03 cbr won't start HELP - 600RR.net
post #1 of 35 (permalink) Old 02-24-2014, 07:12 PM Thread Starter
I just bought a 2003 cbr600rr from a guy didn't have a gas tank and was missing a couple of parts. Anyways, the bike wasn't about to start because It had no gas tank when I bought it. I bought the gas tank installed it. Added oil because you couldn't see it in the side glass ended up adding to much oil by accident. The fuel pump kick on and all gauges work every thing seems to be there spark plugs look new to me. But the bike only turns over it won't start. Doesn't even act like it wants to start. The tilt sensor is unmounted and just hanging freely. I'm clueless with bikes. Please help me out
03cbr600r is offline
post #2 of 35 (permalink) Old 02-24-2014, 07:16 PM
Austicus's Avatar
You'd be surprised how much this happens but make sure your kill switch isn't engaged.
Austicus is offline
post #3 of 35 (permalink) Old 02-24-2014, 07:16 PM
Lifetime Premium
wrathsrr's Avatar
It's the tilt sensor (bas).
Needs to be mounted and plugged in or bike won't start.
hey pound town is going to take over as a saying
Keeper of the Bucket-2W1R
My build thread...
[/I]https://www.600rr.net/vb/showthread.php?p=6111490#post6111490
wrathsrr is offline
post #4 of 35 (permalink) Old 02-24-2014, 07:28 PM Thread Starter
But it turns over. Would it still be the BAS?
post #5 of 35 (permalink) Old 02-24-2014, 07:51 PM
Lifetime Premium
wrathsrr's Avatar
Yes. Arrow needs to be pointing down. Just hanging there it's telling the bike it's tipped over.
My build thread...
wrathsrr is offline
post #6 of 35 (permalink) Old 02-24-2014, 08:01 PM Thread Starter
Is there a way to bypass it?
post #7 of 35 (permalink) Old 02-24-2014, 08:14 PM
Bridge_Jumper's Avatar
Feedback Score: 5 reviews
Isn't the arrow supposed to be pointing up?
2006 Honda CBR600RR Black Tribal Edition
2W1R - IceTitan
Bridge_Jumper is offline
post #8 of 35 (permalink) Old 02-24-2014, 08:15 PM
yeah, you gotta jumper the 2 outside wires
https://www.600rr.net/vb/showthread.php?t=270680
2W1R - IceTitan
post #9 of 35 (permalink) Old 02-24-2014, 08:24 PM Thread Starter
Awesome. One more question. The oil pressure light is on an doesn't turn off. Does that have any meaning?
post #10 of 35 (permalink) Old 02-24-2014, 08:35 PM
Lifetime Premium
Talk2M3Goose's Avatar
I have an 09', it doesn't turn off until the bike is actually running... well it should turn off if all is good.
2009 CBR600RR
DDM HIDs-Leyla Fairings w/Cowl-Spirit Line Tank Pad-Sato Racing Helmet Lock-Akra S/O-CBR Heaven FE/IT-BikeBolts Kit-Stomp Grips-Keiti CF Gas Cap-K&N HF Air Filter-DIY License Plate Relocator-Cycle Pirates Shift Lever-ZG Double Bubble-Pit Bull Spools-Tapeworks Graffiti Rimstripes-600rr.net Sock-PZR Zero GI-Tekacarbon CF Heat Shield & Rear Hugger-Driven EvoSpec Sprockets-EK 3D Blk Chain-Driven LE D3's-Smoked Hyper White Halo-1's-ASV C5's-RR Bar Ends-Q3's-RAM Mount-eTrex Legend
KCCO
Talk2M3Goose is offline
post #11 of 35 (permalink) Old 02-24-2014, 08:37 PM
Lifetime Premium
wrathsrr's Avatar
[QUOTE=Bridge_Jumper;6047265]Isn't the arrow supposed to be pointing up? [/QUOTE
The v points down...
https://www.600rr.net/vb/showthread.p...tipover+sensor
My build thread...
wrathsrr is offline
post #12 of 35 (permalink) Old 02-24-2014, 08:46 PM
[quote=wrathsrr;6047385]
oooh, mine is like the picture at the bottom of that thread where it says "up" with an arrow
2W1R - IceTitan
post #13 of 35 (permalink) Old 02-24-2014, 08:47 PM Thread Starter
In that link that you posted he said his fuel pump isn't priming. My fuel pump is priming
post #14 of 35 (permalink) Old 02-24-2014, 08:49 PM
the fuel lines could just be dry and not have fuel in them yet, you could try manipulating the throttle
2W1R - IceTitan
post #15 of 35 (permalink) Old 02-24-2014, 08:50 PM
Lifetime Premium
wrathsrr's Avatar
https://www.600rr.net/gallery/files/2/7/5/8/0012.JPG
My build thread...
wrathsrr is offline
post #16 of 35 (permalink) Old 02-25-2014, 09:27 AM Thread Starter
Bypassed the BAS still won't start. You guys have any other ideas? Everything seems to be working fine. The only thing I could think of it's not getting spark. It's getting fuel and air
post #17 of 35 (permalink) Old 02-25-2014, 09:34 AM
Lifetime Premium
Chances are this isn't it, but just in case I'll throw it out there. When I first bought my 09' I couldn't get it to start either and it was because the kill switch was just barely engaged even though it I had it toggled off. On my bike you can toggle off the kill switch like you would any other switch, but there is just this little extra you have to push it in to get it to fully disengage. I pressed the heck out of it and haven't had any problems since.
2009 CBR600RR
KCCO
post #18 of 35 (permalink) Old 02-25-2014, 09:38 AM
did you try manipulating the throttle a few times?
2W1R - IceTitan
post #19 of 35 (permalink) Old 02-25-2014, 09:40 AM Thread Starter
Yeah I tried holding it wide open/ half throttle.
post #20 of 35 (permalink) Old 02-25-2014, 09:41 AM
keep trying it between full throttle and zero throttle. It might take you a while to get the fuel drawn from the tank to the injectors
2W1R - IceTitan
post #21 of 35 (permalink) Old 02-25-2014, 09:44 AM Thread Starter
Ive tried. Still nothing. Even turned the idle up. Still nothing.
post #22 of 35 (permalink) Old 02-25-2014, 10:45 AM
Soponcio Virtual's Avatar
So... Bike fuel pump primes, and engine cranks but doesn't start... (everything normal and correct here!)
Check your plugs for spark and your gas tank for gas...
If you have spark and you have gas we can continue to troubleshoot!
Honda CBR600RR 2003 - Gone! (the blond)
Honda CBR600RR 2007 - On the road! (the brunette)
Soponcio Virtual is offline
post #23 of 35 (permalink) Old 02-25-2014, 10:49 AM Thread Starter
I just checked the spark and I have spark. And I do have gas in the gas tank
post #24 of 35 (permalink) Old 02-25-2014, 10:54 AM
did you make sure you didn't pinch any of the fuel hoses when lowering the fuel tank?
2W1R - IceTitan
post #25 of 35 (permalink) Old 02-25-2014, 11:04 AM
Could it be the HISS ???
I've never experienced an HISS ingnition blocking, so I don't know how the bike responds under this circumstance...
Strange... everything seems to be fine with the bike and you also said you tried pulling on the gas while hitting the start, right??
I know that kill switch issue won't let your fuel pump prime, so that is not the problem.
Geeeeeeeeeeees.... this is getting interesting/frustrating...
post #26 of 35 (permalink) Old 02-25-2014, 11:13 AM
there aren't HISS systems on US bikes (then again, I don't know where the OP is from).
I'm still sticking with the OP needing to treat the engine as if it were flooded (manipulating the throttle until it starts). It happened to me twice last year and each time I drained the battery a few times before I finally got it running
2W1R - IceTitan
post #27 of 35 (permalink) Old 02-25-2014, 11:23 AM Thread Starter
Do you guys think the spark plug gap could be to big?
post #28 of 35 (permalink) Old 02-25-2014, 11:25 AM
the plugs come pre gapped
2W1R - IceTitan
post #29 of 35 (permalink) Old 02-25-2014, 12:15 PM Thread Starter
The guy before be used a car plug gapper and gapped them to a .08
post #30 of 35 (permalink) Old 02-25-2014, 12:20 PM
they are iridium plugs, they aren't supposed to be gapped. If I remember right the gap is supposed to be 1mm anyways
2W1R - IceTitan
