Turn signals stay on after swapping rear signals to LED - 600RR.net
post #1 of 14 (permalink) Old 04-11-2014, 11:25 PM Thread Starter
Exerstine's Avatar
Title pretty much says it all. I have Had front LED turn signals for awhile now and everything was fine. The signals would blink faster but I kind of liked the faster rate. Anyways just a few days ago I bought just some regular LED rear signals and when installed the signals just stay on instead of blink.
I have seen these flasher relays being added in on the harness, I would like to avoid that. Is there another way to resolve this issue?
Exerstine is offline
post #2 of 14 (permalink) Old 04-11-2014, 11:33 PM
X-treme1's Avatar
Feedback Score: 5 reviews
The LED flasher relay is the best way to go. You don't have to add it into the harness, just remove the stock one and replace with the LED one. They cost about $20 and take two minutes to install.
Sent from Motorcycle.com App
You start the game with a full pot of luck and an empty pot of experience. The object is to fill the pot of experience before you empty the pot of luck.
2010 Leyla
X-treme1 is offline
post #3 of 14 (permalink) Old 04-12-2014, 02:22 AM Thread Starter
Exerstine's Avatar
How can I tell the difference? If there's a link I would gladly purchase one as long as I don't have to add the two wires into the harness
post #4 of 14 (permalink) Old 04-12-2014, 03:18 AM
Here is what I have. It says 2004-200 CBR1000RR but it's the same for 2007-2012 CBR600RR.
Installation is simple. It's plug and play so all you need to do is remove stock relay and plug in new the one. I'll try to find a picture for you as mine is being shipped at the moment.
pandafx is offline
post #5 of 14 (permalink) Old 04-12-2014, 05:50 AM
gioarge's Avatar
I have European version (4 pins relay) and bought the electronic one from tripage here on the forum
Once installed no difference with OEM
--- 2013 CBR600RR ---
My Build Thread
gioarge is offline
post #6 of 14 (permalink) Old 04-12-2014, 09:22 AM Thread Starter
Exerstine's Avatar
This helps me tremendously! Thanks bro.
post #7 of 14 (permalink) Old 04-12-2014, 02:26 PM
aeo37's Avatar
Pretty sure that only 07+ is a plug and play. 03-06 you have to kind of splice it into your harness
What year is your bike?
aeo37 is offline
post #8 of 14 (permalink) Old 04-12-2014, 04:48 PM
the 4 LED flashers do not draw enough current to make the thermal relay switch over. you have to either fit resistors or an LED flasher relay. the relay on the 03-06 is in the gauge cluster iirc.
youngy is offline
post #9 of 14 (permalink) Old 04-13-2014, 01:44 AM Thread Starter
Exerstine's Avatar
I had tried fitting some resistors onto the turn signals and it never made them blink just stay on and they were dim. I guess if I have to, I will wire the relay into the blue connector I just don't like the idea but it'll get my signals working
post #10 of 14 (permalink) Old 04-13-2014, 03:09 AM Thread Starter
Exerstine's Avatar
My bike is a 2003. I just purchased the flasher relay from tripage
post #11 of 14 (permalink) Old 04-13-2014, 06:23 AM
it sounds like you did not fit the resistors correctly.
youngy is offline
post #12 of 14 (permalink) Old 04-13-2014, 06:44 AM
Nico's Avatar
Resistors go in parallel to the lights, not in series.
LED flasher relay is however a better option.
Nico is offline
post #13 of 14 (permalink) Old 04-13-2014, 10:20 AM Thread Starter
Exerstine's Avatar
I may not have. I am no means a professional lol. How would one go about wiring correctly?
post #14 of 14 (permalink) Old 04-13-2014, 10:57 AM
read what Nico said above............. the resistor is wired across the LED indicator in order to load the relay without dropping the voltage to the LEDs.
youngy is offline
