Engine Temperature - 600RR.net
post #1 of 29 (permalink) Old 01-17-2006, 01:18 PM Thread Starter
Engine Temperature
I was just curious what temperature your bikes get to when just running around the streets and not the open road?
kiwi_ryder is offline
post #2 of 29 (permalink) Old 01-17-2006, 01:26 PM
Anywhere from 160-228 degrees Farenheit here in colorado. Keep it under 240 and you will be fine.
Jayock is offline
post #3 of 29 (permalink) Old 01-17-2006, 02:34 PM
pc911x's Avatar
Mine runs anywhere from 170 to 220 when stuck in traffic.
A thought for life;
DRESS FOR THE CRASH, NOT THE RIDE
Visit my photography web site
@ DonArmstrong.US
pc911x is offline
post #4 of 29 (permalink) Old 01-17-2006, 02:41 PM
Mine runs 80 degrees Celcius moving, and pops up to 104 stopped then the fan starts up I think the most I've seen on a really hot day was 115 once. I don't do that Fahrenheit meter as I know 100 degrees Celcius is boiling, and usually the temp outside is measured this way when you see the banks post it.
Blue ThundeRR is offline
post #5 of 29 (permalink) Old 01-18-2006, 09:59 AM
OveRReV's Avatar
Images: 16
same here it hovers at 104C & the highest was 116C but when i changed the coolant it never go beyond 112C.
2003 CBR 600RR JDM
HRC ECU AMA spec
HRC radiator
WP 4618 rear shock
WP 1508 steering damper
Ohlins 9.0N fork springs
Overrev tuned fork cartridges
Akrapovic Evo Carbon FS
Dynojet PCV WB2 POD300
BMC race air filter
AFAM 15/47 sprockets
DID VX2 520 gold chain
Brembo 19RCS MC
HEL brakelines
HM Plus quickshifter
EVR CTS slipper clutch
BST CF wheels
OveRReV is offline
post #6 of 29 (permalink) Old 01-18-2006, 10:14 AM
Sodamninsane's Avatar
Images: 15
170-220 is normal... fan should kick on at 214? ish...
Sodamninsane is offline
post #7 of 29 (permalink) Old 01-19-2006, 08:37 PM
shiftn3rdon1's Avatar
30 degrees F here and my bike runs at 173 degrees F
shiftn3rdon1 is offline
post #8 of 29 (permalink) Old 01-19-2006, 08:40 PM
Images: 13
Blue ThundeRR... nice avater I watched it for a good min.
layden03 is offline
post #9 of 29 (permalink) Old 01-19-2006, 08:43 PM
Back in the Day
Moeman's Avatar
Images: 665
Feedback Score: 148 reviews
The RR is known for running a lttle bit hotter than other bikes
At 220 F the fan should come on and if it does while you are
at a red light shut your high beam off till you start moving again
this will help preserve battery juice
Its normal to see temp ranging from 186 to 203 while driving in slow
traffic
Nothing to worry about unless your temp hits 240 then you got to pull over
and shut the bike off and let it cool down
Moeman is offline
post #10 of 29 (permalink) Old 01-20-2006, 02:25 AM
Mines been from 168-220... usually in the 170's on open road, 200's in traffic.
Toobs is offline
post #11 of 29 (permalink) Old 01-20-2006, 02:33 AM
SLAPS808's Avatar
Feedback Score: 56 reviews
165 175 open roads, 180 190's through slow moving traffic. 205-215 at long stop lights. my fan kicks on at 220. never seen my temp go past 220.
SLAPS808 is offline
post #12 of 29 (permalink) Old 01-20-2006, 02:40 AM Thread Starter
Thanks for the help guys, mine runs about right then, its just a little hotter than all my other bikes.
Cheers
post #13 of 29 (permalink) Old 06-26-2006, 08:52 PM
If in celcius, past what temp would i know something is wrong?
ProphetX is offline
post #14 of 29 (permalink) Old 06-26-2006, 08:55 PM
Ichiro's Avatar
212*F = 100*C
I'd pull over if I saw 116*C
05 RR Slv/Blk
Super perfundo on the early eve of your day
Ichiro is offline
post #15 of 29 (permalink) Old 06-27-2006, 08:02 PM
My fan stop work while I was riding to work last in the mouning. It was about 60 degrees. I was rolling a my temps was @220 It freaked me out because it was sort of cool @6:00 in the mourning. When I got to work I check it and my fan was not coming on. so I had to run a switch to it to make it to the dealership. I took it straight there from work. i guess I wire wrong because I thought it suppose to blow air to the radiator but I ? it suppose to draw the heat from it. When got in traffic from work it was in the 80's close to the 90's My temp was climbing like crazy so I had to hit the shoulder just to keep some air coming in but it was all hot and dry air outside that day. When I got to the street where the dealer is my temp reach 252 degrees. It scared the **** out of me because the red light came on then the gauge started blink @ me so I had to go around some cars to get a little wind, then it hit 256 and that was it and about 3min from the dealer then but it was long line of traffic and red light so I had to turn down side and get some are quick the temp when down enough for me to make it to the dealership. My bike is still @ the shop now. They said that the fan was unplug. That was bull because I checked the voltage there and there was none when you first turn on the bike the fan comes on the goes off, the fuse was good. So I asked him where was it unplugged @ and he could tell me. Unless it came loose on the other side near the thermostat. I didn't check that but, i will find out when I got and pick it up.
s295647 is offline
post #16 of 29 (permalink) Old 06-27-2006, 11:12 PM
blue_rrockit's Avatar
mine is running kinda hot. i live in socal and last night around 11pm i was zooming around local streets and noticed my temp was about 190F when i was moving and 200-210F at idle. by the time i got home it got up to 223F. gonna flush out the radiator and replace my coolant with Engine Ice this weekend.
blue_rrockit is offline
post #17 of 29 (permalink) Old 06-28-2006, 11:36 AM
wynngripRR's Avatar
fan kicks on at 220, mine sees 220 almost everytime i ride in traffic, I dont think its a big deal... Id probably get more nervous if I was in the 230-240 range
wynngripRR is offline
post #18 of 29 (permalink) Old 06-28-2006, 12:33 PM
APEX_600RR's Avatar
Mine gets up to about 232 everyday haha but im not too worried about it. The ECU will shut the motor off way before any heat damage has a chance to occur. I'll mix up and throw some Water Wetter in there when im not so lazy.
On o3-o4's the fan kicks on at 220 but on the o5-o6's i think its at around 212. I would always watch my o3 kick on at 220 but i think my new o5 kicks on around 212. I thought that was interesting, they must of had overheating problems with the 1st gen 600RR's ...
APEX_600RR is offline
post #19 of 29 (permalink) Old 06-28-2006, 03:49 PM
Even with Engine Ice my temps get up to 220+ while in local street traffic. On the highway I hover at like 172-176 (it was about 83 degress that day). When my mids and lowers where off my temps didn't climb fast at all even in local traffic. The temps climb slower with the Engine Ice for sure. I think you'd notice a big difference with Engine Ice if you were doing trackdays.
Johnny Candles is offline
post #20 of 29 (permalink) Old 06-28-2006, 04:35 PM
APEX_600RR's Avatar
When i flushed my coolant on my 954 and filled up w/ a Water Wetter mix I noticed a HUGE difference. Kept the temps at least 10 - 15 degrees cooler than with just coolant. Maybe it's more noticeable in really hot conditions like here in Phoenix ...
post #21 of 29 (permalink) Old 06-30-2006, 11:54 PM
scoRRpion's Avatar
On o3-o4's the fan kicks on at 220 but on the o5-o6's i think its at around 212. I would always watch my o3 kick on at 220 but i think my new o5 kicks on around 212. I thought that was interesting, they must of had overheating problems with the 1st gen 600RR's ...[/QUOTE]
on my 05 the fan still comes on at about 218-220 maybe your bikes just cooler than mine......pardon the pun.
scoRRpion is offline
post #22 of 29 (permalink) Old 07-09-2006, 07:09 AM
I've always been a bit worried about the high temperature on my bike. Especially at trackdays when my bike runs between 100 and 110 deg C (212 and 230 F). All my other bikes runs at about 85 to 95 deg C (185 to 203 F) under the same conditions.
I have heard some things that the problem can be fixed buy replacing the oilpump cover with one that has much better cooling-capabilities. Or thats what some aftermarket manufactorers claim.
Wile E. Coyote is offline
post #23 of 29 (permalink) Old 07-10-2006, 02:29 PM
The highest I have seen my 06 run (taking into consideration I am in Vegas) is 234. This was in the afternoon at the hottest part of the day, sitting at a stop light, while it was 106 - 109 degrees outside. That was the last time I was riding during the day. I was sweating for an hour after I got off that bike..... it was disgusting. I typically run anywhere from 190 - 215.
b3LgIuM fIre PiN3 is offline
post #24 of 29 (permalink) Old 07-13-2006, 08:03 PM
stevenunez's Avatar
Do all the 600's run hot like the CBR6RR? I don't ever recall my ZX10R ever topping 212' F- do all the 6's run this hot because of their smaller engines and higher working revs to maintain average speeds?
stevenunez is offline
post #25 of 29 (permalink) Old 07-13-2006, 08:57 PM
Hooked on Phonics
teleinfoncarr's Avatar
170 to 223 but it seems to stay in the 200 to210 most the time
NO BRAINS NO HEADACHE
The edge... theres no honest way to explain it, because thoes who know where it is have gone over..
teleinfoncarr is offline
post #26 of 29 (permalink) Old 10-01-2010, 12:04 AM
170-225. if its not over 100 degrees outside the fan does a pretty good job keeping the temp below 230.
aquinas is offline
post #27 of 29 (permalink) Old 10-01-2010, 12:20 AM
05'Scorpion's Avatar
Feedback Score: 8 reviews
fluctuate for me between prime 177 and fan kick on temp of 220...gotta be a hot day or really stuck in traffic to go over 220 tho...highest ive seen mine is 247 but that was after we made a stop after runnin wide open through scortching desert......
177=prime!
2006 CBR 600RR - Red/Black *StreetBike*
2003 CBR 600RR - All Black *Trackbike* SOLD
Orion Pit Bike *SOLD
05' CBR 600RR - Sold/Missed
WANTED!!! 08'+ 1KRR for sale White/Red or all Black
and....OHLINS FORKS/BREMBO BRAKES!!!
PARTS FOR SALE: https://www.600rr.net/vb/showthread.php?t=204160
05'Scorpion is offline
post #28 of 29 (permalink) Old 10-01-2010, 03:12 AM
Nico's Avatar
Nico is offline
post #29 of 29 (permalink) Old 10-01-2010, 04:20 AM
SHORTSTACK's Avatar
Feedback Score: 15 reviews
holy sh*t that lady in your avatar is beautiful.
mine runs 170-223 depending on what im doing.
R.I.P. PHATTY
SHORTSTACK is offline
