low fuel indicator - 600RR.net
post #1 of 12 (permalink) Old 02-24-2006, 06:37 PM Thread Starter
bendu's Avatar
low fuel indicator
My low fuel indicator does not work. It will no longer blink. The amount of fuel displayed on the gauge works. Is there a relay for the low fuel blinker?
bendu is offline
post #2 of 12 (permalink) Old 02-24-2006, 06:41 PM
what do you mean not blink? maybe your not low enough... NEVER heard of it not blinking and the guage still working
nightdevil is offline
post #3 of 12 (permalink) Old 02-24-2006, 07:17 PM Thread Starter
bendu's Avatar
The indicator used to blink. Now the bike will run out of fuel before blinking.
bendu is offline
post #4 of 12 (permalink) Old 02-24-2006, 07:30 PM
Back in the Day
Moeman's Avatar
Images: 665
Feedback Score: 148 reviews
i think you fuel level sensor went bad simply cause it will not read or register the level of the fuel in the tank look into that & best of luck
Moeman is offline
post #5 of 12 (permalink) Old 02-24-2006, 08:11 PM
madbrown75's Avatar
Mine never blinks, but I don't know if I've ever been low enough. I can get gas and put 4.3 gallons in though and it still wont be blinking.
CBR RIDERS FOR LIFE
madbrown75 is offline
post #6 of 12 (permalink) Old 02-25-2006, 05:12 PM Thread Starter
bendu's Avatar
I think the sensor is fine. The level of fuel is registered. However the indicator does not blink when fuel reaches the reserve level.
bendu is offline
post #7 of 12 (permalink) Old 02-25-2006, 05:25 PM
Back in the Day
Moeman's Avatar
Images: 665
did you unplug the cluster and plug back again
may be the main connector got loose
Moeman is offline
post #8 of 12 (permalink) Old 02-25-2006, 08:53 PM
Thats weird i had my bike do that to me a couple times. i've noticed if i just turn the key over the light will blink but when i start it the light does not blink. this has only happened 3 times. but once it caused me to run out of gas like a loser :( if u find a solution post it up. but sounds like a loose connection or short of some sort
davedog665 is offline
post #9 of 12 (permalink) Old 02-25-2006, 09:28 PM
resqme's Avatar
Images: 2
how do you know it's reaching the reserve level?...:headscrat I've never seen mine blink.
resqme is offline
post #10 of 12 (permalink) Old 02-25-2006, 09:32 PM
rdss's Avatar
Images: 3
I let mine blink once just to see if it worked and have filled up at 100-110 miles. I figure its better safe than sorry!
Black '04 CBR 600RR
Mods: Silver wing removed, all black Corbine Seat,
Bagster Tank Cover, Scorpion Titanium Slip-on
and the 4 dollar FE mod with Shock Racing LED turnsignals.
rdss is offline
post #11 of 12 (permalink) Old 02-25-2006, 10:46 PM Thread Starter
bendu's Avatar
Fuel capacity is 4.8 gallons including the .9 gallon reserve. So if you are putting more that 4 gallons in and your indicator isn't flashing, it probably doesn't work.
bendu is offline
post #12 of 12 (permalink) Old 02-26-2006, 09:04 PM
can you reset your bike by unhooking the battery? I know it electronis sometimes they just need to be reset. I dont how you do this on an rr but it might be an idea.
slow1onrr is offline
