battery not being charged - 600RR.net
post #1 of 10 (permalink) Old 02-22-2014, 06:16 PM Thread Starter
ok so i have a 09 600rr
i havnt started it in a while
i jumped it today and it died in about 15 mins
what test can i run with a volt meter to find the problem?
eddie7978 is offline
post #2 of 10 (permalink) Old 02-22-2014, 07:04 PM
jacob92icu's Avatar
How long is a while? Your battery could have a bad cell and not be able to hold a charge any longer. Try charging over night, then take a volt reading in the morning with black probe on negative terminal and red probe on positive. Record the reading and let it sit off the charger, then take another later in the day around dinner time. If its lost like 2-4 volts or more my vote is the battery. You can try jump starting it too, and check the voltage while its running. Should be 13.5-14.5, that will show good regulator and stater, so another sign battery can't hold a charge.
Also, there's a ton of info out there on this already, but this should help.
Good luck.
Love my 03 600RR
Build Thread:
https://www.600rr.net/vb/showthread.php?t=394793
Black And Gold!
jacob92icu is offline
post #3 of 10 (permalink) Old 02-22-2014, 07:16 PM
dagg92's Avatar
bring the battery to your local auto store, have it load tested. Simple
dagg92 is offline
post #4 of 10 (permalink) Old 02-22-2014, 08:46 PM
Everything you need to know is in this thread.
https://www.600rr.net/vb/showthread.php?t=266808
PatrickRR is offline
post #5 of 10 (permalink) Old 02-23-2014, 11:42 AM Thread Starter
ok so i started it and put the volt meter up to it was fluctuating from 13.5 to 12.5 and the lights were flickering and then it died and the volts on the batt dropped all the way down
post #6 of 10 (permalink) Old 02-23-2014, 09:45 PM Thread Starter
so would that be the battery? it only stays on for about 5-10 mins the dies
post #7 of 10 (permalink) Old 02-23-2014, 10:38 PM
Your charging system doesn't really make much power at idle. Go ride it or charge the battery properly
wibbly is online now
post #8 of 10 (permalink) Old 02-23-2014, 10:52 PM Thread Starter
oh i didnt know that
post #9 of 10 (permalink) Old 02-24-2014, 01:36 AM
jacob92icu's Avatar
I would either go get your battery tested at an auto store like previously stated (they will most likely tell you to get a new one) or give out a good charge, and then run the tests i stated above. The fluctuation part you mentioned is a little strange to me, but you should definitely charge properly it before proceeding.
Love my 03 600RR
Build Thread:
Black And Gold!
post #10 of 10 (permalink) Old 02-24-2014, 08:35 AM
X-treme1's Avatar
Feedback Score: 5 reviews
Your battery is shot, I just went through a similar problem.
You start the game with a full pot of luck and an empty pot of experience. The object is to fill the pot of experience before you empty the pot of luck.
2010 Leyla
X-treme1 is offline
