no power electrically - 600RR.net
post #1 of 8 (permalink) Old 03-13-2014, 01:30 AM Thread Starter
so I went up to my bike today to try to leave when I turn my key on there was no power to the dash I could not start my bike my clock was not on nothing so I pull my battery off charged took it back out to the bike plug everything back up the way it should be turn my key on the lights came on barely my temperature fan has not worked in a year and all of a sudden the cuts on when the key is off and also when I turn the key home check the battery my charger says its good not sure what else to doit's late here so I'm going to do more trouble shooting tomorrow but if anybody can help it would be appreciated Thanks for yaknowledge
fail.com is offline
post #2 of 8 (permalink) Old 03-13-2014, 05:43 AM
Lifetime Premium
wrathsrr's Avatar
You can try checking your fuses by the battery and behind the left mid also, but sounds like a short somewhere in the system. If what I read right (confusing towards the middle, lol). Your saying fan hasnt worked in a year ? Now it does randomly with key on or off?
This could be your culprit.
hey pound town is going to take over as a saying
Keeper of the Bucket-2W1R
My build thread...
[/I]https://www.600rr.net/vb/showthread.php?p=6111490#post6111490
wrathsrr is offline
post #3 of 8 (permalink) Old 03-13-2014, 05:44 AM
Wrist-Twist-Rookie's Avatar
Battery chargers only read the voltage while there is no load on the battery. I bad battery can read good voltages after being charged. I would say you need a new battery.
Wrist-Twist-Rookie is offline
post #4 of 8 (permalink) Old 03-13-2014, 10:42 AM
G Money's Avatar
Definitely get it load tested. I could roll start my bike with a battery that showed "0% Battery Life" on a Honda Dealership's battery load tester. I watched him hooked up and then he chuckled a little bit when the reading came up on the screen.
'03 600 RR - ~33,000 miles (14,000 from me)
Yoshimura RS-5 Slip on - Arrow Stainless Headers - BMC Street Filter - PCV - EK 520 Chain on Driven Sprockets - CoreMoto Stainless Lines (F+R) - Dan Kyle PAIR Delete - The2Wheels Shorty Levers - Vortex V3 Rearsets - Woodcraft Frame Sliders & Bar Ends - Woodcraft Stator and Clutch Covers - Cox Radiator Guard - Renthal Dual Compound Grips - 1000RR Kill Switch and Throttle Housing - TST IT and FE - Proton Flushmounts
G Money is offline
post #5 of 8 (permalink) Old 03-13-2014, 11:05 AM
Lifetime Premium
wrathsrr's Avatar
You guys are saying a bad battery is causing this?
My build thread...
wrathsrr is offline
post #6 of 8 (permalink) Old 03-13-2014, 11:27 AM
G Money's Avatar
I didn't read that part I guess. That's definitely not a symptom of battery issues.
G Money is offline
post #7 of 8 (permalink) Old 03-14-2014, 06:03 AM
Nico's Avatar
ok.
So to start with, what you've written there makes almost no sense at all. Can you spell it out again one point at a time. When doing so, describe what you did and what you observed. Then start a new line and say what you did next and subsequently observed etc. One action and set of observations per block of text, and all in chronological order.
Next, what year bike is it? What mods have been done?
Once you've got a legible description of the issue I'll be more than happy to help you work through it.
Nico is offline
The Following User Says Thank You to Nico For This Useful Post:
Canadian_Wanabi (05-21-2014)
post #8 of 8 (permalink) Old 03-14-2014, 06:31 AM
No, sounds like he has two separate issues.. One thats been causing no fans, or intermittent gauges, for over a year?.. And the other sounds like a dead battery.
