Front led turn signals - 600RR.net
post #1 of 10 (permalink) Old 03-25-2014, 07:49 AM Thread Starter
Front led turn signal wiring
I have factory turn signal wiring harness with 3 prongs and the led turn signal wires only has 2 does anyone know where I can get a wiring harness for this problem or know what I can do. I prefer not to hard wire them together. Thanks
Mnaylor is offline
post #2 of 10 (permalink) Old 03-25-2014, 12:33 PM
just dont connect the running light wire from your oem plugs, if you want plug and play cut your oem wires from orange and blue plug leaving 5 or 6 inches of wire on them and solder/splice the 2 appropiate oem wires onto the 2 wires from your new led turn signals
07RR//r&g frame sliders,tst IT,fork+swingarm protectors,r&g rad guard,red asv,s
,red lowers,yoshi rs5,oem seat cowl,vcr rearsets,stomp grip,,headlight covers,0.875 springs,,flush mounts,fe,spools,oem numberboards,rim tape,cam mount ,db screen,lightech carbon mirrors,res socks,gi-pro,led pegs,carbon tank panels/yoke trim/ hugger/chain guard/front fender/fuel trim,carbon wrapped sub frame,gb engine covers,numerous carbon wrapped pieces,RED mids, suspension set up
ash2020 is offline
post #3 of 10 (permalink) Old 03-25-2014, 02:42 PM
lilbuddy16's Avatar
Feedback Score: 5 reviews
I got mine here. http://tripageled.com/store/
2012- CBR250 ~ Sold
2006- CBR600rr ~ Sold
2012- CBR600rr ~ Sold
lilbuddy16 is offline
post #4 of 10 (permalink) Old 03-25-2014, 05:33 PM Thread Starter
I'm not trying to sound stupid but I'm new to all this bike stuff seeing this is my first bike but do you know what it's called
And I don't have a soldering gun that's why I didn't wanna cut the wires
Mnaylor is offline
post #5 of 10 (permalink) Old 03-25-2014, 09:00 PM
lilbuddy16's Avatar
No problem man. Don't worry about being new. Everyone is new the first time. So it's called the front signal harness.
Did your flush mounts come with a harness?
Go to the vendor section / tripage then PM Tristan (I think that's his name). I had the same question a few weeks ago. Basically you just pull one of the wires out and tape it up.
The three wires are power, flash and ground. So it's up to you on how you want the lights to work. I opted to not have constant power running to mine so there off unless my signal is on.
Tripage has great customer service. The part you need is maybe $7 if I remember.
2012- CBR250 ~ Sold
post #6 of 10 (permalink) Old 03-25-2014, 10:07 PM
tripage's Avatar
Feedback Score: 91 reviews
Order this and in the comments put "running/signals" and we will make your signals running/signals using 2 wires and give you some heat shrink to make this as easy to install as possible. I will explain with the order. Welcome to the forum. T
http://tripageled.com/store/index.ph...product_id=150
Owner
Tristan Page
[email protected]
[email protected]
tripage is offline
post #7 of 10 (permalink) Old 03-25-2014, 10:25 PM Thread Starter
This is what I have I need the part the male end that connects into the 3 prong oem female end but my turn signals only have 2 wires coming from it I'm probably asking the same thing but I'm just confused
Mnaylor is offline
post #8 of 10 (permalink) Old 03-25-2014, 10:37 PM
tripage's Avatar
Yes, order above with the comments and we will take care of you. Signal will work just like OEM. T
Owner
Tristan Page
[email protected]
[email protected]
tripage is offline
post #9 of 10 (permalink) Old 03-26-2014, 06:15 AM Thread Starter
Ok thank you
Mnaylor is offline
post #10 of 10 (permalink) Old 03-26-2014, 07:54 AM
tripage's Avatar
Also if you haven't thought of this. A flasher relay will correct your flash rate after switching to led's your signals will flash faster than normal.
http://tripageled.com/store/index.ph...&product_id=58
Owner
Tristan Page
[email protected]
[email protected]
tripage is offline
