starting problems - 600RR.net
post #1 of 7 (permalink) Old 03-14-2006, 10:22 PM Thread Starter
starting problems
i need help (Bad). My 05 wont start it turns over but never fires. Iam not sure if the fuel pump is working or if it's flooded? This problem all started when I pulled off the upper cowl to replace it, after a high side and a broken thumb (Ouch!). I also install hotbodies's flushmounts with no resistors yet, could this be the problem?
DaMoN is offline
post #2 of 7 (permalink) Old 04-15-2006, 08:31 PM
same problem
hey are your head lights off when if so i think my bike is having the same problem
nighthawk41186 is offline
post #3 of 7 (permalink) Old 04-15-2006, 08:44 PM
AlpineJim's Avatar
check your connections, battery and fuses..
Matthew
03' 600rr - Track
AlpineJim is offline
post #4 of 7 (permalink) Old 04-15-2006, 10:07 PM
Back in the Day
Moeman's Avatar
Images: 665
Feedback Score: 148 reviews
Check the BAS it a sensor that is located between the headlights
make sure you installed it correctley there is an arrow on the back of it
make sure its pointed upwards
Moeman is offline
post #5 of 7 (permalink) Old 04-15-2006, 10:38 PM
the connection that goes to your gagues it feels like it is connected but it isnt push it in real hard and make sure it clicks or wont start
urbanstreetrider is offline
post #6 of 7 (permalink) Old 04-16-2006, 11:08 AM
NewRedRider's Avatar
Images: 24
If you removed the BAS make sure you jump out the wires. (White/Black and Red/White)
NewRedRider is offline
post #7 of 7 (permalink) Old 04-16-2006, 12:42 PM
I Am a Ticket Magnet
hammbone's Avatar
Images: 2
yep sounds like your BAS..... It shuts off your fuel pump in the event of a tip over or crash.
Pics Here >> https://www.600rr.net/vb/showthread.php?t=70659
*On falling off a race bike at high speed -It's kind of like tumbling around inside a giant clothes-drier.
Dave Aldana (1975)
*At 180 mph, when your front wheel wants to play pogo stick, you don't do nothing. You don't sneeze, you don't hiccup, you don't even breathe. All you do is point it and hang on.
Kenny Roberts
hammbone is offline
