Upshifting problems. - 600RR.net
post #1 of 16 (permalink) Old 01-31-2006, 01:27 PM Thread Starter
eh-TEE-OH-clez
Aeteocles's Avatar
Images: 3
I got my new-to-me '05 RR. I bought it with 418 miles on it. It now has 590 miles on it. 600 mile service soon to be done.
However, the bike suddenly has trouble shifting up from 2nd to 3rd, and from 3rd to 4th.
The shift lever is solid, like when you try to upshift into 7th gear on the freeway.
I brush/squeeze the clutch lever a teeny bit, and unload the throttle a tiny bit when I shift. Even when I squeeze the clutch all the way in, the shifter lever still feels solid.
I really have to dig my foot way under the shifter and really yank on it to get the lever to move.
Any ideas what's wrong? Should I bitch at them when I get the 600 mile service done?
Aeteocles is offline
post #2 of 16 (permalink) Old 01-31-2006, 01:31 PM
mine was harder to shift when it was new, mine shifts great now with almost 13000 on it. seems like it got easier to shift around a thousand miles if i remember correctly.
TippinRR is offline
post #3 of 16 (permalink) Old 01-31-2006, 01:35 PM
squirt a little chain lube on the linkage point and the shift lever
cyclescientific is offline
post #4 of 16 (permalink) Old 01-31-2006, 01:35 PM
and the 7th gear attempt is exactly how i would've explained my feeling, too. others have experienced the same. (i tried searching but couldn't come up with anything, but it has been discussed)
TippinRR is offline
post #5 of 16 (permalink) Old 01-31-2006, 01:44 PM
Images: 12
Are you releasing pressure on the shift lever before atempting to gear it up again?? IE: not trying to shift through 2 gears with one push??
gearheadRR is offline
post #6 of 16 (permalink) Old 01-31-2006, 01:53 PM
em2b96p's Avatar
i dunno maybe a lack of oil???? * stop laughing at me* hahahahaah
em2b96p is offline
post #7 of 16 (permalink) Old 01-31-2006, 02:04 PM Thread Starter
eh-TEE-OH-clez
Aeteocles's Avatar
Images: 3
Yeah, I never upshift more than one gear at a time....I'll downshift several gears though.
post #8 of 16 (permalink) Old 01-31-2006, 02:20 PM
NewRedRider's Avatar
Images: 24
It sounds like you're not releasing pressure off the shifter before trying to upshift again. As you already know, a better oil will help shifting also.
NewRedRider is offline
post #9 of 16 (permalink) Old 01-31-2006, 02:23 PM
Ninja Master
Simonster's Avatar
Images: 28
i'm sure the dude knows how to shift.
your linkage probably needs adjustment and/or lubrication. definitely get it checked out at the service.
Read my cactus.
Simonster is offline
post #10 of 16 (permalink) Old 01-31-2006, 02:26 PM
Images: 24
Yeah, I was thinking along the lines of a different bike, shifter, and oil. Not him being a retard.
post #11 of 16 (permalink) Old 01-31-2006, 06:06 PM Thread Starter
eh-TEE-OH-clez
Aeteocles's Avatar
Images: 3
I'll try adjusting/lubricating the linkage and changing out the oil at the 600 mile service.
It's definitely not user error though. I can "clutch, throttle, shift" over and over, and the lever won't move. I have to consciously dig my foot way under the lever and PULL up on the lever to get it shift. It's definitely not clutch plates failing to resettle between shifts because of not letting go of the clutch. And it only happens between 2/3rd and 3rd/4th. There's no grinding noises, or anything funny. It's just feels like when you try to shift up into the 7th gear that isn't there...
post #12 of 16 (permalink) Old 01-31-2006, 07:18 PM
Ninja Master
Simonster's Avatar
Images: 28
that's why it's probably the shift linkage. basically, if it's out of alignment, it's trying to shift where there ain't no gear. happens more often w/ cages, because there's more slop, but the opposite is also true: bikes have less slop, but need higher degrees of precision in the linkage because the shift tolerances are greater.
Read my cactus.
post #13 of 16 (permalink) Old 02-01-2006, 03:35 AM
LtcOliverNorth's Avatar
I had something similar happen to me when I got some locktite on the linkage bearing with my 1KRR. If the linkage bearings (or the shif-lever itself) are stiff and not allowing the lever to "fall" all the way back down, then you can't "reset" the ratcheting action.
One way to test for this would be to ride the bike and push the lever DOWN before shifting. If you feel the lever going down or if after pressing down on the lever it clicks into gear with no problems then I'd say that was the problem.
On my 1KRR it was so subtle I had to manupulate the gearshift lever with my hand to notice that the movement was stiffer than normal.
2005 BMW R1200GS
2005 Kawasaki KLR650
1971 Honda CL350
LtcOliverNorth is offline
post #14 of 16 (permalink) Old 02-01-2006, 11:01 AM
Ninja Master
Simonster's Avatar
Images: 28
bwahahahahahahahahaa!
perhaps if you got a bigger gearshift lever...
Read my cactus.
post #15 of 16 (permalink) Old 02-01-2006, 07:13 PM
lol! Well, usually it does what it's supposed to on it's own so I don't have to use my hands at all.
2005 BMW R1200GS
1971 Honda CL350
post #16 of 16 (permalink) Old 02-09-2006, 01:20 AM
id have to say it the ider if your tring to up-shift into a 7th gear. if 1st and 2nd are ok it not linkage. What RPM you shifting?
salvagerider is offline
