05 600rr integrated tail light problems - 600RR.net
post #1 of 29 (permalink) Old 03-30-2014, 07:25 PM Thread Starter
So I installed a integrated tail light on my 05 CBR 600rr and I used a test light to figure out the wiring. Everything is wired correctly. I'm not getting anything from the tail light. Turn signals stay lit up solid on the cluster but not on the tail light. Running light on the tail light nor the brake light work. But when I plug in the stock tail light it works perfectly fine. What is up with this? I checked fuses, wiring, everything and I'm stumped.... any help would be greatly appreciated. Thanks guys
redz28 is offline
post #2 of 29 (permalink) Old 03-30-2014, 07:33 PM
Back in the Day
Moeman's Avatar
Images: 665
Feedback Score: 148 reviews
You need a flasher relay or add resistors to solve the turn signal blinking rate issue
http://tripageled.com/store/index.ph...&product_id=58
Tripage is a site sponsor & vendor and will hook you up awesome customer service
Moeman is offline
post #3 of 29 (permalink) Old 03-30-2014, 07:43 PM Thread Starter
I forgot to mention, before I wired the tail light, I hooked up the signals and the ground and they worked fine but when wired the tail light and hooked everything up is when everything stopped working
redz28 is offline
post #4 of 29 (permalink) Old 03-30-2014, 08:00 PM
tripage's Avatar
Feedback Score: 91 reviews
You have led front signals? Do you have them wired as running/signals? Sounds like you do and that is why the signals are coming up on with the taillight and that will cancel the running lights. Flasher relay is most likely needed as well if you have led front/rear signals. Let me know about the front signal 2 wires wired into 3 most likely and I can let you know the fix for this. T
Owner
Tristan Page
[email protected]
[email protected]
tripage is offline
The Following User Says Thank You to tripage For This Useful Post:
Moeman (03-30-2014)
post #5 of 29 (permalink) Old 03-30-2014, 08:40 PM Thread Starter
No fronts at all
redz28 is offline
post #6 of 29 (permalink) Old 04-02-2014, 06:21 AM Thread Starter
Okay so when the tail light is hooked straight to the battery, every function works correctly but when hooked to the harness, same as before, nothing. All fuses are good. Is there a relay that could be bad?
redz28 is offline
post #7 of 29 (permalink) Old 04-02-2014, 07:35 AM
Miweber929's Avatar
No, sounds like it's simply not hooked up right, most likely the ground is not in the right place from your description because running light dies not run through a relay.
Look at the wiring diagram in your service manual and compare wire colors to functions, not simply matching colors. If it works on the bench and stock still works, it's got to be a wiring issue. On an LED light positive and ground matter, on an incandescent bulb it doesn't and can be backwards, think you might have something swapped. Otherwise snap a pick of the wiring so we know more.
Most IT's are 5 wires: left TS, right TS, brake, running and ground; your bike will have separate grounds for the turn signals which won't be used in this situation.
Mike
Miweber929 is offline
post #8 of 29 (permalink) Old 04-02-2014, 09:00 AM
tripage's Avatar
^^^^^^ Correct. If you post a picture we can help with wiring.
Owner
Tristan Page
[email protected]
[email protected]
tripage is offline
post #9 of 29 (permalink) Old 04-02-2014, 09:07 AM Thread Starter
Everything is wired correctly. As stated before, I used a test light to determine what prong was what function in the factory harness. When I hook just the ground and one function up (left signal, right signal, etc) still nothing.
redz28 is offline
post #10 of 29 (permalink) Old 04-02-2014, 09:29 AM
tripage's Avatar
Have you metered the ground wire on the 3 pin to the bike? If you have ground and one of the signal wire going to the + they turn on then?
Owner
Tristan Page
[email protected]
[email protected]
tripage is offline
post #11 of 29 (permalink) Old 04-02-2014, 10:00 AM
I think that as you have no front signals the rears won't work correctly. There is not enough load on the relay to heat it up.
youngy is offline
post #12 of 29 (permalink) Old 04-02-2014, 11:02 AM
tripage's Avatar
That is correct with the signals, it will turn on solid and not flash but the running/brake should still work on the taillight. You have no signals up front? Make sure none of the wires are touching. If your running/signal wires are shorted together then your rear signals will come on because the running light power will backfeed to the integrated taillight and that will turn on the signals and cancel the running lights. Sounds like that is your problem.
Owner
Tristan Page
[email protected]
[email protected]
tripage is offline
post #13 of 29 (permalink) Old 04-02-2014, 01:59 PM Thread Starter
The fronts aren't cut, still have factory plug so no short there. The front running light still works. When I plug in the turn signals for the IT is when the signals on the cluster will stay lit but nothing from the IT. And still no running light in IT
redz28 is offline
post #14 of 29 (permalink) Old 04-02-2014, 03:14 PM
tripage's Avatar
Something isn't right if your signal in the cluster is turning on by itself. That means that the cluster is getting power from something to turn it on. If you power up the taillight without connecting the signals in the taillight does this happen?
Owner
Tristan Page
[email protected]
[email protected]
tripage is offline
post #15 of 29 (permalink) Old 04-02-2014, 06:04 PM Thread Starter
No, only when the signals are plugged in. But even without the signals plugged in still nothing from the light. I just now remembered, when I was plugging in each function to test if it worked I accidentally touched power the running light with the ground pigtail, but It just popped the fuse so I replaced it and the running light worked again. Then I put all the pig tails in their connector and plugged everything in and got nothing
redz28 is offline
post #16 of 29 (permalink) Old 04-02-2014, 08:12 PM
tripage's Avatar
Take a picture of your taillight wires and bike wires including the signals. Just shooting in the dark without pictures.
Owner
Tristan Page
[email protected]
[email protected]
tripage is offline
post #17 of 29 (permalink) Old 04-02-2014, 08:17 PM Thread Starter
I got the tail and the factory light back on it right now cause I been riding this week. I was going to wait til I had some info before I tore it back down. But, the wiring is correct, I can assure that. Downloaded a service manual and double checked everything
redz28 is offline
post #18 of 29 (permalink) Old 04-02-2014, 08:35 PM
tripage's Avatar
If the wiring is correct and you checked it on the battery and it works then it would work, right? I don't mean to doubt you but the signals won't come on in the cluster unless something is wrong with the light. Something may be wrong with it.
Owner
Tristan Page
[email protected]
[email protected]
tripage is offline
post #19 of 29 (permalink) Old 04-02-2014, 08:36 PM
Miweber929's Avatar
Test light is incandescent, that was my point; still feel like ground and hot is mixed up somewhere. If stock works, you bike should be fine.
Take a pic, we're guessing without it.
Mike
post #20 of 29 (permalink) Old 04-02-2014, 08:57 PM Thread Starter
If this is something along the lines of my problem, where do I need to start to fix it?
redz28 is offline
post #21 of 29 (permalink) Old 04-02-2014, 09:22 PM
tripage's Avatar
I would start with making sure the light works. Connect it to the battery and go through everything. Running light/brake and each signal. Confirm it's the light and not the bike or the other way around that is causing the problem. Then I would connect one part of the light at a time. I would do the ground and running light first. If it's good then connect the brake and check it. If all good connect one signal and then the other.
Owner
Tristan Page
[email protected]
[email protected]
tripage is offline
Miweber929 (04-03-2014)
post #22 of 29 (permalink) Old 04-02-2014, 10:21 PM Thread Starter
I have already done that and everything works when connected straight to battery
redz28 is offline
post #23 of 29 (permalink) Old 04-03-2014, 04:29 AM
a lot of the responders here have asked for photos...........
youngy is offline
post #24 of 29 (permalink) Old 04-03-2014, 06:50 AM Thread Starter
I know but i haven't had time to take it back apart to take some. If the wiring is correct why are pics needed though?
redz28 is offline
post #25 of 29 (permalink) Old 04-03-2014, 07:07 AM
well you know, if I was asking for help ,and all these guys were trying to help me but asked for a pic to make it easier, I'd be getting a pic uploaded.
if you want to be argumentative about how people can help, you carry on.
good luck.
youngy is offline
post #26 of 29 (permalink) Old 04-03-2014, 09:03 AM Thread Starter
I'm not trying to argue at all, don't take it that way
redz28 is offline
post #27 of 29 (permalink) Old 04-03-2014, 09:59 AM
Miweber929's Avatar
Based on the symptoms you've described your wiring is not correct, that is what we are trying to help you determine. Long distance troubleshooting is not easy and with nothing to go on but your insistence it's wired right we're all left guessing without pics. If stock works fine, and off the bike the light works fine, there has to be something with the wiring, load or the light itself.
Help us help you, and visually is the best. Follow the last post by Tripage, it's the best way.
Mike
post #28 of 29 (permalink) Old 04-03-2014, 11:12 AM Thread Starter
I'll try to get some up this evening after work, thanks
redz28 is offline
post #29 of 29 (permalink) Old 04-24-2016, 07:32 PM
Ace 1's Avatar
Did u check the fuse?
Ace.
Ace 1 is offline
