oil light... - 600RR.net
post #1 of 18 (permalink) Old 03-18-2006, 02:14 AM Thread Starter
oil light...
hey i just got my bike up and running the other day and now right when i start up the oil light blinks, then lighs solid, then blinks again.
i checked the sight glass and there is PLENTY of oil in it and i am stumped.
any help would be appreciated!
They Call me Streetfighter...
Boostjuice is offline
post #2 of 18 (permalink) Old 03-18-2006, 02:23 AM
Blizzle RR's Avatar
I just did a search on it, if its 7long flashes & 1short one it could be the tp sensor (throttle position sensor)
Blizzle RR is offline
post #3 of 18 (permalink) Old 03-18-2006, 01:28 PM Thread Starter
how easy/hard is that to change?
post #4 of 18 (permalink) Old 03-18-2006, 01:37 PM
This is for a PCIII Install but will show you where and how to get to the TPS ..... bout half way down . Is a big job bro ...sry......Dont run it till you find out tho . No Oil pressure is NO JOKE ! You lock her up quick
https://www.600rr.net/vb/showthread.php?t=39231
HRCFxtreem is offline
post #5 of 18 (permalink) Old 03-18-2006, 02:15 PM Thread Starter
i dont know if its good or bad news but im pretty sure i can get to it without doing any work.....
thats the state the bike is in at this moment(add lights)
post #6 of 18 (permalink) Old 03-18-2006, 02:18 PM
Blizzle RR's Avatar
Did it go through those flashes that I stated, bro?
post #7 of 18 (permalink) Old 03-18-2006, 02:19 PM
Right on .... left (shifter) side ........ area at the end of the fuel rail ...... you will see it ..... has plug stickin out the top ...... also .... maybe can check the ohms on it see if its good .... same dude that told you about the light could prolly tell you the range for a meter ...... or if you have a real shop manual should say it too ........
post #8 of 18 (permalink) Old 03-18-2006, 02:22 PM
AlpineJim's Avatar
From what I know, you can't replace the TPS on the TB's... Because its not sync with the TB from factory and you can't calibrate them...
You will have to buy a whole new TB.. cheapest place would be ebay.. But if someone messed with the white screws on the TB..
Goodluck bro!
Matthew
03' 600rr - Track
AlpineJim is offline
post #9 of 18 (permalink) Old 03-18-2006, 02:23 PM Thread Starter
yeah i found it BUT...
its 7 blinks on startup, then chenges to 9
post #10 of 18 (permalink) Old 03-18-2006, 02:37 PM
AlpineJim's Avatar
is it 7 short blinks
not a pause that last for a second (1.3sec)?
Matthew
03' 600rr - Track
post #11 of 18 (permalink) Old 03-18-2006, 02:43 PM Thread Starter
yeah the 7 are about 1.3sec, and the 9 are a bit shorter
post #12 of 18 (permalink) Old 03-18-2006, 02:48 PM
AlpineJim's Avatar
That would make the code 79.. but highest code is 49
Each long blink = 10 and short blink = 1
Matthew
03' 600rr - Track
post #13 of 18 (permalink) Old 03-18-2006, 03:10 PM
Blizzle RR's Avatar
Hows the bike running & do you have a power commander?
post #14 of 18 (permalink) Old 03-18-2006, 03:23 PM Thread Starter
the bike runs fine and no i dont have a power commander.
its 7 at first then it only repeats 9 over and over again. never seen a second 7 set.
post #15 of 18 (permalink) Old 03-19-2006, 11:25 AM Thread Starter
so i mis counted...
its code 9
post #16 of 18 (permalink) Old 03-19-2006, 11:51 AM
AlpineJim's Avatar
You need to check your IAT sensor...
Matthew
03' 600rr - Track
post #17 of 18 (permalink) Old 03-19-2006, 12:39 PM Thread Starter
what and where is that?
post #18 of 18 (permalink) Old 03-19-2006, 01:22 PM Thread Starter
nvm, found it in the service manual
thanks!!
