rear brake light wont work - 600RR.net
post #1 of 4 (permalink) Old 11-01-2005, 05:31 PM Thread Starter
So my rear brake light will not work... The brake light goes on when I press my front brake.. but not when I apply the rear brake. My rear brake does work though.... Any comments, suggestions?? Thanks
klumpped is offline
post #2 of 4 (permalink) Old 11-01-2005, 05:36 PM
bent240sx's Avatar
Images: 81
check the switch behind your right foot peg. make sure the spring did not pop off. also there is a barrell type adjuster on the switch, make sure there is enough tension on the spring to activate the switch when you push the brake pedal.
03 black #228
bent240sx is offline
post #3 of 4 (permalink) Old 11-01-2005, 07:20 PM
Images: 306
Here is a diagram. You don't have to unbolt the rearset to adjust it. Like he said above. Check the spring and the adjusting nuts. The spring stretches over time which prevents it from activating the switch. Also check the wires to the switch. If that doesn't help then it may be your switch is faulty.
joe_rocket65 is offline
post #4 of 4 (permalink) Old 11-04-2005, 08:17 AM Thread Starter
Thanks... It was the spring.... Easy fix... Thanks for the help
klumpped is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
wtb: rear brake light bracket/screws 03-04 EuniceEstelle Wanted 0 11-06-2006 12:10 PM
Rear Brake....Y/N? Mongoose Trackdays 152 04-04-2006 04:43 PM
Rear Brakes not lighting brake light?? CanadianCBRGuy Maintenance 5 07-20-2005 03:26 PM
Rear Brake Reservoir Elimination - Image and Questions Coyote Trackdays 47 02-01-2005 04:05 PM
rear brake pedal too sensitive, need help sgtadamdee 03-06 RR Modifications 9 01-07-2004 06:06 PM
