problem with rear brake - 600RR.net
post #1 of 11 (permalink) Old 03-14-2014, 01:08 PM Thread Starter
loucasp's Avatar
hi guys!! i have a problem with my cbr600rr 07.. my rear brake was weak and i changed the brake oil and was still weak so i changed the brake pad and is still weak.. when i push the brake hard the tyre dont block.. there is no air in the brake lines... what is the problem? i dont have rear brake.... HELLLPPPP PLEASEEE!!!!
"I try to have a different relationship with the bike. I don't give it a name, but I always speak with it. I don't know if the other riders do the same. This is not only a piece of metal - there is a soul." - ''Valentino Rossi''
http://www.youtube.com/user/loucasp1/videos
loucasp is offline
post #2 of 11 (permalink) Old 03-14-2014, 01:11 PM
Seksas's Avatar
Feedback Score: 32 reviews
i mean it sounds like an air problem is your brake pedal adjusted properly to the cylinder the two lil nuts? not sure how that would affect it tho.
"It's not the size of the dog in the fight, it's the size of the fight in the dog. Mark Twain
https://www.600rr.net/vb/176-rr-other-brands-bike-build/527578-seksas-track-build.html
04 CBR600rr Track bike partout : https://www.600rr.net/vb/106-03-06-rr-parts/581209-03-04-track-bike-part-out-pcv-yoyodyne-so.html
Seksas is offline
post #3 of 11 (permalink) Old 03-14-2014, 01:18 PM
swan-rr5's Avatar
what's a rear brake?
it's not particularly strong to begin with but check that there's no crap sticking the piston. other than that I don't know, I only rarely use it at the track & it's not to stop
swan-rr5 is offline
post #4 of 11 (permalink) Old 03-14-2014, 01:51 PM
could be the piston is stuck but also as it's a sliding caliper it could be the caliper is corroded onto the pin and not sliding.
youngy is offline
post #5 of 11 (permalink) Old 03-14-2014, 05:30 PM
mine is exactly the same,its just the way it is,mine will just about lock wheel on gravel but not on tarmac,as others said its more a control brake as opposed to all out stopping,i reckon you might just have to put up with it
07RR//r&g frame sliders,tst IT,fork+swingarm protectors,r&g rad guard,red asv,s
,red lowers,yoshi rs5,oem seat cowl,vcr rearsets,stomp grip,,headlight covers,0.875 springs,,flush mounts,fe,spools,oem numberboards,rim tape,cam mount ,db screen,lightech carbon mirrors,res socks,gi-pro,led pegs,carbon tank panels/yoke trim/ hugger/chain guard/front fender/fuel trim,carbon wrapped sub frame,gb engine covers,numerous carbon wrapped pieces,RED mids, suspension set up
ash2020 is offline
post #6 of 11 (permalink) Old 03-15-2014, 07:46 AM
tlambert_01's Avatar
I would check to see how tight the brake pads are against the rotor when u push the brake. They could just be out of adjustment.
'09 CBR 600RR
- Two Brothers carbon fiber black series slip on exhaust
- Power Commander V
- Autotuner
- Zero Gravity double bubble dark smoke windscreen
- BK Moto V2 dual halo/demon eye projector kit
- TST smoke integrated taillight
- ASV F3 shorty levers
- flush mount front signals
- Galfer steel braided brake lines and pads
tlambert_01 is offline
post #7 of 11 (permalink) Old 03-15-2014, 09:09 AM
BOTM winner 03/15
dkid's Avatar
Feedback Score: 5 reviews
^This.
Mine was similar until I removed and cleaned up the calliper inc slider pin. The pin was corroded which made it difficult for the pads to slide properly. I did install HEL stainless steel braided brake lines at the same time and I'm pretty sure that helped with feel too.
UK '08 CBR600RR build thread: link *SOLD*
BOTM Winner 03/15
dkid is offline
post #8 of 11 (permalink) Old 03-15-2014, 09:48 AM
Lifetime Premium
Talk2M3Goose's Avatar
I have the same problem OP. To stop via my rear brake I literally have to shift all my weight to my right foot and pretty much stand up and even then I'm not sure it would ever lock up on anything other than gravel. I replaced the pads, replaced the fluid, bled the lines and cleaned all relevant rear brakes parts and it MAYBE helped a tiny bit. But 2 weeks later (now) my rear brakes are no better than they were before I cleaned/replaced everything. I mean the only things I can think of that may help now would be an all new MC - kinda drastic, or like someone else said, new stainless steel brake lines? Honestly, I wish I had access to another 600 to compare my rear brakes against to see if this "weak" behavior is just normal for cbr's.
2009 CBR600RR
DDM HIDs-Leyla Fairings w/Cowl-Spirit Line Tank Pad-Sato Racing Helmet Lock-Akra S/O-CBR Heaven FE/IT-BikeBolts Kit-Stomp Grips-Keiti CF Gas Cap-K&N HF Air Filter-DIY License Plate Relocator-Cycle Pirates Shift Lever-ZG Double Bubble-Pit Bull Spools-Tapeworks Graffiti Rimstripes-600rr.net Sock-PZR Zero GI-Tekacarbon CF Heat Shield & Rear Hugger-Driven EvoSpec Sprockets-EK 3D Blk Chain-Driven LE D3's-Smoked Hyper White Halo-1's-ASV C5's-RR Bar Ends-Q3's-RAM Mount-eTrex Legend
KCCO
Talk2M3Goose is offline
post #9 of 11 (permalink) Old 03-15-2014, 09:59 AM
Asabon94's Avatar
Ya like everyone stated rear brake is very weak. When used with the front I barely feel a difference. it's a control stop to balance weight. When I put my ss lines on it stiffened up the pedal ALOT.
Sent from Motorcycle.com App
Asabon94 is offline
post #10 of 11 (permalink) Old 03-16-2014, 12:29 PM Thread Starter
loucasp's Avatar
thnx guys i will check it!
loucasp is offline
post #11 of 11 (permalink) Old 03-16-2014, 01:42 PM
you may have glazed pads /rotor.....and/or seized pistons?
clean pad faces and rotor with sandpaper (NOT silica based sandpaper)
check for seized pistons....you can clean them up and restore movement w/o taking the caliper apart....if not in too bad a condition.
then brake cleaner fluid.....ride it and do a series of increasing speed/braking effort stops to bed the pads/rotor.
I have ebc hh pads galfer ss lines and can easily get rear to skip/skid with medium foot pressure....
tary preisser is offline
