RPM and gear Doesn't work on my 03 cbr 600rr - 600RR.net
post #1 of 3 (permalink) Old 04-20-2014, 12:07 AM Thread Starter
When I start it up the rpm swings up then down just like usual when you start up.
Everything else on the cluster works except my gear indicator.
Mph works
Gas works
Everything like usual
I've check fuses under middle left cawl but I'm not sure if that's the only place fuses are located.
If anyone knows how to fix this or have the same problem let me know. Thanks
CBRtai is offline
post #2 of 3 (permalink) Old 04-20-2014, 01:00 PM
if the tacho isn't working then the gear indicator won't work either.
youngy is offline
post #3 of 3 (permalink) Old 04-20-2014, 03:30 PM
aeo37's Avatar
Did this just started to happen out of no where, or was the buke wrecked?
When i wrecked, the plug that goes to the cluster got ripped out and mangled and shorted out. When i replaced the harness and cluster, my tach would only do the initial sweep.
In another thread, Nico had said that it was a bad ECM/ ECU. So it could be you need another one. I'll see if i can find that thread for you
OK, I found the thread https://www.600rr.net/vb/showthread.php?t=248147
aeo37 is offline
