Need help Installing Integrated Taillight - 600RR.net
post #1 of 14 (permalink) Old 01-06-2006, 03:10 PM Thread Starter
I hooked up the two yellow wires that came with the Integrated Taillight and now they just don't blink. My front ones also just stay lit. When I touch the groung wire to them they start blinking, but if I have them connected they don't blink.
Please Help
miacho11 is offline
post #2 of 14 (permalink) Old 01-06-2006, 03:13 PM Thread Starter
Help Installing Integrated Taillight
I connected the taillight and now they don't blink. they stay lit untill i touch the ground wire to them. If I connect the ground wire they also don't work.
HELP
miacho11 is offline
post #3 of 14 (permalink) Old 01-06-2006, 03:26 PM
Toe
Toe's Avatar
is the bike on or off?
cause when i installed mine the bike has to be on for them to blink.
Toe is offline
post #4 of 14 (permalink) Old 01-06-2006, 03:29 PM Thread Starter
I have the bike on so that the board is lit up. You think it has to be on all the way. Thats weird
miacho11 is offline
post #5 of 14 (permalink) Old 01-06-2006, 03:31 PM Thread Starter
I never thought about that. I will try it. The weird thing is when I touch the green wire to the yellow and oange it starts blinking.
miacho11 is offline
post #6 of 14 (permalink) Old 01-06-2006, 03:34 PM
O2BESOHUGE's Avatar
http://www.customled.com/PRODUCTS/TH...er.htm#StageII
I HAD TO INSTALL THESE WITH MY TURN SIGNALS (LED'S) AND NOW THEY BLINK FINE
O2
2007 WHITE CBR600RR
PUIG WINDSCREEN
WATSENS SIGNALS
TRIPAGE TAG BRACKET
TRIPAGE HUGGER W/ LEDS
INTEGRATED TAIL LIGHT
VORTEX CAT 5 SPROCKETS 520 CONVERSION
D.I.D. 520 ERV3 GOLD CHAIN
SHOGUN NO CUT FRAME SLIDERS
SOLO SEAT COWL
TWO BROTHERS CARBON EXHAUST
O2BESOHUGE is offline
post #7 of 14 (permalink) Old 01-06-2006, 03:38 PM Thread Starter
Cool thanks................I'll try that route also.
miacho11 is offline
post #8 of 14 (permalink) Old 01-06-2006, 04:03 PM
O2
mine came with these... i used them. works fine... i think if you dont use them they blink faster.
Toobs is offline
post #9 of 14 (permalink) Old 01-06-2006, 04:09 PM
Back in the Day
Moeman's Avatar
Images: 665
Feedback Score: 148 reviews
use the resistors that came with the tail light the resistor needs
to be hooked up between the + & - wires
Moeman is offline
post #10 of 14 (permalink) Old 01-06-2006, 05:54 PM Thread Starter
Thanks for all the info................I'll be working on it this weekend.
miacho11 is offline
post #11 of 14 (permalink) Old 01-06-2006, 11:50 PM
First, what kind of integrated tail light do you have? All the resistors do is slow down the blinking rate same with the relay. If your signals aren't blinking then you didnt connect the wires correctly. Let me know what integrated tail light you are using
kink is offline
post #12 of 14 (permalink) Old 01-07-2006, 01:55 AM Thread Starter
It is the clear alternatives from e-bay for like $85. It is a complete replacement not just the bulb and it didn't come with different wire system. It has 2 yellow wire for the signals and a plug and play connector for the brake.
miacho11 is offline
post #13 of 14 (permalink) Old 01-12-2006, 08:31 PM
Syn6RR's Avatar
I just installed one of these last night. It was relatively simple because I cut off the connectors from my stock fender for the turn signals and soldered the yellow wires to them then plugged them in. Just make sure to test which yellow wire is left and which is right before you solder. I didn't put one those resistors because I kinda like the fast blink it seems to get more attention.
Syn6RR is offline
post #14 of 14 (permalink) Old 01-14-2006, 12:48 AM
Lan
Lan's Avatar
Carefull with the resistors. They get hot as hell when they are hooked up under your tail. Probably not hot enough to do any dammage but it gets hot enough under there without something else helping it get hotter.
Lan is offline
