i need a little help bike won't start - 600RR.net
post #1 of 7 (permalink) Old 11-10-2005, 04:32 PM Thread Starter
Exclamation i need a little help bike won't start
I rode my bike home last night parked in front of my house went to ride next day turn bike (didn't hear fuel pump) tried to turn it over but won't start it turns over fine but will jsut not start i can't get the fuel pump to work. nothing has happened the bike was not dropped or anything
05 CBR 600 RR any one else have this problem or have any advice
nighthawk41186 is offline
post #2 of 7 (permalink) Old 11-10-2005, 04:47 PM
Images: 28
If you're not hearing the fuel pump turn on when you turn the ignition on then I'd start by checking for a blown fuse. 30A main fuse, then 10A sub fuse. Then inspect the engine stop switch, fuel cut-off relay, engine stop relay, and bank angle sensor.
Ajax is offline
post #3 of 7 (permalink) Old 11-10-2005, 04:56 PM Thread Starter
checked the main fuse and all the sub fuses that i could find. Everything else is working.
and by the way i have a power commander and it's not getting any power at all and i have checked all the connection and it still works with my laptop seems like the fuel system is not gettting anypower
post #4 of 7 (permalink) Old 11-10-2005, 05:38 PM
something may be shorting out something... or a loose connection with the power commander, i had that problem.
MannyMalice is offline
post #5 of 7 (permalink) Old 12-10-2005, 01:49 PM
Shaggs2Dope's Avatar
Images: 4
my bikes doin the same thing, but without any mods. turned off while i was riding and wont turn back on
Aww, they love each other, but are Jealous of who gets my attention.
Shaggs2Dope is offline
post #6 of 7 (permalink) Old 12-10-2005, 02:18 PM
Back in the Day
Moeman's Avatar
Images: 665
Feedback Score: 148 reviews
try charging the battery it might not have enough juice to
get all the electronics going ( fuel pump )
Moeman is offline
post #7 of 7 (permalink) Old 12-12-2005, 10:44 PM
Images: 4
mine turned out to be a loose connector or something, because i disconnected everything and reconnected it, and it started first try. all my fuses were fine but i heard the ignition fuse goes out easily, small bike, small battery, big draw of current. Easy to nuke a fuse. Check your FI electrical connectors, and the ones that are near stator cover and back to the coil as well
Similar Threads
Thread Thread Starter Forum Replies Last Post
bike wont start (04) pink wire not getting power. 10SECGN Maintenance 4 11-15-2006 11:52 PM
Bike Doesn't Start CBRiderRR Troubleshooting 5 11-15-2006 01:12 AM
Honda Releases Info On 800cc V-4 MotoGP Bike eRRoc MotoGP, AMA and WSBK 71 11-03-2006 12:57 PM
Bike wont start Fixembones Maintenance 10 08-18-2006 03:13 PM
Bike wont start krhymez Troubleshooting 5 08-17-2006 12:48 PM
