help: knocking/popping noise - 600RR.net
post #1 of 13 (permalink) Old 11-13-2005, 01:05 PM Thread Starter
em2b96p's Avatar
ok ive got a 03 rr with about 16xxx miles on it.. the clutch does not slip and ive really had no problems with it...
but... lately ive been hearing a knocking/popping noise coming from the bike. i notice it when i move the bike around in the garage while it is OFF and in Neutral.
i have taken off the crush drive sprocket plastic cover and i can hear that the noise is coming from behind the crush drive sprocket. it deffinatly is not the chain rubbing against the plastic guide piece on the swing arm.
important note: when i loosen the chain excesivly the noise dissapears, but when i tighten it to spec the noise comes back.....
im thinking ive got a bad chain but the chain isnt streched.... any ideas???
thanks
steven
em2b96p is offline
post #2 of 13 (permalink) Old 11-13-2005, 05:36 PM Thread Starter
em2b96p's Avatar
after test riding the bike i can hear the noise when im riding. harder to hear because of the exhaust and wind noise.
but come to think of it, the noise sounds like a roulette wheel.
em2b96p is offline
post #3 of 13 (permalink) Old 11-13-2005, 06:12 PM
Back in the Day
Moeman's Avatar
Images: 665
Feedback Score: 148 reviews
you probably get a tight spot in your chain simply becuse when the chain is loose you do not hear that noise & it comes back when you tighten the chain to spec
Moeman is offline
post #4 of 13 (permalink) Old 11-13-2005, 07:09 PM Thread Starter
em2b96p's Avatar
what exactilly is a tight spot? does this mean i wil have to get a new chain?
em2b96p is offline
post #5 of 13 (permalink) Old 11-14-2005, 09:36 AM
Look for a kink in your chain links or bend each link and see if you find any that are stiffer then the rest. Easy to check with the bike on a rear stand.
If the chain is bad, theres a good chance your front sprocket may be worn out.
Dekon is offline
post #6 of 13 (permalink) Old 11-14-2005, 02:21 PM
NewRedRider's Avatar
Images: 24
Also make sure the rear wheel is aligned correctly.
NewRedRider is offline
post #7 of 13 (permalink) Old 11-14-2005, 02:48 PM Thread Starter
em2b96p's Avatar
ok so i added a bit of engine oil since i havent changed it since june..... and then i lubed the chain..
sound is gone :) hopefully that fixed it and not masked it
em2b96p is offline
post #8 of 13 (permalink) Old 11-14-2005, 04:29 PM
Resident Leg-Humper Females Beware
BlueBlur's Avatar
Images: 25
Feedback Score: 18 reviews
most likely it was a dirty chain or it was a bit too tight. i had that issue for a few weeks this summer after taking my wheel off, loosened the adjusters maybe half a turn and it's gone.
HOOORRRAAAYYYY FOR BOOOOOTTIEES!!!
BALALALALALA OMG TERRORIST!!
BlueBlur is offline
post #9 of 13 (permalink) Old 11-14-2005, 09:09 PM
Images: 24
Lube it often and she'll love you forever!
post #10 of 13 (permalink) Old 11-15-2005, 12:02 AM
some words to live by haha
potate311 is offline
post #11 of 13 (permalink) Old 11-15-2005, 12:04 AM
oh yeah and here is another tip for ya before you post a thread saying the ENGINE is making a "knocking/popping noise".... change that friggin oil! jeez
post #12 of 13 (permalink) Old 11-15-2005, 02:07 AM Thread Starter
em2b96p's Avatar
oh yea show me where i sed ENGINE is making a noise
i do see ENGINE OIL but not ENGINE is making a noise
you wiseguy
shut ur fingers
em2b96p is offline
post #13 of 13 (permalink) Old 11-22-2005, 03:48 PM
I have this problem atm. Chain is well lubed and adjusted according to the manual. Is it possible for the front and rear sprockets to be misaligned? Chain is only 8000km old (halfway between new and replace on the marker) and not stretched at all. Sprockets look fine. I don't wheely, but do do trackdays.
proze is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
knocking noise behind front sproket em2b96p Troubleshooting 8 07-07-2011 12:28 AM
chain noise srfinatsunset Maintenance 10 08-26-2005 01:13 AM
Whirring noise in 4th gear when cold asf Maintenance 0 06-09-2005 01:01 PM
aftermarket exhausts and Malibu Canyon Jaebster West Coast 15 06-06-2005 09:18 PM
brake noise and vibration powerranger Maintenance 3 04-22-2004 05:53 AM
