would just call the other honda shop in town. tried to crack the throttle while starting, but no luck.
post #4 of 18 (permalink) Old 10-11-2005, 10:12 PM
AlpineJim's Avatar
I am having the same thing happening to my 03 600rr track bike, I just rewired it for keyless start and now nothing will happen... no prime noise but lights and speedo works.. I did the trouble shooting(engine will not start and no MIT) in the service manual and ran in to a dead end, I got to the point to check continuity on the A4 and A18 of P32 and A4 as continuity but A18 doesnt??? I know that Im getting the battery power to my ECM but no continutiy on the ground? All the fuses are good and relays are good.. battery voltage is great.. It just doesnt want to prime the FI?
AlpineJim is offline
post #5 of 18 (permalink) Old 10-17-2005, 08:05 PM
im stuck in the same problem and am horrendously irritated, any help?
pbcstylez is offline
post #6 of 18 (permalink) Old 10-17-2005, 08:36 PM
check kill switch, bike stand, and gearing. thats all i can point out.
jchung is offline
post #7 of 18 (permalink) Old 10-17-2005, 09:56 PM Thread Starter
switch, stand, gears are all good. 2-3 bars of fuel & fully charged battery.....bike is going to the shop tomorrow....will let you all know when i hear something.
post #8 of 18 (permalink) Old 10-18-2005, 10:09 PM
ive checked my kickstand, in neutral, plenty of gas, fulyl charged batt, when i turn it on the FI and everythin turns on, it sounds like its almost ready to fire up but its just not firing up, any other ideas?
post #9 of 18 (permalink) Old 10-19-2005, 05:33 PM
NewRedRider's Avatar
Images: 24
Bad gas can cause this. Try holding the throttle wide open and crank it. If the gas is older then 5 weeks dump the tank a try a fresh tank of gas.
NewRedRider is offline
post #10 of 18 (permalink) Old 10-19-2005, 05:56 PM
seems like a pinched fuel hose? gonna strip it back down again tonight and see, the other day it backfired once and wouldnt backfire at all anymore it just putts but wont turn over
post #11 of 18 (permalink) Old 10-19-2005, 06:08 PM
Time to get to know your bike and clean tthe sparkplugs. Mine sounded like it wanted to start in the spring and I just cleaned the plugs and it started up right away.
gripnrip is offline
post #12 of 18 (permalink) Old 10-19-2005, 06:11 PM
Images: 24
Your not supposed to clean iridium tip plugs. Just replace them.
post #13 of 18 (permalink) Old 10-19-2005, 06:16 PM
Why not? I did and it worked but I"M wondering
gripnrip is offline
post #14 of 18 (permalink) Old 10-19-2005, 06:29 PM
everything was fine until i took the bike apart the other day to get to the throttle body, i dont see how my plugs are fouled already
post #15 of 18 (permalink) Old 10-20-2005, 12:55 PM
It sounds like it could be somthing you did taking it apart. But my plugs fouled with less then 3000 miles on it. When I put it away for the winter I cracked it open one last time in the garage and shut it off. All that gas didnt get to burn.
gripnrip is offline
post #16 of 18 (permalink) Old 10-23-2005, 04:14 AM
it seems now as if im not getting any spark, or lack of spark, any ideas before i start replacing plugs or rectifier or stator?
post #17 of 18 (permalink) Old 10-23-2005, 09:52 AM
Images: 24
It really depends on your idea of cleaning. If you're burying the plug in the dirt and burning them with gas, you might be Ok. But if you're using a brush, file, or sandpaper to clean the plug with you can damage the iridium center electrode and the gap. The SM's pretty clear. It says to check the gap with a wire type feeler gauge. If the gap is off, replace the plug. If you're cleaning it the wrong way the gap is probably off. The correct spark is very important.
Why did you have to get to the TB's? Did you take them off? Check your fuel line from the tank. There's a "groove" in the airbox for that fuel line to follow and it's easy to get it on the wrong side of the tab on the tank.
post #18 of 18 (permalink) Old 10-27-2005, 11:33 PM
im gonna replace me a rectifier, any ideas?
Similar Threads
Thread Thread Starter Forum Replies Last Post
2nd gear wheelie on 600rr appex_wraith Stunts 47 08-21-2009 08:52 AM
sh*t hit the fan (told my mom i have a bike) [long post] marlopez General Discussion 64 06-09-2006 03:56 PM
Help! ASAP Bike starting problem, then smokes! bwest3 Troubleshooting 8 05-26-2006 02:57 PM
Protecting your bike on and off the internet souperman General Discussion 8 02-21-2006 07:08 PM
New To 600rr.net and bikes ChiTownsFinest Off Topic & Flame Thrower 18 05-08-2005 12:55 PM
