bike not starting - Cbr600rr 2006 - 600RR.net
post #1 of 14 (permalink) Old 03-24-2014, 06:00 AM Thread Starter
Hi, my cbr600rr yr 2006 is not starting. I was riding the bike without any issues. I parked the bike for 2 hours, then trying to start it again. When turning the keys, I noted that the headlights were off, but there is no sound of the fuel pump, and the oil indicator is lighting, even the flasher is not working at all. When pressing on the starter, the starter is turning, but the bike won't start. I checked all fuses and connection and everything is fine.
please guide me accordingly.
thanks & Regards
Anil
rave_bach is offline
post #2 of 14 (permalink) Old 03-24-2014, 07:10 AM
Lifetime Premium
wrathsrr's Avatar
Check your killswitch to see if its in the off position. Bike in Neutral? If thats all good check battery and connections there.
Your saying with key on, you have no headlights? Did you check fuses behind the left mid fairing?
hey pound town is going to take over as a saying
Keeper of the Bucket-2W1R
My build thread...
[/I]https://www.600rr.net/vb/showthread.php?p=6111490#post6111490
wrathsrr is offline
post #3 of 14 (permalink) Old 03-24-2014, 07:32 AM Thread Starter
Hi. Thks for your reply.
the killswitch is in off position and as mentioned the starter is turning else it won't turn. Bike is on neutral and battery is fully charged and all connections near battery is correct The fuse in the mid fairing is also correct.I also tried to push start the bike, but in vain.
post #4 of 14 (permalink) Old 03-24-2014, 09:05 AM
Bridge_Jumper's Avatar
Feedback Score: 5 reviews
the starter still turns when the kill switch is set to "not run"... you might wanna check to see that you have it on "run"
There's also a fuse by the battery that you can check
2006 Honda CBR600RR Black Tribal Edition
2W1R - IceTitan
Bridge_Jumper is offline
post #5 of 14 (permalink) Old 03-25-2014, 04:53 AM Thread Starter
The problem has been located. There is 2 plugs in the middle fairing blue & white. While putting a wire testing device in the white plug on the 3rd or 4th position (a red and white wire), I noticed that the injection noise is being made as usual. I then try to start the bike and it started, but the headlight was still not working and after 2 mins the headlight comes in and everything was fine.
I put some WD40 spray into the plug as there was some white substance in the plug which was due to rust. While putting the fairing, the problem started again, the bike won't start as the injector noise was not heard a new.
What needs to be checked again pls?
post #6 of 14 (permalink) Old 03-25-2014, 09:37 AM
G Money's Avatar
Pictures are worth a 1000 words my friend. White substance in the plug sounds like possible corrosion, which could be interrupting the circuit. But I can't decipher what plug you are describing.
'03 600 RR - ~33,000 miles (14,000 from me)
Yoshimura RS-5 Slip on - Arrow Stainless Headers - BMC Street Filter - PCV - EK 520 Chain on Driven Sprockets - CoreMoto Stainless Lines (F+R) - Dan Kyle PAIR Delete - The2Wheels Shorty Levers - Vortex V3 Rearsets - Woodcraft Frame Sliders & Bar Ends - Woodcraft Stator and Clutch Covers - Cox Radiator Guard - Renthal Dual Compound Grips - 1000RR Kill Switch and Throttle Housing - TST IT and FE - Proton Flushmounts
G Money is offline
post #7 of 14 (permalink) Old 03-26-2014, 12:22 AM
Check your fuses, plugs and wire harness for the headlights... They put a safety on the bikes that if your headlights dont work, the bike wont turn on for safety. Try to push start the bike and see if it starts...
Cbr247 is offline
post #8 of 14 (permalink) Old 03-26-2014, 12:32 AM
Haha what??? Not a chance.
wibbly is online now
post #9 of 14 (permalink) Old 03-26-2014, 01:24 AM
Haha how much you wanna bet that some bikes have that safety? I had a blown headlight fuse in my cbr and bike wouldnt start, changed the headlight fuse and bike started right away and has always started since.
Cbr247 is offline
post #10 of 14 (permalink) Old 03-26-2014, 01:29 AM
This was on my 07 cbr1000rr. I know ppl remove headlight fuses to track bikes etc... Just trying to help op figure out the problem, if you have a better solutiom, chime im
Cbr247 is offline
post #11 of 14 (permalink) Old 03-26-2014, 01:35 AM
Unplug your headlights. Guaranteed start.
The hot for the headlight runs to the kill switch, where it is normally closed with the start button. This turns your headlight off when cranking for stronger starting. It's possible that this hot is used to fire the starter relay, I'd have to check though.
It is absolutely NOT a safety
post #12 of 14 (permalink) Old 08-26-2014, 03:49 AM
SoDamnStreet's Avatar
Images: 3
same thing happened
under the right side fairings near the tank and air ducts there are two plugs one with 4 wires and a set with 2 wires. the plug with 4 runs to the start,run,off assembly. i cleaned used wd all that good stuff and it happened again. same plug problem, repeated the cleaning process connected secured with small zip tie works like a champ. i am thinking for whatever reason condensation is building in that plug and causing this issue. well anyways worked for me. oh yeah sorry there are no pics bike already reassembled
SO DAMN STREET.
FAMILY 1ST M.C. LOUISVILLE KY
SoDamnStreet is offline
post #13 of 14 (permalink) Old 08-26-2014, 02:16 PM
Andywear's Avatar
they have an electronic cleaner that would be better to use then WD-40.
Its in an aerosol can.
this place is full of trolls-
EAD.
Andywear is offline
post #14 of 14 (permalink) Old 08-26-2014, 03:03 PM
Andywear's Avatar
I used it on Jeep that I always left in the rain. This dimmer switch worked great after I cleaned it.
EAD.
Andywear is offline
